How to Build a French Cleat Organizing System
90,036
984
69
About: Hi I'm Linn and on my Youtube Channel I have lots of great videos about building, construction and fun projects. You can also check out my site @ http://darbinorvar.com
A French cleat system is great for organizing any wall. I'm building one for my shop, however I really believe this is an awesome solution to any space where you want things in order, no matter whether that's a craft room, office, kitchen, pantry etc...
I have a lot of different things that needed to be organized in my shop, so I decided to build a set of French cleats for the wall, and then to build a couple of different organizers to hang on the wall. In this instructable I will go over hanging the cleats as well as building the organizers.
Step 1: How French Cleats Work
French cleats work like this: You have a piece of wood with a 45 degree angle on the wall, pointing up. Then you have another 45 degree angle board that you can slip in and it stays put.
What's cool is you screw these cleats into the studs, and then you can hang things with a 45 degree wood back all across the wall without having to worry about attaching each one individually to the wall. You can attach anything to this board. A shelf, a cabinet, some kind of holder, anything. And you can move them around, change things up, do whatever you want.
Step 2: Cuts
For the French cleats, I'm cutting 4 inch strips of 3/4 inch plywood with one side at a 45 degree angle. How long you make the cleats depends on your wall!
Step 3: Planning...
Then I'm mapping out where I want them on the wall, marking out where the studs are and countersinking before drilling them into the wall. I'm making sure to use a level to get all the cleats straight.
I decided to make a grid of these cleats all over the wall, however you could certainly do whatever you find most appropriate for your setting. Perhaps you simply need one cleat on a wall, or you might need a section with a couple of cleats. I spaced out mine about 8 inches apart.
You could either leave them the color of the wood or the plywood, however I decided to paint my cleats so they blend into the background. That way, whatever I put on the cleats will "pop" more.
Step 4: Screw Organizer
Now, we have the cleats, so what's really necessary are some storage units to hang on them. First of all, I decided to build a large screw organizer box to hang on the cleat. In this box I wanted to store all of my metal hardware in little cubbies so I built one large box, and 36 tiny boxes to go inside the big one using my new box joint jig that doesn't require a dado stack (video above). I created a separate Instructable about that build here: How To Make an Organizer Box for Screws
Step 5: Holder
I needed to store miscellaneous tools and I wanted to be able to hold several things in one holder. So I built two of these, and you can use the concept and create one that fits your needs in terms of size, I built these out of 1/2 inch plywood.
I have one large back piece, measuring 12 x 9 inches, one front piece measuring 6 x 9 inches, and two side pieces 4 inches wide, cut at an angle between 12 and 6 inches.
I predrilled and secured the back to the sides, and then the sides to the front. For a bottom, I decided to use hardboard cut to size.
Also, I cut up a piece of 9 inch long french cleat board (4 inch wide with a 45 degree angle at one side.) I attached the cleat with the 45 degree angle pointing down, to create a gap for for the holder to slide onto the wall.
Step 6: Medium Box
I loved the large box so much, I decided I might as well make another, but a smaller one to hang
with a shelf or two. This one measured 16 x 12 inches with dados cut out for two shelves. To build this box I used the same technique as the large screw organizing box, so please check that out for more information on the build: How To Make an Organizer Box for Screws
Once I had the box built, I again, attached a French cleat back measuring the width of the box.
Step 7: ​Mallet Shelf
I've been meaning to find a better place to keep the mallets I build, so I decided to build a hanger
for those as well. So, I got a board, the size of my wall, and then I marked out how far apart the mallets needed to be. I drew some lines, and sawed the holes with a panel saw, since it's such a long board. I chiseling out the backs.
Then simply putting on a back, and screwing the back onto a cleat, ready to put it on the wall.
This type of holder would be perfect to make to store any hammers, mallets or similar shaped tools.
Step 8: ​Small Clamp Rack
I also wanted to fit some small clamps, so I used the same concept as the mallet hanger, however on a smaller scale and I cut it up on the bandsaw. Then attached a back, and a French cleat.
Step 9: Finishing
I sanded all the holders to remove any rough edges and then I spray painted everything white with an HVLP sprayer. You could of course leave them the color of the wood or the plywood, however I really like the fresh, clean look of the white. I also decided to paint the cleats themselves.
Step 10: Shop Vac Shelf
I also made a shelf for my small shop vac. This one of the reasons why I love this system: I want to be able to move my shop vac between my drill press and my CNC machine. So I attached a French cleat above the CNC, and then the drill press is located right below my French cleat wall. So now, I can easily move the shelf with the shop vac from one location to the other without any efforts at all, and it's off the floor and not in the way which is really cool.
