Homemade Cutting Dies
195,367
96
33
About: I've dabbled in pretty much everything. If I haven't odds are I'd like to learn how and try it. I'm one of the most conservative people I know. I am a semi-self-employed insomniac who can barely ride a bicyc...
Cutting dies are expenive to have made professionally for a custom application, and oftentimes it just seems easier to cut with an exacto knife than get a die made, especially if you will be making an unknown quantity of items. Depending on the complexity of your design and how precise your dimensions must be, making your own die can save you quite a bit of time and effort. If you must have ultaprecise dimensions, this method is not for you, but if being off by 3/32 won't cause the sky to fall, making your own cutting die is a straightforward process.
This die is designed for cutting paper. If you want something that you can put in a press and stamp thin sheetmetal with, you will need to use a different source for the blades (actual sheet or flatstock, not just the trash from last night's chili), and you will need to set these blades in wood or metal. If it's metal, tacking them in place with your arc welder is a good idea, but you will need to run a full bead (or braze) before you apply 12 tons of force. If you are building a press die, you will also need to get a small square, to make sure you have your blades at the right angle. For just cutting paper, it's nowhere near as tough, and that's what we'll be doing today.
Don't be an idiot like me and forget to sharpen all your blades before you bend them and stick them in tight corners. I have not actually sharpened this die yet, and if/when I do, I will update this with photos. Until then, you get a verbal description of what to do. It will work.
Step 1: Get Your Materials
-- You will be needing a block of floral foam large enough to fit your whole pattern on.
-- One or two metal food cans (empty them first. Yum)
-- Tin snips (don't just try big scissors
-- Gorilla glue
-- Needlenose pliers
-- Leather gloves (optional, but there will be edges ranging from kinda sharp to razor sharp)
-- Dremel tool or handheld drill (no drill press), or even a bench grinder if you are so lucky
-- Clamps or a vice (to hold things while you sharpen)
-- Grinding/sharpening attachment for your electric spinny thing of choice
-- A flat object big enough to fit over your entire pattern
-- Ruler or calibrated eyeball
-- Time and the patience to use it
Step 2: Cut Up Your Can
You want to cut your pieces about 3/4 inch wide, and however long you need for that section of your pattern. Try not to have a junction between blades in the middle of a curve, but if it's unavoidable, it can be done cleanly with a little dilligence.
Wear gloves.
Step 3: Sharpen Your Pieces
This is the step I forgot.
You want to get these exacto-knife-sharp. Put your blade (before you do any bending it might need) in the laws of a vice. Get out your grinder/sharpener and grind a sharp bevel on one side of the soon-to-be blade. You want a very low angle, not a wide one like on a chisel. If you have an actual exacto blade, use it as an example.
Do your grinding with little pressure, and make sure you don't stay in one spot too long. The last thing you want is a hot, soft blade. You could try warming it with a torch and tossing it in used motor oil, but I never saw the need.
When you're done, take a whetstone (or fine-grit wetsanding paper in a pinch) and run your newly created blade across it a couple of times, beveled side down, then flip it over beveled side up and do the same thing. Sharp endge leading. Now test it on some paper. If it cuts more like an exacto than a steak knife, you're ready to move on.
Step 4: Start Laying Your Die
You want to start laying out your pattern (wearing gloves!) in your floral foam. You really don't want to make a hole and then have to remove the blade and make another hole with it, so make sure it'll be square and located correctly.
Start from a good reference point. In this case, I started with the back wheel, because that tells me where the axle is, and therefore the limits of where the corner of the car can be. I had to cut the piece for the wheel a little longer than I expected I would need (then sharpen, right?), and cut it to length until I had the right radius. Measure twice, cut once, unless you're flying by the seat of your pants, then just keep cutting tiny bits till it works. If you cut too much and run out of can metal, go eat a can of pears and watch NASCAR.
Note: do not use Busch's baked beans cans for this application. I know, I can see the disappointment on your face. As great as their products are, they put what looks like some sort of emamel paint/coating on the insides of their cans. This keeps the tinny taste out of the beans, but it also is a very stubborn coat of non-metal. I use these cans as storage, not scrap metal.
