Homework Writing Machine
149,214
379
229
About: How to Everything.
FOLLOW US ON OUR WEBSITE :- http://www.creativitybuzz.org/
Hi guys , As per the title this is a simple project using Arduino to make Homework writing machine at your home.This machine can draw any design and write any type of fonts.You can see sharpness and perfection of writing in photos.
IF YOU LIKE THIS PROJECT PLEASE VOTE IN CONTEST (YOU CAN VOTE AT AND OF THIS PROJECT)
Step 1: Watch Youtube Video of Making Writing Machine
Here is full video of how writing machine is work on surface.If You Like This Project Please Press The Like Button.
Step 2: Disassemble DVD Writers.
First of all you need 2 DVD writers of your CPU.You can use non workable DVD writer for this project.
Take 2 DVD writers and open 5 screw on bottom of this DVD writer.
Then open bottom case of DVD writer and disconnect all circuit.
Then open Top case of DVD writer.
Step 3: Disassemble All Parts.
After this you see rectangle part of DVD writer with stepper motor on back side.
Open 2 screw on this Rectangle and remove this rectangle outside.
Repeat this process for 2nd DVD writer.
After this you have two PCs of Rectangle Part (AS per 2nd Pic.)
Step 4: Unscrew Stepper Motor
Open one screw on sliding shaft and 2 screw on stepper motor.
Disassemble stepper motor and sliding parts from one rectangle.
Remove all circuit of sliding part and cut middle part of this sliding part.
Now you have 2 PCs of plastic part.Combine both plastic object and stick with FeviQuik.
Step 5: Connection of Stepper Motor
Take female header pin (4 pin) as a picture.
Connect two stepper motor with this 4 pin female header as show in picture(In the same line).
Step 6: Make X - Axes Gantry.
Take Sunboard sheet of 10 cm length and 9 cm width.
Take other sunboard sheet and cut this type of object.
1) 3 x ( 1cm x 10cm) combine with glue.
2) 3 x ( 1cm x 10cm) combine with glue.
3) 3 x ( 1cm x 5 cm ) combine with glue.
Stick 1st part on left side of 9x10cm sunboard sheet and 2nd part on right side of 9x10cm sunboard sheet.
Place shifting part on this sunboard sheet along X axes.
And your X axes Gantry is ready.
Sick 3rd part Parallel to shifting shaft and Stick Stepper motor with X axes Gantry.
Step 7: Connect With Y - Axes Gantry.
Step 8: Connect Servo Motor.
Step 9: Flexible-nib Pen Making
Step 10: Connect Pen
Step 11: Take All Circuit
Ready your all circuit.
1) 2 PCs A4988 Stepper Motor Driver with heat sink
2)Expansion Board A4988 Driver
3)Arduino Uno R3
First of all take hit sink and stick on A4988 stepper motor Driver.
2 PCs A4988 Stepper Motor Driver connect on Expansion Board A4988 Driver module. Then this combination connect on Arduino Uno R3 (As per circuit Diagram).
Step 12: Wiring
Step 13: Benbox Softwer Configuration.
Step 14: Watch This on Youtube.
IF YOU LIKE THIS PROJECT PLEASE VOTE ! VOTE ! VOTE ! IN CONTEST.
Step 15: Any Error !
If you have any questions about this project please comment in comment section.If you made this writing machine and any error during writing please attach your writing machine pictures.I will reply very soon.
IF YOU LIKE THIS PROJECT PLEASE VOTE VOTE VOTE IN CONTEST AND PRESS LIKE BUTTON !
Arduino Contest 2017
Second Prize in the
8 People Made This Project!
  • Build a Tool Contest
  • Sweet Treats Challenge
  • Remix Contest
    Remix Contest
229 Discussions
SumanS51
8 days ago
Sir, what did you insert there...
That black things...
LoothA
Question 8 days ago on Step 15
The one which I made doesn't work properly, servo motor is working only one way. And also only one motor is running. It also runs only one way. And the other motor is getting heated. So please help me to finish this successfully. My mail id is lootte23@gmail.com
kAL_c1
10 days ago
hello sir
how can I configure this software for the first time what are the basic thing to do COM port is not showing what should I do give me link of this software and firmware
ShaikS42PremalathaS2
Reply 21 days ago
hi this is sahil did they gave any number for contacting them i too need this project can you help me out
ShaikS42
21 days ago on Step 15
I made this project as my school project but am unable to write what i want can you please help me out , i got a dead line of 29th
Adnan73
Question 6 weeks ago on Step 15
I am trying to test a sg90 servo with arduino uno example sweep, but having all the things done in a proper way, servo does not rotate. I am running the code through arduino menu options, Examples > Servo > Sweep. I am attaching an image of wiring. I just want to know that after installing arduino ide and drivers, is something more to configure for a servo to be run? Because arduino other examples are performing correctly. Guide me please where the problem is. However servo rotates well whenever it is powered by a 5v supply outside the arduino setup.
All-ThingsDIY
Question 2 months ago on Step 6
hey sir, can you please include a complete list of your parts. thanks
Sarthak1814
2 months ago
Sir I'm having a difficulty in opening this file which you gave to download in the description so please help here!!!
RGG4
2 months ago on Step 13
You didnt use codes?
AshisS9
Question 2 months ago on Step 13
If have made y axis base and x axis base of different measurements the also i will put the same as given in the configuration....Please tell me
PrinceR53
Question 3 months ago on Step 1
sir number de do sir apna
TomaszFeliks
4 months ago
I have problem with stepper motor. It's not working but servo motor working normaly. Please help me
