Homemade CNC Projects Part 1 - DIY Z Axis Slide Plans
3,566
36
More Homemade Vertical Milling Machine very cheap DIY Slide Mechanism CNC here:
So you want to build a CNC machine, but you're not quite sure what kind of machine to build?
How much can you afford to spend on your CNC machine? Some are more expensive than others.
Feature
X, Y, Z Work Area:250mmx250mmx80mm
Max feeding height(mm): 65mm Machine Size: 450mmx350mmx390mm
Work table size: 250mmX250mmX80mm
Material: 6061+6063 aluminium alloy Stepper motor: 57 series ,2 phase,4 lines ,
3A new stepper motors Transmission unit:High strength stainless steel screw Sliding unit: X-axis=20mm round rail, Y-axis=20mm round rail, Z-axis=20mm round rail.
And More Homemade PCB Press Drill DIY Drilling Slide Mechanism CNC here:
Supplies:
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
