How to Fix Digital Calipers
29,018
17
19
About: My name is Zach Sousa and I'm a Canadian highschool student that has a passion for making.
In this instructable I will show you how to fix calipers that show a false value. It's worked for me and some other people and it should work for you.
The reason that it shows incorrect values is because is uses capacitance to measure the value and the circuit board van sometimes touch the metal.
Parts and tools:
Broken calipers
Tape
Small Phillips head screw driver
Supplies:
Step 1: Take Off Label
On the back of your calipers there should be a sticker that says metr. ISO take that sticker off and you will find screws under it.
Step 2: Take Off Screws
Unscrew the 4 screws then take the front off of the calipers and turn it around. You should see a circuit board that looks like this.
Step 3: Tape
Put a small piece of tape over the circuit board I used masking tape but scotch tape also works.
Step 4: Screw Screws
Screw the screws that you removed earlier and place the label on I left the label off because it didn't stick to the back.
Step 5: Thanks!
Thanks for viewing this instructable! I hope this worked for you!
2 People Made This Project!
  • Classroom Science Contest
  • Arduino Contest 2019
19 Discussions
lmoraisvieira
4 days ago
Worked likie a charm!!!!!!!!!!!!!!!!! AMAZING!!!!!!!!!!!!!
Excrubulent
12 months ago
Hey, mine was good for a year, then went nuts past about 100mm. This fix worked!
One issue I had though, my sticker looked a lot like it was simply part of the metal, and I couldn't see any edges where I could remove it, so I thought mine was different. That might be worth mentioning - the sticker may look metallic, but still try to remove it.
I ended up cutting off a fair bit of plastic around the sides looking for how it was fastened, before my efforts finally dislodged the sticker and I realised my mistake. Still works fine though, now it just looks a little "customised".
Heisennberg
Question 1 year ago on Step 3
Hey, Where did you put the tape exactly, and how much did you use? This particular photo actually does not help at all :( Cheers
GregO29
1 year ago
I am a little confused... Step 3: tape, picture is blurry, I can't see any tape. My calipers are composite (non-metalic), so where do I tape them to make it work? I tried several different areas of tape, including the whole thing, but it still reads crappy with lots of errors.
souravg009
1 year ago
WOW!! it did worked. though error is getting accumulated. any suggestion?
mrunmoys
2 years ago
Thanks a bunch. yuhuuuu! My calipers works now !!!
CarlosF86
2 years ago
it worked for me thanks
Mainul
2 years ago
I was frustrated with two of my calipers bought from China.
Both of them are now working perfectly simply applying small pieces of scotch
tape as described above. Thanks a lot.
razvanesq80
2 years ago
WOW!! So simple and it works!!! My caliper never displayed correctly past 50mm, now working spot on the hole length! Thank you, I was just about to order a new one!
Way2go
2 years ago
Silverline calipers rescued and working, after using this fix. I did have to remember to put back 2 rubber blades at the ends of the housing which appear to wipe the scale. The hardest part of the fix was sticking the label back on. Good tutorial!
espeaker
2 years ago
Well I tried the fix maybe someone forgot a step. When I took my calpers apart
I found two (2) copper strips. both a mess lots of corrosion clean the copper up and guess what the calpers with fresh battery SR44W back in service.
ecominimalnick
3 years ago
Brilliant! Sealey calipers that have always been erratic then stopped working at all. Now fine.
Thanks
Norkator
3 years ago
I bought German made caliber which was messing up readings out of the box, I try cleaning it up first and oiling the rail but anything did not work. Then I found this article, did the trick and it works perfectly. It's like whole different caliber now. Now it always comes back to zero. Thank you for this tutorial!
JohnE50
3 years ago
Worked great, Thanks
AaronH10
3 years ago on Introduction
It works! Brand new calipers from Digikey - had an incrementing offset out of the box. I did this fix and it works perfectly! Thank you so much.
Dimitrios
4 years ago on Introduction
I only logged in today to say thank you! It was bugging me for a couple of days, I hardly used mine, always kept nice in the box. Thinking it was the battery, bought a new one, same problem, numbers go crazy. Your fix did the trick! Thanks!
switch62
I now have a properly working caliper. Been broken for over 4 years.
I put the tape over the 2 screws on the white part of the circuit board, they sit above metal (when it's put back together). The green part of the circuit board sits over the plastic scale and can't short to any metal.
Never thought that it might be the screws shorting to the metal.
Thanks.
