Homebrew Cheese Cultures
1,626
20
It's the night before my last major exam this year. I already have plans for after the exam... Make cheese, but this time enlisting the help of my girlfriend for a laugh. But every good cheese needs a population of bacteria to taste divine, so here is an easy way to whip up both commonly used bacterial cultures for your cheese!
Step 1: What You Need
These few ingredients are simple and found in most supermarkets: A tub of natural(unflavoured) yoghurt A tub of Cultured buttermilk- the keyword being cultured Ice cube tray- I used a Lego one since I had measured it out and each ice cube would contain half an ounce of frozen culture. When preparing your culture you should measure out the volume of your ice cube tray so that you know how much each cube will contain
Step 2: A Waiting Game
Now for the long bit. The bacteria in the buttermilk are mesophilic, meaning they thrive in room temperature conditions. So take the lid off the buttermilk, place a tissue over the lid, to keep dust out, and set it aside overnight. This lets the bacteria reproduce at optimal conditions so that the buttermilk will have the maximum population, key to making cheese.
The yoghurt is different. It's bacteria are thermophillic, they thrive in slightly warmer conditions than that of the mesophilic bacteria. I'm not sure if you leave it out overnight, I bought naturally set yoghurt. This means that the bacteria have reproduced and converted the lactose sugar into lactic acid, decreasing the pH of the milk and thickening it. Just like why we are leaving the buttermilk out.
Step 3: Freeze It
If you bought naturally set yoghurt then you can freeze it straight away. Mix it with a spoon so that it becomes slightly more workable and pour it into an ice cube tray. Place it in the freezer for a few hours until frozen. Because of the thickness and bacterial population of the yoghurt I started to freeze it whilst waiting for the buttermilk to thicken overnight
Step 4: Bag It and Tag It
Now that the culture is frozen, pop out the cubes into a freezer bags, marked with the date of freeze and the temperature preference of the bacteria. This is important so they can be used in the right cheese, at the correct optimal temperature and so that you know when to renew the culture. Once frozen, the culture should be used within one month, or renew after that month by thawing in some milk, allowing the bacteria to multiply again then freeze the new thick soured milk.
    • Organization Contest
    • Pie Contest
      Pie Contest
    • Weaving Challenge
      Weaving Challenge
    3 Discussions
    caeric
    5 years ago
    Great ible! Being a new cheese maker, how do you determine between meso or thermo cultures? Also 1 cube does how many gallons, ie 1 cube per gallon of milk? Also would you let this ripen just like the powder meso culture? Thanks for sharing!
    thomas9666caeric
    Reply 5 years ago on Introduction
    Generally it's a mesophilic culture found in cultured buttermilk and the bacteria in yoghurt is thermophilic. I don't know as of yet if there is any way to differentiate easily between the two.
    The number of cubes is proportional to the size of each. I used an ice cube tray that produces half ounce cubes, so in most of my recipes I use 4 of them to get 2 ounce of culture, thawed in a cup of milk and added to the main batch.
    If you're meaning letting it ripen in the main milk batch then you just leave this as you would a DVI powder, this is just the same bacteria, same population size but it's just been home grown and frozen for convenience. The DVI powder is the same, but just freeze dried, for a longer shelf life.
    Hope this helps.
    Tom
    caeric
    5 years ago