And no, I don't send my cans to get melted. I make all sorts of things out of them.
Step 5: Bending Your Blades
Depending on your design, you might need to do some serious bending to make a section of your die. If the corner is going to have to be sharper than the nose of your needliest neddle nose pliers will allow, you are gong to need to make two blades and have them meet at the corner of this sharp joint.
An example of this is in the intake stacks on this hot rod. Since this is stylized design anyway, I wasn't too concerned about precision (or even mounting the engine straight), but you can see where I made the 135 degree bend, then for the sharper corner of the slashcut, made a new blade. You can see that from the firewall to the radiator, the engine is made of three separate blades.
This is a V8 Chevy small-block. The middle exhaust ports are siamese, remember? I'd have put a Ford in a Ford, except I didn't want to make four header pipes!
Step 6: Set All Your Blades to the Same Height
This is ultra-high-tech. Set your large flat object on your newly created die and lean on it. Be careful of pressing the blades too deep, and make sure it's parallel to the foam surface.
Step 7: Glue
Not that much glue. Seriously, less than you think. No, even less. A little... no... there you go. That should be plenty. Really.
You want your Gorilla glue to expand and harden your foam, as well as reinforce the blades from every angle possible, while keeping at least 1/8th inch clearance between the sharp bits and the rapidly expanding Blob. Unless you a are a master Gorilla Gluer, you won't quite get this right. That's okay.
If you have put on too much glue, don't do what I did and start paper toweling off the foam as it expands and threatens to swallow the table. You think I'm kidding. I wish I had photos (or even video of my panic as the glue just wouldn't stop), but I was covered in glue and didn't want my camera to share that fate. Wait until it dries and rout it out. Do this with a Dremel rotary tool if you have one. If not, that's okay, but the dremel is a heck of a lot faster because of its higher rpm.
Forget what your junior high woodshop teacher told you about routing with a drill. Embrace what your high school shop teacher told you: "go ahead, kid, try and rout with the drill press, but don't come crying to me when it doesn't work right." Maybe you never succeeded in your quest to hand-CNC a 3D B-52, but that doesn't mean you can't use a regular drill bit as a straight-cut router bit in a pinch. Use the maximum speed setting. Be aware of the bit catching a blade and kicking things around (no, shards won't fly). Go slow and gentle and you'll be fine.
Step 8: Cut
Do this on a soft rubber pad, like the underside of your average mousepad, or that craft rubber mat stuff that they have on papercutting tablets. Set your paper down, set your die on it gently, and lean on it. Make sure you've got pressure everywhere. Lift and check the results. Any spots that didn't get cut are either from a somewhat dull blade, or a gap in your blades. If it's a small gap, you can just keep an exacto on hand to cut that little spot easier than you can fix it. If it's a dull blade, there'll probably be a crease left in the paper where it should have done some cutting. Get out the ol' sharpener and fix it.
    • Classroom Science Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    33 Discussions
    oinquer
    4 years ago on Introduction
    i was thinking where to get other kind of almost ready steel rule.
    Maybe a bandsaw inverted where we would sharpen the wrong side?
    Like this? they are usually bendable ...
    andypughoinquer
    Reply 1 year ago
    You can get "band knife" which is a toothless bandsaw blade. It is useful for cutting foam, but would work well here too.
    The eBay search term to use is probably "bandsaw knife". They seem relatively inexpensive.
    mrsmerwin
    2 years ago
    wow. Sounds easy enough. Can you use other types of foam besides the floral stuff?
    MichelleB260
    2 years ago
    Oh my, you had me in tears when you talked about Gorilla Glue. I had the same thing happen to me when I used it the very first time. My husband laughed and laughed when i started to scream as the glue grew and grew and grew and grew, etc. LOL ?
    BelindaF
    Would this work with stainless steel cookie cutters do you think?
