How to Easily Use Key Rings
52,004
45
13
Key rings are annoying. It's a pain to open them, and sometimes they snap shut before you manage to get the key on them. Fortunately, you can solve this problem with a quarter
*Mobile users: if the video doesn't play click on "MVI 0893" and it will open.
Instructions
- Get a coin about the size of a quarter.
- Press the edge of the coin against the key ring at a 45 degree angle, near where it opens; the coin will slide under part of the key ring, lifting the end up.
- Apply pressure to the coin so that it lifts up the end of the key ring enough to slide the key on. Then slide the key on.
- Remove the coin and slide the key on the rest of the way.
Burning Questions Contest
Grand Prize in the
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Jewelry Challenge
      Jewelry Challenge
    13 Discussions
    TheHumanWhiz
    5 years ago
    I really liked how you included that link for mobile users! And the instructables is a really handy trick!.
    Ps. How do you do the link thing?!
    M3GTheHumanWhiz
    Reply 5 years ago on Introduction
    Thanks! You should be able to just tap on it (it should be orange) and it should open vimeo.
    I like your method. It holds the ring open while I slide the key on. I have used just the key in the past but too often it was difficult to open all the way and sometimes the key would pop off before I could slide it all the way on, especially with a large key. Your way is so much easier and faster. Thanks!
    wilgubeasttotalblank
    Staple removers are indeed awesome for opening up a key ring. But staple removers are slightly less ubiquitous than coins, so knowing both methods should help you level up to MacGyver status.
    M3Gwilgubeast
    Yeah, that's what I was thinking. Most people always have a couple coins with them.
    pfred2M3G
    I always have my fingernails with me, so that is what I use.
    tgrainger
    5 years ago
    By using it in the same manner they're suggesting here, but instead of having a coin in the way, your key will be in position. As that's what you're trying to fit anyway.
