How to Fishtail Braid
1,506
12
This is simple cute hairstyle to do that takes about 5-10 minutes depending on how long or thick the hair is. Materials needed: Hair tie (preferably small elastic one so that it's less visible) Bobby pins Hair brush
Supplies:
Step 1: Seperate
*Works on dry or damp hair* Brush out the hair completely so that there is no tangles. Separate the hair into two equal sections as shown
Step 2: Cross Over
Take a section of hair from behind a larger section and cross it over the top. Combine it with the other section of hair as shown. Then do the same for the other side, crossing it over the first strand and adding it to the opposite section
Step 3: Keep Going
Continue crossing and adding. Make sure to hold the hair tightly as you do for a better looking result
Step 4: Tie It Up
When you reach the bottom or when you run out of hair to add and cross over, tie with a hair tie. Secure any loose strands with bobby pins if needed. Hair spray lightly for a stronger hold :)
    • Classroom Science Contest
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
