Homemade Dryer Sheet Replacement
125,317
1,203
48
About: Made in Canada, I grew up crafting, making, and baking. Out of this love for designing and creating, I pursued a BFA in product design from Parsons School of Design in NYC. Since then I've done work for Mart...
Wool dryer balls are a simple to make, cost effective way to keep clothes soft and wrinkle/static free! They deliver the same benefits for laundry as commercial/conventional dryer sheets WITHOUT all the nasty chemicals. And due to their bounciness, they also work to create more space in between your garments during the drying process, which allows better circulation of the hot dryer air. This reduces drying time by up to 25%!! - resulting in huge time, cost, and energy savings for you!
Let's get started!
Step 1: Choosing Your Yarn
You must buy 100% wool yarn (no synthetics) that has a minimum wool content of 85%, with any additional fibers being natural. As an example, my wool was 85% wool / 15% mohair and it worked really well. Also be on the look out for roving which is a looser, more 'open fiber' yarn that felts better than standard wool yarn.
I made my balls about softball size and used 90 yards per ball. It's not absolutely necessary to make them as big as I did (baseball size will do), so feel free to use less wool per ball.
Step 2: Getting Started
The only other things you'll need other than the wool, is a nylon stocking, scissors, and about a 3 foot length of either acrylic yarn or embroidery thread.
To get a ball started, using both ends of your skein (double up!), start wrapping the yarn around your fingers. (2 or 3 fingers work)
Step 3: Grow Your Ball
Once you have 6-8 wraps of your fingers, pull your 'starter' off and wrap a couple of times around it's middle. (like pictured) Then turn it and squish it from end to end and continue to wrap your starter until you've formed a small round sphere. Keep wrapping until your ball is anywhere from baseball to softball size.
Step 4: Tucking Your Tail
Once the ball is the size you want it, cut the doubled up ear, leaving a 2" tail. Tuck the ends underneath a few yarn strands and push it down towards the center of the ball with your finger. If you don't feel like it went in deep enough, grab your scissors and use one end to push it in further.
Repeat the last few steps for however many balls you want to make.
3-4 balls for small to medium loads
5-6 balls for larger loads
Step 5: Getting Fancy
This next step is completely unnecessary, but I love a chance to add some visual fun when possible.
Inspired by Italian Bocce Ball sets, I used colored wool yarn to add some fun embellishment. Tying and tucking the ends the same way I tucked the ball ends.
You can get all kinds of creative with this one!
Step 6: Felting Your Balls
To protect your balls during the felting process, do the following:
  1. Cut four 7-8" pieces of acrylic yarn or embroidery thread.
  2. Gently stuff the first ball into the end of a panty hose leg or knee high, being careful not to move the decorative yarn patterns if you decided to try that.
  3. Use one of the acrylic yarn pieces to securely and tightly tie the fist ball in place.
  4. Repeat this for all your remaining balls, being sure to finish with a tie too!
Now your balls are ready to be felted.
Add your wooly caterpillar to a load of towels and wash in hot water, dry on high. Repeat this one more time.
NOTE: The balls will continue to felt even more over time with use.
Remove the balls from the pantyhose and...
Step 7:
Voila! You have upped your drying game for the next 1000 LOADS!! - have saved yourself time and money, and the environment energy. That's a lot of win win if you ask me.
You can also add essential oils to the balls prior to putting them in if you're used the adding scent to your clothes. Lavender works really well.
Now go forth and soften!
  • Classroom Science Contest
  • Fandom Contest
    Fandom Contest
48 Discussions
crewelgirl
2 years ago
I made these & they did not work. At all. Very disappointed.
I used 100% wool; as you can see, they felted nicely, and the directions were identical. Anyone else out there that this did not work for? Any idea why it did not work?
KianaBrowningcrewelgirl
Reply 5 weeks ago
Ya mine unraveled one by one until the last one tangled my clothes when I thought I could use it after felting.
