Homemade DIY Power Bank Using 18650 Battery
75,951
110
37
About: Hi, I am Mechanical Engineer. But loves Electronic mini projects too. Also like to do creative things. Whenever free, I will always be learning something. Had posted these projects when I was Engineering Stu...
Hello my dear friend,
Want to make power bank at home? Have old dead laptop battery? And want to make something new?
This is a very simple project. You need not to be very good in electronics. It requires very less components.
You can also do much more modifications in it.
I highly recommend you to view this video, it has every thing explained in details.
(This is my first video and project presented on net :))
Supplies:
Step 1: Gather Some Parts
Main required components
  • 18650 Lithium ion battery
  • 1A TP4056 module with protection circuit
  • 3v to 5v USB DC-DC step up module
  • A box/case
Tools Required
  • Soldering gun and some metal
  • Glue gun (if you have)
  • some wires
Step 2: The Boss of Power Bank - BATTERY
The main & costly part in power bank is Battery.
The price of every power bank is always dependent on 18650 battery.
Why to use 18650 only?
• Small in size
• Can store large power than any other
• can sustain High discharge current
• Light Weight
Where to find 18650?
• Old Laptop battery (good source, free, many batteries,original)
• Online or local store
Dead laptop battery also have some working 18650 batteries.
I highly recommend you to use at least 2 batteries. One battery is also sufficient. But more batteries will give you more mAh & more input charging current
NOTE-
Beware of FAKE batteries.
Use trusted sites, stores, brands
take care to do not short circuit. (high power = more precaution)
&& +ve terminal + -ve terminal + short circuit = loss of money
You can also use old 3.7V mobile battery.
Step 3: Connections / Circuit Diagram
Connect modules as shown in diagram.
Connections are very simple.
You can also use Single pole switch instead of DPDT switch.
If you want to increase mAh then connect more batteries in parallel.
2nd image shows connections that i had made for my power bank.
Circuit diagram is explained in details in video.
Step 4: Assembly
This is what I made.
I had not shown you how to make assembly in details. The reason is that, every person does not find same size box/case as shown. They can use their own innovative ideas for fitting all the items in what they find.
1) So besides that, I found a small box at home for my power bank.
2) I fitted a small plastic spacer to make space for battery with glue gun.
3) Then used battery connectors instead of directly connecting wires to battery.
4) Made slots in box using soldering iron (Old tip).
5) Put both modules in box and fixed using glue gun.
6) Inserted Battery & that's it it is ready to use.
Step 5: Testing and Modifications
I Had tested my power bank and shown in video.
The power bank works well & as expected.
The mobile is of 2500mAh
And it charged at the rate of approx. 1% per minute.
The power bank if is fully charged, then it can charge mobile once fully. Then it need to be charge again.
So i suggested you to use more battery. But if you want to make it small then use 1 battery.
Modifications you can do :-
1. Make inbuilt emergency torch.
2. charge by solar panels.
3. You can also use this as power source for arduino 5V projects.
4. Can also use old mobile battery.
A VERY BIG THANK TO YOU
Give your opinion regarding to this project & also any improvement needed for presentation & project.
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    37 Discussions
    Pennygolin
    Question 23 days ago on Step 5
    Is it possible for steps on how to connect the wires and the dpdt
    PatrickB312
    Question 10 months ago on Introduction
    Hey Rahul! What if like I want to create 12slots of 18650 battery for power bank. What kind of module should I buy? Is it possible to to increase the mAH?
    1 answer
    deostroll
    Question 4 months ago on Step 5
    When charging phone how much mA current does it consume? Looking for something that can give about 600mA current...any advice?
    giuseppecong
    Question 9 months ago
    What's the switch for? Can I skip it?
    qinchetan
    2 years ago
    Why is the positive terminal from TP4056 is connected to negative of DC-DC booster converter?
    dperkin3qinchetan
    Reply 1 year ago
    I think that is a mistake. I just finished building this. I hooked the positive thru a single pole switch to the positive input on the boost module.
    BenM313
    Tip 1 year ago
    The cells to build DIY powerbanks in the UK can be sourced quickly and at a very good cost here- www.18650.uk
    B_Hoops
    Question 1 year ago
    Hi, if i wanted to add a solar panel or dynamo in as an additional method to charge the battery where abouts would I add this? I already have a bridge rectifier with smoothing capacitor circuit that produces the correct output voltage from the dynamo. Many thanks
    JayceV
    Question 1 year ago
    Is there any way to get a bust module the will just sense the load and turn on or or there a way to remove the switch from the circuit?
    R0CKINGR
    Question 1 year ago on Step 1
    Hey Friend where I get 1A TP4056 module with protection and 3v~5v usb dc~dc setup module ? Can I get it from local shop or online ? Please reply me 1st ... I want to make it fast !
    1 answer
    Rahul - SR0CKINGR
    Answer 1 year ago
    You can found it online easily. Search 'tp4056 protection'
    Mouse6452
    2 years ago
    If I wanted to add a voltage meter to show the amount of power that the battery had left, where in the circuit would I put that?
    edwinl33
    1 year ago
    I saw 2 types of step up boost module. Which of this 2 modules works best? The blue one output current is 600mah only, while the red one output current rated at 1A-1.5A.
    randoms9edwinl33
    Reply 1 year ago
    most phones draw at least 800ma so get the red one
    edwinl33
    1 year ago
    I want to make a powerbank the same as the one you made. But consist of 2 18650 li-ion battery with 3.7v 6800mAh each. Is it okay for the TP4056 charging module to charge the 2 18650 in parallel connection?
    ericliu126
    2 years ago
    Since i want to build 4 packs for my family, so I bought 20 18650 cells from
    https://www.dnkpower.com/li-ion-18650-battery/
    however, when i go on with the projects, i just find I have no tools to make them together,anyone have great ideas so that i can put them together with easy steps?
    MaciejJ5
    2 years ago
    You wrote "I highly recommend you to use at least 2 batteries" but you connected only one in this project. Do you know if the TP4056 module will be working with 2+ batteries or I should use something different? I am looking to use 6 18650 batteries.
    Rahul - SMaciejJ5
    Reply 2 years ago
    Yes. They will work. Only thing you need to do is connect them in PARALLEL. That's it. And it would be good to to use upto 4 batteries. More batteries provides more current and more risk. Thanks :)
