How to Make a Hermit Crab Habitat
112,354
34
25
About: I like to make stuff, and I enjoy hermit crabs!
Hermit Crabs are very cool, and social creatures. In order for them to survive, you have to really simulate their "Natural Habitat."
Supplies:
Step 1: Simple Supplies
Some basic supplies you will need is:
bedding: play sand, Eco earth, Jungle Bedding
Salt Water: Oceanic sea salt mix, Distilled or spring water
Fresh water: bottled spring water, or distilled water
Bowls:You will need three bowls; One for fresh water, one for salt water, and one for food
Heat Source: Light, Under Tank heater
Hiding spot: coconut hut, driftwood pine and ceder is poisonous to hermit crabs!
Humidity: humidifier, or mister
Tank: Ten gallon glass aquarium MINIMUM
Step 2: Laying Down Substrate
Let's start by putting down substrate. Here is a good list of substrates.
Jungle Bedding (pet stores)
Hermit Soil (Pet stores)
Play sand (Home Depot.) (This is used in childrens' sand boxes. It's found on the beach.)
Bad Substrates.
Calci sand
Gravel
wood bark (Usually Pine or cedar, which is poisonous to hermit crabs.)
***ASK ME IF YOU HAVE ANY OTHER IDEAS FOR SUBSTRATES***
Play Sand, and Jungle Bedding are BEST SUBSTRATES!!!
*** REMEMBER: Your substrate MUST be atleast 3 times deeper than your largest crab.***
This is because they have to go through a process called "Molting". Thats when your crab will bury under ground to shed his skin. You should give him some healthy foods, because this process can take MONTHS.
Step 3: Salt Water
Use "Oceanic Natural Sea Salt Mix" to create your salt water. DO NOT use table salt! it contains Idonide that can be harmful to hermit crabs. Also use bottled spring water, or distilled water because of the same reason. Tap water contains idonide and other chemicals.
Mix 1 1/2 tsp of sea salt with one cup (8 oz.) of water.
Mix 5 cups sea salt, with 1 gallon of water.
Step 4: Hermit Crab Diets
Hermit crabs eat a verity of foods! And it's good to vary between them!
Most fruits and veggies are safe, Only if they are organic and do not contain any spices or chemicals.
Here is a list of safe foods:
Organic popcorn
raisins
pineapple
apple
banana
orange
carrots
lettuce
strawberries
Safe Commercial Diets:
FMR Hermit Crab Treat
HBH Verity Bites
Hermit Crab Cookies
I would have the fruits and veggies as a main course, and commercial diets as sides.
Step 5: Finishing Up
Now just add freshwater, other climbing toys, and  hermit crabs! make sure when you buy your crabs, get one thats active and NOT in a painted shell! Painted shells can be toxic to hermit crabs, as the paint may contain led.
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    25 Discussions
    ZoeR21
    1 day ago on Step 4
    Are mineral blocks also considered food?
    Brandi-lynnB
    Tip 7 months ago
    Although this is a super old thread, I'm Sharing some easy set up guides. Also, you can become a member of the "Hermit Crab Owners" group on Facebook
    Also, hermit crabs have modified gills. They rely on humidity to breathe. They really are "hands off" pets. it's okay to buy crabs in painted shells.. just have unpainted shells for them to change into :)
    Screenshot_20181015-225302.pngScreenshot_20181015-230046.pngScreenshot_20181015-225641.pngScreenshot_20181015-230126.pngScreenshot_20181015-225955.pngScreenshot_20181015-225353.pngScreenshot_20181015-230137.pngScreenshot_20181015-230004.png
    HermitGuy101JohnJY
    it says heat. and the salt water helps their exo skeleton during molting. In other words, if you don't have salt water, they will die!
    TJS48HermitGuy101
    Reply 2 years ago
    ive never once put saltwater in my crab cage and they molt just fine
    10462TJS48
    Reply 1 year ago
    they like salt water to bathe in.
    MinaMonster2000
    2 years ago
    1 problem how do you make it with out buying stuff useing household stuff.
    sandovalm04
    2 years ago
    Hmm...Class pet is good but even better!
    641491
    3 years ago
    yes!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    641491
    3 years ago
    KittyK12
    3 years ago
    I'm not sure what this products directions are, but the above amounts do not make sense. Please make sure to read each package for mixing directions.
    rjoos
    5 years ago on Introduction
    If you are just looking for products to make this whole process a lot easier, I would totally check out underwaterislands.com. They have these cool underwater habitats for crabs so you don't have to leave your tanks half filled.
    zhockins
    3 years ago
    I really need help with my 10 gallon hermit crab tank I have the freshwater,rocks,sticks for climbing and even a background they can climb on,I also have a food and a freshwater bowl. Is this the good stuff
    JasonC75
    3 years ago on Introduction
    this looks like home of a hermit crab dose it look like a hermit home
    Nasubi77
    7 years ago on Step 3
    1.5 tsp per cup would be HALF a cup per gallon, not 5 cups per gallon.
    tlutchman
    7 years ago on Introduction
    where did you get the 10 gallon tank???
    I live in canada and i can't find any. :(
    vampierwolf
    can you use sea salt like goumet saslt if it doesnt contain any iodine?
