Homebrew WISP ( Wireless ISP)
159,054
159
126
About: Do-It-Yourself electronic projects I've made. Read it, Learn it, Use it....spread the word!
I have always been amazed with wireless technology even before. I remember during our high school days. My friends and I were DREAMING on how to propagate data packets using the VHF radio (145.00 Mhz) and a Commodore 64 computer. It did not materialize though, we haven't had the chance to test it because of money considerations, back then a Commodore 64 PC cost thousands of Dollars. Cassette tapes were still used for file back-ups, no Hard Drives and Floppies yet. Well ..... so much with History.
This project is to make a homebrew wireless ISP in your neighborhood, this is to share your internet connection using wireless technology. Although we have questions about security issues but I won't be touching that topic, my reason for this blog is just to show how powerful this technology is and how it can help bring internet connection to rural areas. I will be using cheap materials you can find anywhere.
Supplies:
Step 1: Materials and Fitting
Materials Needed:
Plastic Transhcan - used as enclosure
Access Point
Homebrew POE Injector and Antenna
Power Supply Regulator
a. Fitting the Access Point and Supply Regulator
Using a plywood, cut the desired size so that it will fit inside the trashcan. The wood will be used as the base for your AP and the Power Supply Regulator. I will be using the regulator I made in my previous blog.(https://www.instructables.com/ex/i/BD1BA19AFB3510289811001143E7E506/)
Look at picture #2 and #3,It would look like this after putting the AP and the Regulator. Take note that there's a bolt near the regulator, this will be used to attach the wood to the plastic trashcan afterwards. The RJ-45 modular box is part of the POE I made. You can make your own POE using this link (http://www.nycwireless.net/poe/) as reference, this is a cheap alternative that works well.
Step 2: Putting It All in the Trashcan
I am only using a rectangular plastic trashcan. I live in a tropical country, the only problem is to secure the AP from getting wet. No SNOW or DUST STORM to worry about here... Now,make all the needed holes to bolt the plywood and the trashcan together.
I designed a metal holder for the trashcan with U-bolts for the mast installation (picture #2). Using it to hold the plywood and the plastic together.
As you can see in the third picture,the bolt is holding the plywood, to the plastic and the metal holder... all three of them.
Step 3: Installing the Antenna and Finalizing the Rig
I made a Bi-Quad antenna using Trevor Marshall's (http://www.trevormarshall.com/biquad.htm) design but tweaked it a little bit to make use of my available materials. I will be posting a separate blog for this.
The second picture is a peek of my Bi-Quad inside the plastic enclosure. You can see the Copper Cladded Board or PCB used as the reflector and copper wire for the main element.
I am using an RG-58 (50 ohms)cable from the Linksys AP to the external antenna, compatible connector for this particular Linksys is RP-TNC.
After putting everything inside the Trashcan, I made a plastic cover to keep the Birds from nesting inside. This will also protect the AP and the Regulator from mist during heavy rains.
Step 4: Putting All in the Mast
Using the Metal Bracket that I made, the "loaded" Trashcan can be securely fastened to the mast,installed also the antenna.In the third picture you can see the Trashcan and Antenna in all its Glory. Sweet huh?
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    126 Discussions
    gotwificowboy
    1 year ago
    Love it ! You did excelent using all that you could find and build, and then applying your skills. I have developed hundreds of WISP's and love the idea, and yes folks this will work.
    WIFIENGINEER
    9 years ago on Introduction
    that would be ok for a point to point application
    If you want to be an access point though you would need to us an omni directional antenna or construct sector antennas
    I have sucessfully established a 40 mile point to point link using 2 parabolic reflectors and 500mw
    Something else that helps is using 802.11b
    It will easily outdistance 802.11g and 802.11n
    JustinR128WIFIENGINEER
    Reply 2 years ago
    hey i have some question id would like to talk you email me justintrags@gmail.com
    drserverWIFIENGINEER
    Dear Sir/
    I am Internet Cable Service Provider, I cover 2 Kilometer area. I have almost 500 Internet Cable coustumers. I want to convert my whole Cable Network into Wireless Network. I would be very thankful to you if you can help me out from this problem and tell me also about your products which will help me to do convertation.
