Homemade Fly Cutter - From Scrap Steel
7,163
31
14
About: I tend to be a bit of a Jack-of-all-Trades. Some of the interests I have are woodwork, metalwork, photography, electronics. I'm a father of two and a grandfather of 4. My wife and I live with our son and fa...
A need for a Fly Cutter to skim a surface down about 1mm and keep it flat. I recently bought a cheap new 7" x 14" Chinese mini metal lathe and as I expected there were some problems with it. The one problem, which I'm sorting out in this instructable, is to lower the height of the tailstock centre. It's about 1mm higher that the headstock centre which is unacceptable for long turning and drilling. After a lot of thought and browsing the Internet for a solution, and finding nothing, I decided to try and skim the upper base of the tailstock myself. To do this I would need to hold the tailsock firmly on it's side on the cross slide and to use a fly cutter to do the skimming. As I don't own a fly cutter I had to make one.
Designs and videos for fly cutters are aplenty so I chose to use one of the simple ideas which I could turn on my lathe and then work out how to make the tool holder slots. I have sort-of followed the design in this drawing. I don't think the dimensions are critical.
Pay close attention, however, to the slot holding the cutting tool in place. The point of the cutter must lie along the centre line of the holder and it is crucial that you make the slot on the correct side of the centre line. If you study the images and drawing, and think of the direction of the spinning cutting tool you will see that, because of the angle of the cutting tool, it can only be on the one side.
Step 1:
I needed a bit of round bar about 30mm in diameter and I determined to find some scrap. Why pay for it? So I phoned a good friend who also has a similar lathe with the same faults and asked him where we could find such a bar. He said, "You know what. I have an old piece 32mm x 450mm that I brought home all the way from Western Australia, about 4000 kms". He had been on a round trip of Australia a few months back and found this thing. "I'll bet your wife asked you, 'What on earth are you taking that piece of junk back home for?' " I said to him. He laughed and yes that's exactly what she said.
So I'm showing how to turn some "fools gold" into "real gold". One person's junk is another man's treasure.
Step 2:
Now that this bar was in my hands I cut 3 pieces out of it using a 1.5mm metal cutting disc in my angle grinder. 2x 70mm and 1x 40mm. I'm intending to use the 2nd 70mm length to make a second fly cutter for my friend who gave me the steel rod.
In a 3-jaw chuck turn the pieces down to remove all the rusted outside and face off the two ends.
Step 3:
This is the basic tool holder. I still have to mill the tool holder slots into the top at an angle of approximately 10 degrees. The tool holder head is about 25mm and the shank is about 40mm. I decided to tun the shank down to 20mm as accurately as I could as I am thinking of buying a collet set for the lathe (one day) and 20mm is a standard collet size. In the meantime I can put the 40mm shank into my 3-jaw chuck and spin the tool with that.
The length and diameter measurements are not critical but when we come to cutting the main tool holder slot it needs to be cut fairly accurately.
Step 4:
Being a round piece I tried to figure out how I was going to hold this in/on my cross slide/compound slide. I first had the thought that I would make a collet with square sides to clamp and hold it steady while I milled out the slots. So I turned up the collet as you can see in the pictures. The sleeve just fits over the shaft of the fly cutter and cut a slot through one of the sides. Clamping this in some sort of vise holds the cutter well - BUT there was no way I could find to support this in my quick change tool holder or on the cross slide without first making a vertical milling vise. Then I had what I thought was a brain wave...
I'm not going into detail on the making of the collet as I'm not using it for this project - it will just go into the bin for use on something else.
Step 5:
As my lathe tool post can hold a square bar of 8 - 10mm in it I could mount a square bar along the shank of the fly cutter. So, clamping the fly cutter shank in the 3 jaw chuck I scribed a line across its face (through the centre - this is important) and then without moving the 3 jaw chuck and marked a point on the shank of the part (so the line across the face and the mark on the shank are on the same plane). Then I turned the part around in the chuck and using the point on the shank, I scribed a line down the length of the shank. This will be the centre line to drill out the holes to support the square bar being fitted.
