How to Enable Half Stars in Itunes
27,768
51
79
Being obsessive on how i organize my thousands of songs in Itunes, I found that the wimpy 1-5 star ratings weren't cutting it. So I found a way to rate them a half. This is very useful if you like everything rated EXACTLY how you want it.
*Disclaimer... this SHOULDN'T cause problems with your Itunes. If you do everything right, it will be fine.
NEED:
1. Itunes (duh)
2. A computer (either mac OR windows, separate instructions for both)
Mac users go to step 6...
Step 1: Windows Instructions
If your computer is running windows, use this set of instructions.
If your computer is a Mac, use the OTHER instructions. (skip to step )
First off, don't have Itunes running whille you do this. You can, BUT you'll have to restart Itunes in order for this to take effect.
Just to be safe, close it anyway...
Now, find the ItunesPrefs.xml file.
Usually (in Vista) this is at
C:\Users\YOUR USERNAME HERE\AppData\Roaming\Apple Computer\iTunes
In XP, this is at
C:\Documents and Settings\YOUR USERNAME\Application Data\Apple Computer\iTunes
Replace YOUR USERNAME with your computer user name (duh)
The application data folder is usually hidden in windows so you'll have to type this in the explorer bar.
The folder looks like this-----------
Step 2: Open the .XML File
Right click on the ItunesPrefs.xml file
hit Open With,
then WordPad.
Why WordPad and not Notepad???
Notepad has a tendency to not display .XML files quite right.
You should now see this----------------------------------
Step 3: Scroll Down and Paste
Scroll down to where you see a line that reads:
<key>User Preferences</key>
<dict>
Below this line, but above the next line, type
<key>allow-half-stars</key>
<data>
dHJ1ZQ==
</data>
to be safe, just copy and paste it from this screen.
  • this "dHJ1ZQ==" means "true" in Base64.
Step 4: Check &amp; Save
Check where you have just pasted. It should look just like this now...
If it looks like that, then save this file and exit out of WordPad.
Step 5: Open Itunes
Open up your Itunes again, and you should now be able to rate things as half stars!
This also works on rating your albums.
The only thing bad about this is that you can't see the half stars on your ipod. It displays them as a whole number. But it does, however, recognize that 4.5 star songs are less than 5 star, which makes them work with the smart playlists.
Congratulations, you now have half stars.
Simply click and drag in between the regular stars to access these new stars.
For Mac users, check out step six.
Happy Rating
-MusicNinja17
***Please Rate and Comment.... thanks***
Step 6: Enabling Half Stars on the Mac
To enable half stars on a Mac, first, close Itunes.
Then, you have to open up Terminal
(Located at /Applications/Utilities....somewhere in there)
and once it's open, type in
defaults write com.apple.iTunes allow-half-stars -bool TRUE
Hit enter, and then close out of the terminal.
Then, open Itunes
Congratulations....you should have half stars!
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    79 Discussions
    thinkdunson
    2 years ago
    unfortunately, this does not work any more. with itunes 12.5.1 for windows, apple has removed this method of enabling half stars. (i haven't tested the mac version to see if the terminal method still works.)
    however, smart playlists do still take into account all previous ratings that included half stars. so the feature is clearly still in place, someone just needs to figure out how to get at it.
    gryphynthinkdunson
    Reply 2 years ago
    This still works (thank goodness!) for v12.5.1.21. Read this page.
    http://www.technipages.com/itunes-enable-half-star-ratings
    JoelE15
    3 years ago
    PLEASE HELP
    Thanks for posting this. However, I have since found that I don't like the 1/2 stars because I mis-rate far too often. I want to go back to the whole star system. I planned on just reversing what you posted but my itunesprefs file not looks different. I fear I'm going to cause havoc and loose my years of organizing.
    My itunesprefs now looks like this:
    </dict>
    <dict>
    <key>0000000000000000</key>
    <data>
    ?? QUESTION ?? How do I get back to the original?
    Thanks so much....
    TobyP9
    3 years ago
    I love you a bit; I really do.
    It does not extend into the auto / smart playlists sadly, which makes me sad, but that's not you that's Apple!
    cxvxdanielTobyP9
    Reply 3 years ago
    I've found that half star ratings do work with smart playlists, just not in the way you'd think. You can't select half star ratings from the smart playlist screen but the smart playlist generator's rules of logic still apply. An input of "greater than 3" will return songs with ratings of 3.5, 4, 4.5, and 5. An input of "in the range of 4 and 5" will return songs with the ratings of 4, 4.5, and 5. Inputting "greater than 4" AND "less than 5" will returns songs with the rating of 4.5. You've just got to learn how to work around it!
    jbowe
    3 years ago
    awesome, thank you! I was so angry when itunes 12 took away all of my half star ratings!
    ~works on iTunes 12 for Mac~
    thinkdunson
    6 years ago on Introduction
    for Windows 7 (probably for others as well, but i have 7, so that's all i can confirm) the appdata folder is hidden.
    click the start menu and type %appdata% into the search field (including the two percent signs) and then hit enter. that'll open your Roaming folder.
    then just continue with the instructions from there. i tried it and it works.
    thanks for the ible, musicninja.
    thinkdunsonthinkdunson
    Reply 4 years ago
    Just used again and it still works in Mac OS X.10 Yosemite with iTunes 12.
    odixon-luinenburg
    8 years ago on Step 6
    Just so you know, this still works in itunes 10.
    This is amazing, thankyou. I never thought it would be this easy.
    Now to see how it translates onto my iphone...
    JudahCris
    Awesome Guide!!!
    rating all my songs now...
    Album 4 of 76