    Thanks,
    - Mohib
    JustinR128drserver
    Reply 2 years ago
    hey drop me a line i would like to talk justintrags@gmail.com
    JasenB
    2 years ago
    I really hate to ask this... but is this a method of actually being able to provide access to the internet to others and yiurself... with out having to get it first from at&t or comcast or some other provider?
    It seems like a stupid question but i am trying to wrap my brain around this and an idea i have but there are basics of this i need to understand first.
    GravityS
    3 years ago
    Hats off to you for writing
    such an informative piece of work. I must say that I have never seen such a
    fine work. Keep it up.
    faustin1
    7 years ago on Step 4
    I do not see this antenna booster working to well. WiFi uses Microwave frequencies.. RG-58 cable and Pl259 connectors are not designed for those ranges.
    LM400 cabling and sma connections should had been used for max effectiveness
    cwiegandfaustin1
    Reply 5 years ago on Step 4
    For the low power outputs here and short cable runs I wouldn't be too worried. More power might damage the equipment or longer runs would cause more signal loss. I'd keep the cable as short as possible.
    Why would you put the access point in the trash can on the pole? could you just have the linksys in the house and run the signal cable up the pole to the antenna instead? Just courious why you did it they way you did..
    ghz24mikeinbellingham
    here's why
    100 feet of rg-58 loses 32 dB at 2.4 ghz that's your signal is cut in half 10 times or about 0.1% of the signal gets through.
    LMR-400 lose is 5.8 dB/100 feet so you only lose ~3/4 or 75% of your signal.
    cat5 cable (Ethernet ) ~300 feet lose of signal zero.
    better to run cat5 to location then use 6 " of coax
    pppd
    10 years ago on Step 4
    ok, good one, but.. this is not a wisp project, this is more or less access on the net. you need a lot more to make wisp.being N.A.S the first. (not storage but the Network Access Server) to justM: I have build a phased quad antenna reflected by a 90cm parabola & established connection (with the same gear at the other end) in 7Km range and 100mw lasted 3 yrs then i took it down. but still works,
    fouazpppd
    Reply 9 years ago on Step 4
    I'm newbie in this kind of Tech , a 'll be gracefuller if you give us a simple tutorial to built a phased quad antenna reflected by a 90cm parabola. thanks at all
    A further enhancement for this project would be to take your wifi router and flash the firmware with dd-wrt which gives you many more bandwidth filtering and other options than the stock Linksys firmware. Also use OpenDNS, which is free, to restrict access to websites that won't get you in trouble with your ISP or the law if someone in your neighborhood wants to go on a questionable website. You can set up a list of website categories such as porn content in your OpenDNS control panel account and block this from being accessed through your open wifi connection. Then point your DNS settings in your wifi router to connect to your OpenDNS account settings to implement the type of content you will allow people to access through your connection.
    rsdandy
    10 years ago on Introduction
    I know this is coming in late, but I could not go without posting a couple of things. Everyone with the idea of providing service for a neighborhood, or similar will be responsible for the actions of the people on the internet. Also, the FCC has some very strict rules about these things, along with the ISP that is providing the originating IP address. Especially if you plan to sell the service. Of course this all pertains to the U.S. Only.
    greenbeanrsdandy
    Ya, but if you live in a rural area who cares? If your broadcast does not interfere it is not illegal. (Part 15 of the FCC rules). I wouldn't suggest this in a city, but then it's not as necessary there.
    rsdandygreenbean
    Ok... yes the transmissions are legal, but the data may not be (spam, child porn, etc). And it all points to your IP address.
    greenbeanrsdandy
    Not if you split your router. You can have the router give out two different connections. One you broadcast, one you don't. That way you can use one internet connection and have your computer use one IP while everyone else uses the other. This is free to do.
    rsdandygreenbean
    Your modem, be it cable, dsl, or whatever, has one or more ip's assigned to it by the providers servers. The ip that the router gets from the modem, and the ip's that it assigns to users, all go back through this ip, which is associated to your account. If it becomes a serious enough violation, it is simple to determine which account provided the connection that violated the law.