Step 11: Organizing
When everything was ready I was so excited to put all the holders up. I love all the white, and it really looks more like a craft or maker space here than a woodshop really. It's so awesome how you can move things around.
And then putting on the big box. And I really like having the French cleat attached to the back of
the big box because then it won't ever fall over, so it's much more secure to the wall.
Then it was simply a matter of organizing everything and putting it up on the wall. I just think this system is awesome and this whole set up would be great for pretty much any hobby,
no matter whether you're into woodworking, electronics, or sewing, crafting, jewelry making.
Step 12: Conclusion - Watch the Video
For a much better perspective on the build and all the different parts, make sure to watch the video!
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    69 Discussions
    terrefirma
    1 year ago
    Beautiful! I still wonder how others remember where certain items are until they have used them over and over, without labeling. Is it just different brain processing?
    Doyeah
    1 year ago
    nice ible...i like the video too and btw you are talented and beautiful... :)
    DaveH127
    2 years ago
    You have a seriously organized shop. It actually looks like you have a place for pretty much everything.
    Good post. I think I want to do this, as soon as I find my walls, which are hiding behind all the other crap I keep accumulating.
    kathyh3068
    3 years ago
    You are my hero. Very inspiring.
    LarryW3
    3 years ago
    Good job, Linn, as usual. I started my first French Cleat project in my work shop, with the initial target being my pocket hole work board and one table saw cross cut sled. So far, so good. I figure I'll get all of my flatter, thinner things out of my way first, then start on the smaller hand tools and jigs. Thanks for the inspiration! Maybe I'll get brave and try some still photos soon.
    copperaxesteve000
    Reply 3 years ago on Introduction
    A long as your screws are long enough to get a good bite into a secure stud, nothing should happen until the wood gives way or you reach the shearing limit of the screw... which either way, most impressive is you getting that much weight up there in the first place.
    ark19
    3 years ago
    Great idea :)
    TonyT19
    3 years ago
    i have been trying to create this for my electric power washer. i have tried 2x4s, 2x6s, 1x6s to support this piece of equipment. The power washer always falls out the top piece of wood. i am using a long strip (80 inches roughly) screwed to the wall studs with a small (12-14 inch) support piece across the power washer. Can anyone tell me what im doing wrong?
    Phil_STonyT19
    It's called gravity.
    With that amount of timber, don't attempt a house build. I find that when all else fails, a simple loop of nylon cord works wonders. If you really want to fix it, try a Prusik loop, another example of the self-tightening fastening. A triple Prusik would support a fully grown elephant.
    Phil_S
    There used to be a commercial system called Toprail that just needed one horizontal aluminium channel fixed at high level on the wall and everything from shelf supports, cabinets, whiteboards, fire extinguishers etc would hang from it. I used when designing a new laboratory in the 80's. This relied on an angled engagement between the rail and the hanging support. Once the rail was up, you could arrange things how you liked.
    I suppose the beauty of the 45-degree support is that that heavier the load, the more tightly it is pulled in towards the wall. It also prevents the load from pulling away horizontally or verticly - a bit like a coat hook.
    Cleats come in many forms and the classic form is the marine cleat where a rope passes between two teethed, hinged jaws and once the rope catches on the teeth, more pull on the rope tightens the jaws together. Climbers rely on the cleat action to ascend ropes.
    A bit puzzled what the French had to do with it - most things starting with "French" are top shelf stuff.
    3366carlos
    3 years ago
    Very nice. Im An average guy with no way of cuting 45 deg angles.
    AntonioA103366carlos
    of you have a skill saw, there will be a wingnut to loosen that will allow the baseplate to adjust to 45 degrees relative to the blade. To make a straight cut, run the base plate along a factory edge of Plywood clamped or nailed into position.
    plecat
    A small addition might be to cut some saw kerfs in the walls of the boxes for dividers. You could then store several types of fasteners in one drawer if you don't have many of them. This would save space (and drawers!)
    I supposed you could have a set of drawers for each interest (electronics, screws, other hobbies) and store the others not in use in an inconspicuous place. Great job!!
    plecat
    If you figured this out yourself, you must have some French blood in you! :)
    jeanniel1
    Nice 'ible - easy to follow! Great for organizing, and the cleats are super strong, depending on if they are mounted to the studs or anchors. I make clay ones for hanging the murals of clay slabs or artwork that's heavy.
