Hot Cat Neckpad
5,324
258
Here is a nice tutorial to make a hot cat neckpad. Heat this cat in your microwave for 3 minutes and enjoy!
Step 1: Materials
Big paper for pattern
Sewing machine
Heat resistent fabric (cotton)
Scissors
Rice or cherry pits
Funnel
Calliper
Chalk
Meter
Pins
Step 2: The Pattern
Draw on a paper 2 circles in each other with diameter of 7 and 15 ( or more) cm. (= 2.8 and 5.9 inch). You can make the outer circle bigger for a fatter cat. Draw feet, head and tail like on the picture. Cut out the pattern. Draw the pattern 2 times on your fabric and cut out.
Step 3: Sew
Pin the two pieces together with the right side facing in. Sew together but keep a small part unstitched for turning inside out. Cut out the cat.
Step 4: Filling
Turn inside out. Pull the fabric through the opening. You can use a pencil to poke the ears, feet and tail of the cat. Fill the cat with the rice of cherry pits with the funnel through the opening. Stitch the opening. Done!
Step 5: Heat
Heat the cat in your microwave and put her in your neck. Enjoy!
Sew Warm Contest
Runner Up in the
Sew Warm Contest
    • Organization Contest
    • Paper Contest
      Paper Contest
    • Weaving Challenge
      Weaving Challenge
    3 Discussions
    MicioGatta
    5 years ago on Introduction
    Totally cuteeeeeee! >^_______^< Would you pealse do add the scan of the cat pattern? >^.^< that would be great!
    vjmac
    5 years ago
    very cool!
