Homemade Gunpowder
53,019
164
20
Hello everyone!!!
Today i will show you how to make real homemade gunpowder!
It's very easy to make and requires only 3 ingredients!
So... Let's start :)
P.S. In the video i burned less then a gram of gunpowder! So be careful
Step 1: Ingredients
So...
You will need:
  1. Charcoal ( just burn down some wood or buy from a garden store ).
  2. Sulfur ( you can find sulfur in garden stores as fertilizer ).
  3. Potassium or sodium nitrate ( you can find Potassium or sodium nitrate in garden stores as fertilizer ).
  4. Scales ( i am from europe so i am using grams to measure everything, but ounces will work...)
  5. some containers, and something to crush the chemicals.
Step 2: Scaling
So the recipe is:
  1. 75% potassium or sodium nitrate
  2. 15% charcoal
  3. 10% sulfur
I am making 100g of gunpowder, so you will need:
  1. 75g potassium or sodium nitrate
  2. 15g charcoal
  3. 10g sulfur
If you are doing everything with ounces, just calculate your weight, for one ounce you will need:
  1. 0.75oz potassium or sodium nitrate
  2. 0.15oz charcoal
  3. 0.1oz sulfur
I RECOMMEND TO NOT MIX EVERYTHING UP YET!
Step 3: Crushing Things
Now you will need to crush your ingredients to powder.
Simply, get an open container, or a bowl , pick up a marker or something and crush your not - powder ingredients.
IF ALL YOUR INGREDIENTS ARE IN POWDER FORM, SKIP THIS STEP.
Step 4: Mixing Everything
Now, take a bag or something, and mix everything up!
Don't worry about sulfur pieces, it's nothing :)
Congratulations! You made your own gunpowder!
To test it, simply light a little bit of it :)
If you want to make it explode, simply put the gunpowder to sealed container, insert a fuse, and light it up :)
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    20 Discussions
    Ratuls
    3 years ago
    I have a question, does the gunpowder burn again?
    martis_ltuRatuls
    Reply 3 years ago
    No, once the reaction is over, the output products are non-flammable
    8-BitNmartis_ltu
    Reply 2 years ago
    So does that mean that you can make fireproof walls out of burning gunpowder and using the remains?
    Clark530/
    2 years ago
    You can also piss into a water bottle and let it evaporate in the sun for a few days. the end result is potassium nitrate
    GraemeM23Clark530/
    Reply 2 years ago
    You'll get potassium nitrate but it will be contaminated with urea. No idea if it would hinder the combustion of the final product though.
    Tekurious
    2 years ago
    Where is the video?
    electricman05
    2 years ago
    Thanks for the great instructable. Much simpler than all the others.
    Tekurious
    2 years ago
    cool!!!!!!??
    railroadman30
    2 years ago
    Many ways online threads explaining ways to make and collect it. Use smart and small amounts don't want feds showing up thinking your building explosives
    JoakimJ2
    2 years ago
    Does foodgrade potassium nitrate work?
    Ratuls
    3 years ago
    This gunpowder itself works like a firework, can I use it as a propellant in a gun/cannon?
    PhilS43Ratuls
    Reply 2 years ago
    It's why it's called gunpowder, I guess. You just need to confine it in something like a cardboard tube and let the gases do the rest.
    PhilS43
    2 years ago
    I thought the sulphur had to be the crystalline form. The commonly available "flowers" of sulphur doesn't work, but you can convert the flowers to crystals
    Jazz4kurt
    3 years ago
    Now how do I make nitrogen?
    hey jack
    4 years ago
    Do sulfur and potassium nitrate come together or seperate when you buy it?
    The1andonlyDanielhey jack
    Reply 3 years ago
    They come seperate, look for Stump Remover for potassium nitrite and sulfer powder for sulfur
    MarkC418
    3 years ago
    After taking a good look at the chemical reaction (2 KNO3 + S + 3 C → K2S + N2 + 3 CO2) and calculating the molar mass of the ingredients I noticed you rounded down the ratio's too much. The correct ratio's are:
    74.8% KNO3
    11.9% S
    13.3% C
    Rounding these values down can extremely affect the quality of the reaction.
    hey jack
    4 years ago
    Good instructable btw