As I don't have a V bock in my drill press vise I had to resort to carefully measuring the distance from the line down the shank of the part across to the two jaws of the vise. This would give me a pretty good accuracy to drill the holes through the center of the shank. Having a V block would make this centre setup easy.
I carefully measured and marked the distance between the holes on both the shank and the bar using a digital caliper. As you can see from the images I drilled out the shank and the bar. The shank I drilled a 5.5mm hole for tapping a 6mm thread, and the square bar I drilled 6mm to slide the 6mm bolts through. (I wondered if I should have cut a flat surface along the shank to prevent the bar from any wobble but the bolts proved strong enough)
As you can see in the images I had to countersink the holes in the square bar and turn down the bolt head diameters to fit within the bar width (the square bar needs to fit squarely in the tool post holder without interference from these bolt heads)
When I screwed the bolts in tight the arrangement was very strong.
Step 6:
And here is the "gadget" holding nicely in the quick change tool post.
The angle of cut for the milling needs to be about 10 degrees so I set up the angle on my carpenters adjustable bevel. Using this I then set the tool post to the 10 degrees and clamped it down tight.
- this clamping must not be changed until the job is done.
Step 7:
The milling was straight forward but slow on a small lathe like this.
NB - The line I scribed across the face of the fly cutter earlier is now horizontal as it is held in the tool post. This is most important because this line is to be your reference and the main edge of the inner slot to be milled. The edge of the cutting tool should be on this centre line. Again I remind you to be careful of which side of this line you will make your slot. You can cut it on the wrong side. It will depend on whether the 10 degree angle is towards you or away from you. Picture the cutting tool in action as it spins in the chuck. If you get this wrong the cutting point cannot line up with the scribed centre line across the face of the tool. I set the angle of the 10 degrees in my case with the tool pulled in towards me (see image) and clamped the tool post down - this must remain clamped until all the milling is complete. As we are using the quick change tool post to hold the work the work, together with the quick change tool post holder can be lifted out and replaced without the 10 degree angle being changed..
Using the set up I have and using an 8mm end mill you will need to set the top edge of the end mill to run along the scribed line.
The depth of the tool holder slot will be determined by the dimension of the cutting tool you will be using. In my case I intend to use 8mm cutting tools so this slot will be 8mm wide and 8mm deep at the one end and a lot deeper at the other end (because of the 10 degree angle).
When you do the second cut (on the other side of the centre line, you will be milling away from the edge of the fly cutter to about 6mm from the first cut. This will give you a good thickness for the grub screws you'll be putting in to clamp the cutting tool. This second milling cut is also to be made a little deeper than the original 8mm cut to give space for the grub screws or if you use hex bolts instead of grub screws. This milled cut of mine was about 10mm deep.
Note: To keep chatter to a minimum I tightened up the lathe saddle plates and the gib slides on both the cross slide and the compound slide. This still allowed movement of the lathe parts but improved the cut. Oh. And if you don't have a saddle lock (something I still want to add to the lathe)( you'll need to use the lead screw clamp to stop the saddle from moving.
Step 8:
So when the milling cuts are done the part is removed from the lathe and face of the second milled cut marked and drilled out to take M5 grubs screws or bolts. Drill the holes using a 4.5mm drill and then tap them for 5mm
Step 9:
These images show a hole being tapped and the grub screws in place
Your milling cutter is complete.
Place it into the 3 jaw chuck, put in an appropriate cutting tool for the job, adjust the diameter of the cut (that's the full swing of the cutting point) and you are ready to go.
Note: I started this project using a set of cheap Chinese end mills but found that they got blunt and started to chatter. The chatter caused the end mill to dig into the surface leaving it uneven. I then bought a better quality 8mm end mill which cleaned up the surface left a much better finish, but I was left with a slot a little wider than the 8mm I started with. Not too much of a problem as I can put a shim behind the cutting tool, or use a larger cutting tool.
This project does not show the use of the tool. I will probably do another instructable on its use when I can get my tailstock part properly and accurately clamped onto my cross slide. There are many online videos on using a fly cutter in the mini lathe. I highly recommend you look at (or read) as much as possible on this topic as there are numerous cutting tools and cutting tips that can be used - and the cut and finish can vary depending on what you use.
Have fun using it, and think safety as this can be a dangerous tool.