AllisonE4crewelgirl
Reply 2 years ago
What didn't they do? I use wool balls in my dryer (Haven't made them yet though, just bought some) and I find they help. I scent mine with oils, and they make my clothes smell pretty. I'm just curious what didn't work for you?
Yeah, I thought maybe you soaked the yarn balls in baking soda, but apparently this has nothing to do with baking soda...
LOL I was wondering the same thing! The baking soda article was what drew my attention to this site to begin with.
Gadget93
3 years ago
What does the term "felting" mean. Other than not understanding that part, this is a great instructable.
mistergreen
3 years ago on Step 4
I'm a dude, any way to do the felting other than with the nylon? I guess i can buy some at the dollar store, but it seems weird to buy something i don't use, only to destroy it for a DIY project. My balls turned out great. There is something oddly zen about wrapping yarn around itself for 20 minutes.
Cheese Queen
5 years ago on Introduction
Oh, I like these! Downtown to get some pretty wool, stat!
FYI- if you use dryer sheets, the chemicals in them will coat your lint screen to the point air can hardly get through, even though the screen looks clean.
Try this- take the lint screen out of your dryer, clean it off and hold it under slowly running water. If you use dryer sheets all the time, you will probably see the water collecting in your screen like it was a bowl, instead of running right through!
Take a soft brush and a little dish liquid, and give your lint screen a scrub to remove the coating- your dryer will thank you!
dropkickCheese Queen
Reply 5 years ago on Introduction
Cheese Queen,
I'm not arguing about dryer sheet chemicals coating your lint screen. I have no problem believing it could happen.
However I think you might be confusing the surface tension of water for blockages. When you try to run water through a screen it will cling to the edges of the holes and itself restricting the flow. This is a natural property of water. It's what makes water bead up on surfaces.
Dish detergent works by breaking the surface tension of water so it soaks into the particles stuck on plates and loosens them. So when you put dish washing liquid on the screen it will naturally increase the water flow by breaking the surface tension.
dawndowd
jbh123 asked about the static. And I didn't see an answer anywhere (though I could easily have missed it). I will add one question of my own -- do the felted wool balls create excessive lint (if I use white roving and eventually use it in the dryer with black jeans, will I have white spiderwebs of wool on the jeans)?
Sometimes I need to dry a load of nylon quick-dry clothing and the static can be really horrible. I don't necessarily need to know what property discourages the static; I simply need to know it does since the static is the only reason I would use a dryer sheet.
I do know about felting and wool and LOVE this idea! Thanks.
Demariondawndowd
I'm not sure if it'll get on your clothes, (I just made these yesterday so I have yet to try them out!) but I read that if they get too fuzzy or pilly, you can shave them with an electric razor (or those ones made for sweaters). That could cut down on anything if it does make other clothes fuzzy.
Paige RussellDemarion
Reply 4 years ago on Introduction
Hi! Due the 'knitting' of fibers from the felting process (they really stick to themselves as a result), you shouldn't get any fibers on the clothes you are drying. As for static, I've been using these for just over a year now and I find them to be very effective at eliminating static - but note that I'm drying mostly natural fibers like cotton. I'm not sure how effective they would be on a dryer full of nylon. As sconner1 said above, not over drying also helps.
sconner1dawndowd
Dry air and friction make static. Wool against synthetics/rubber are particularly good at creating it.
I think if static is excessive, then you left the dryer on longer than the clothes needed to dry. The low humidity and friction built up a good charge.
Try using the automatic setting on your dryer if it has one instead of the timer setting. They use a sensor and shuts the dryer off when the exhaust air reaches a low enough humidity (the clothes are dry) instead of "overdrying" which wastes energy.
vonronge
4 years ago
I lile this instructible. Balls in the drier will help, particularly when drying large items like jackets or pillows. This will not prevent static without chemical help thoigh. Do be careful with essential oils in your drier, some can dissolve many polymers, and will make clothes made from them look old faster. It is also best to be careful with them because most people will develop rashes if exposed for long periods in cold climates.
lsutton3
4 years ago
Win win totally
lsutton3
4 years ago
Love it
