Homemade Dremel Sanding Disks
1,938
32
8
About: An electrical engineer who likes to make things.
I've been cutting a lot of glass ever since I got diamond cutting wheels for my dremel, and cutting glass means sanding glass (assuming you don't want it to cut you). So I've been doing plenty of sanding.
I use 60 grit, 120 grit, 400 grit, 800 grit, and 2000 grit! Honestly, I was really excited to see they had the 2000 grit in stock near me. Then I finish off with a dremel polishing wheel, but I had been sanding by hand, and the whole process would probably be a lot faster if I used the dremel for all of it, right? Now I imagine there must be a variety of dremel sanding products out there, but as mentioned, I am the proud owner of a large amount of sandpaper.
What's that? You have a lot of sandpaper too? You aren't proud of it? It's a weird thing to be proud of?
Sure, I suppose. Anyway, I decided to make my own sanding disks! (discs?)
Continue on for the full instructions, or for the short version
-Computer paper for strength
-Glue for unity
-A hole, to attach it to the dremel
These are the steps which follow. Combined, I can smooth the mouth of a glass so it's safe to drink from.
Step 1: Supplies
For this project you will need
  • Sandpaper
  • A dremel cutting wheel (or some other circle to trace)
  • Glue
  • Scissors (note: I imagine cutting sandpaper damages them)
  • A sheet of paper
  • A mandrel (this is what the sanding disk attaches to. It goes in the dremel.)
  • Something to punch a small hole (I used a corkscrew)
Optional
  • A ruler
Step 2: Disk Templates
Trace the outline of one piece of sandpaper onto your sheet of paper. This will show you the usable extent of the paper.
Trace your cutting wheel or other circular item onto the sheet, and be sure to mark the center. Repeat for as many disks as you would like; you may find a ruler useful in keeping them organized.
Step 3: Fold and Glue
Fold the paper in half such that the circles you traced will face outward.
Apply glue to the back of one side; this is the inside of the fold.
Fold shut and apply pressure.
This layering will add strength to the disks. In the past I've run into two issues, one was my homemade disks tearing at the center.
Step 4: Cut It Up (or Don't)
If you want to make all of your disks from one type of sandpaper, don't cut anything! Go to the next step.
I made disks for 5 grains of sandpaper, so I cut my disks into 5 sections. 2 sections of 6 disks, and 3 sections of 3 disks.
Step 5: Gluing
Glue your circle template, circle side up, to the back of the sandpaper. Make sure the circles aren't hanging off the edge of the sandpaper.
Apply pressure.
Step 6: Punch Some Holes
Use your hole punching tool (a corkscrew works great!) to punch through the middle of your disks. I found it easier to do this before cutting them out.
Be careful not to jab yourself, and try not to jab anything else either.
Make sure the screw for the mandrel fits in the hole.
Step 7: Get Cutting
The second problem I've had with my disks is tearing radially. This is usually the result of part of the disk catching, so it's important that they're as circular as you can make them.
Step 8: Use Them!
Go forth and sand things!
(Like the mouth of a bottle that you cut the top off of!)
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    8 Discussions
    RodrigoS94
    1 year ago
    Get a beer can, cut, open, glue the sandpaper on it, will be better to use. The sandpapper is too easy to rip, than, u use the aluminium can that is more malleable.
    MagnelectrostaticRodrigoS94
    Reply 1 year ago
    Ooh, now that's a good idea! I recently got a circle punch, so I'll have to see if it can cut an aluminum can.
    Do you know if normal glue will bond to aluminum?
    Yonatan24Magnelectrostatic
    Reply 1 year ago
    I would think that since the disks are so small, the sandpaper would get dull really quickly, and the time that it would take to replace them would make it non-worthy.
    MagnelectrostaticYonatan24
    Reply 1 year ago
    I see. Admittedly, I started sanding from a pretty uneven cut, so I used a sheet of 60 grit sandpaper (by hand) before the disks, but for what I was doing (the mouth of a glass), the disks - 5 grits - held up fine. The 60 grit disk took a beating though.
    For sanding something large, doing it by hand is probably the winning route.
    bionicbenjy
    1 year ago
    nice... a large craft punch or a plotter/cutter machine could be used to get perfect circles.