    HowardK2
    I'll add in...start a cut with a can opener on the non-lined variety (after consuming the peaches or pears)on the non dispense end first. Pry the incision upwards enough to cut off, leaving the cans beveled edge exposed just enough to pry the can opener slot upwards a slight degree with a small durable flat head screwdriver, (I wish there was a sniglet term for the perpendicular section of a cylinder; something universally applied for craft instruction), and followed up with a small needle nose, making sure that this initial cut is more than enough to allow plenty of room to allow a no-nonsense double incision with metal snips. The bottom can then be pulled back, and should resemble the generalized shape of a pop-top with its lifted up circumference edge. Glove handling on the dispensing end is all that is necessary for this starter cut. Cut the lifted tab off with the snips and hold the can in place on the bottom end of the can with pliers, made allowable thru this expose-cut step, ofcourse. Now you begin to create the serrated v cuts on the spout end securely using the snips and second pliers. Wear leather construction gloves at all times!
    HowardK2
    Your step by step writing method is wonderful. You must be the "go to" person in your corner of Colorado. I haven't yet read the rest of the method for this, but I'll add in that cutting a serrated edge like so IWWWWWWWWI from the edge of any metal can, with metal snippers, is effective. Keep the can intact while cutting and extracting the semi attached remnants holding the can in place with one pliers while twisting, wiggling, and yanking the excess with the other. Wear leather construction gloves for protection.
    johannsb8
    6 years ago on Introduction
    I am writting in re to a post on Jul 22, 2009. 11:36
    "I might try this to make some fabric dies but I'll probably just get some thin sheet metal" did you make a die and if so how did it work for fabric. Tracy
    arezendes
    7 years ago on Step 8
    Thanks for the walk through. I'm going to give this a try on a small paper craft project I'm planning.
    In addition to metal cans, builders flashing would seem to be an excellent source of metal. You can find it at the big box hardware stores. They sell it by the foot and it already has a nice curve to it, which would make it ideal for curved areas like your tires. Anyway, just a thought. Thanks for the good tutorial.
    xjiao
    8 years ago on Step 4
    would you think that pink or yellow foam can work too?
    jonoff
    8 years ago on Introduction
    Thanks so much for publishing this.. I'm gonna start one in the morning.
    abuabdullah
    Nice job.  I need to cut flat papers.  How would I be able to creat a creasing line within my diecut?
    Thanks
    dudemonkeys
    10 years ago on Introduction
    Could I use this to cut .002" shim stock? I'm trying to make a deck of cards with steel is the core material and the face and back of a standard rider back bicycle deck. Because I'm using pre-made faces and backs, the dimensions of the card and the curve at the corners would have to be exact. Can this method get that degree of precision?
    Rishnaidudemonkeys
    You can definitely get that degree of precision. Try making a jig using dowels of the proper radius mounted on a board at the proper locations and bend around that. Use one continuous band of steel, not multiple pieces, or you'll have to do a tad of sanding on each card. I've cut aluminum soda cans, but I've never tried it with any thickness of steel.
    dudemonkeysRishnai
    Thanks! That helps me a lot. One more question though, if I'm cutting metal would I need a press with a few tons or could a vise clamp work?
    Rishnaidudemonkeys
    A sturdy clamp could probably do the deed, if you try hard enough. I once needed a press and (carefully) jacked up my car on top of the offending object. Two-ton press right in your driveway! (I take no responsibilty if someone else tries this bonehead idea and gets crushed. I got lucky. You've been warned).
    dudemonkeysRishnai
    With this kind of weight, what would I need to use for the blades? And also, how would I join the two ends of the blade after bending it to shape?
    Rishnaidudemonkeys
    A couple of posts below this one, Mefromliny talks about cutting gaskets using industrial-weight food cans. The fasteners section of the local hardware store has some slightly thicker steel that looks promising. If you have an electric welder, you can probably gently tack the two ends of the blade, but I wouldn't try it with oxyacetelyne. If that's all you have, I imagine some careful soldering would be more effective for you.
    Sandisk1duoRishnai
    it wouldn't be two tons, you would have to balance the whole car on your jack, if you did that, then yes, close to two tons
