How to Make a Cheap Knex Spool Stand
518
7
8
Step1- Connect the structure as shown in the picture.
You will need:
-4 blue connectors
-8 purple connectors
-5 white connectors
-2 orange connectors
-6 yellow connectors
-5 red sticks
-10 yellow sticks
-10 blue sticks
Step2- Print some hollow cylinders to make the spool rotate smoothly
Step3- Place the spools on the top red sticks. That is where the filament will rest on.
Step4- add some rubber pads to the bottom to keep the filament holder in place
Step 1:
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    • Classroom Science Contest
    8 Discussions
    mark429
    4 years ago
    Not exactly the same but 100% inspired by your instructable! Thanks for the great idea. I modified mine to be a "quick change" style Cheers!
    simpson1991mark429
    Reply 2 years ago
    Thank you, I took a picture look above your comment :) I added some rolls for the spool and a shell to reach a higher position :)
    simpson1991simpson1991
    Reply 2 years ago
    Okay the picture is further down now, and wheel not shell
    aburton8mark429
    Reply 4 years ago on Introduction
    http://www.thingiverse.com/thing:389829
    Here, I made the spools to make the filament turn more smoothly. You can change the length of the spool, but the hole inside is a perfect size for the KNEX so just change the z-axis to make it longer. Or just print 2 like what I did.
    aburton8mark429
    HAHA Nice! I found out that if you use little spools or something between the filament roll and Knex the filament roll will turn more smoothly. When I didn't have the something between the two, my prints were less accurate since my printer had to tug more on the filament. Thanks for sharing a picture, your design looks really cool and sturdy!!!
    simpson1991
    2 years ago
    I took yours mark429 and it is working fine :)
    dan8cat
    5 years ago on Introduction
    Finally a use for all my old Knex. This is one of the why didn't I think of that moments! Nice 'ible btw
