How to Install a Horn on a Bike
6,784
13
I am installing a wolo low tone motorcycle horn on my Diamondback trace.
Step 1: Find a Place to Mount Your Horn
find a solid place to mount your horn and make sure it's not in the way of any moving parts.
Step 2: Mount Your Switch
I mounted my switch using the reflector as a mounting point and secured it with the reflector's screw.
Step 3: Power Source
I used a 10 AA battery holder. this was then put into a pouch under the seat.
Step 4: Run Your Wiring
I cut the connectors off an old DC charging cord and used that.
Step 5: Test Your Horn
make sure the horn doesn't touch anywhere besides it's mounting point; the horn will not work properly if it is touching the frame.
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    Crucio
    2 years ago
    Nice job. I would suggest that if you're going to use AA batteries, to use rechargeables.