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    14 Discussions
    Echo Pappa DeltaD
    6 weeks ago
    Thanks for posting, great work , given me an idea for a large hole cutter as well .
    billbillt
    6 weeks ago on Step 9
    Great job!.. I made one almost fifty years ago and it still gives good service.. Got my vote...
    markjfixit
    6 weeks ago
    Very nice job! Your lathe looks identical to mine hope yours is in better shape than mine. I have rust in several places that was hidden. One of the plastic gears are broke, The gears do not line up. Keep in mind I never even used it yet. Maybe you can do a article on the gear section if your plastic gears fail. Notice my supervisor is watching sorta lol
    GarthKHmarkjfixit
    Reply 6 weeks ago
    Hi markjfixit. My gears seem to be ok. There are a lot of videos on utube regarding the gears you might like to look through. One day I hope to start replacing the nylon gears for aluminium ones (when I can cut new gears). I research these mini Chinese lathes for maybe 1 year before I decided to buy one from Aus Amazon. I have decided that the basic lathe in all the names its sold under is the same but the finish is better or worse depending on what the price is. The lathes going into the USA seem to be in better shape than the ones coming here. I accepted that I would probably be getting some faults with my cheap lathe and I did. The badly installed saddle plates (under the ways) I took out and installed correctly as per some videos I watched. I also have a broken tap in one of the 3mm threaded holes for bolting down the rack gear (on the rack and pinion). It doesn't affect the lathe working but I'm trying to figure how I can bore it out and put in a good bolt. Hope you are able to sort out your gears in the mean time. (and your supervisor is sleeping on the job :-) )
    markjfixitGarthKH
    Reply 6 weeks ago
    Thank you for the reply, I may have sounded a bit edgy considering I kinda knew what I was in for from tube but still upset me. I keep at it and fix things as I find them but the gears are the worst. Little machine shop has gears but for their own machine. They won't say yes or no if they fit Chineseum lathes. EBay has tons but they don't say what they will fit at all. So back to utube I go. Hope you keep posting projects because it gives the rest of us inspiration!
    GarthKHmarkjfixit
    Reply 6 weeks ago
    I think most of these lathes are built on the CJ0618 and I think all the gears are the same. Why not buy one or two gears from eBay or your little machine shop in the US and check it out.
    bruce.desertrat
    6 weeks ago
    Nice instructable, it gives me confidence to try milling on mine. However, why not just shim up the headstock by 1 mm to fix the discrepancy? I'd think that would be simpler than milling down the tailstock, as that will be quite difficult to mount to keep it square during milling.
    GarthKHbruce.desertrat
    Reply 6 weeks ago
    Thanks for your comments. I have considered shimming the headstock but I am concerned shimming over the v-way up to 1mm. The flats across the bed are no problem but I'm worried that lifting the seat of the headstock over the v-way will throw off the lateral accuracy. I've also considered lapping the tailstock but 1mm is a lot - and also across the v-way. My upper tailstock section is flat underneath with just a keyway cut through it and there is plenty of extra clearance in the keyway depth. The face of the tailstock too is at right angles to the base so facing / fly cutting alignment should be quite easy once I have made up some cross slide support and clamps. I will not be not be doing any fly cutting on the tailstock until this is rock solid. I want to build up a vertical milling angle plate and vise for the cross slide so this is all part of the process. The fly cutter will come in very handy for this project too and it's all a good learning curve to use and make these tools :-)
    squared59
    6 weeks ago
    Yes! Great project. I am impressed you made it all on the lathe.
    GarthKHsquared59
    Reply 6 weeks ago
    Thanks. Yes the metal lathe is the king of tools.
    gm280
    6 weeks ago
    First let me say, nice project. Second, anybody can make things with the proper equipment. Part of the fun and intrigue is making things when you don't have all the needed equipment. Being clever to come up with ideas to accomplish your designed cutter is all part of the fun. I too need to make such a fly-cutter myself. I will use some of your ideas I'm sure. Thumbs up sir!
    GarthKHgm280
    Reply 6 weeks ago
    Thanks. Yes, I love to think out of the box and try to come up with my
    own ideas. Sometimes using things for what they were not designed to do.
