Quick Release Survival Bracelet/Quick Release Paracord Bracelet
189,470
842
48
About: I went to school for Architectural Engineering for two years and ended up getting a degree in culinary arts (long story). I have great passion in crafting, fixing, or building stuff!!! Whether it's wood work...
Please watch the video below to understand how this bracelet works. It's very cool!.
Throughout this tutorial I will demonstrate how to make a "Quick Release Survival Bracelet". ParaVival is my new gear company, and it's also short for paracord-survival. This particular bracelet comes with up to 15 feet of paracord and can completely unraveled in under 20 seconds, perfect for any emergency or survival situation.
I also run a small boutique called Rusticlub
Thanks!
Step 1: What You'll Need
What You'll Need: Check out our Paracord Kits
-We use a small piece of wood about 3' x 1'. Plywood works great for this. We simply screw an eyehook into it so we can attach the shackle to it while working. You can see the eye hook at the top of the picture below. Again, this is optional. You can do this by simply holding it it your hands.
Step 2: Step 1: Measuring Your Wrist
1. Take a cord and wrap it around your wrist where your bracelet would be. Make sure it's snug, and not too loose. We take this into consideration, your bracelet will not be tight!
2. With a marker, make a line across the cord like shown in part 2 of the diagram.
3. I’ve darkened the lines in Photoshop so you can see a better example here in part 3 of the diagram.
4. Now lay your cord out straight on a table and measure from line to line.
Step 3: Step 2: Starting Off With a Cow Hitch
  • The numbers below correspond to the numbers in the diagram.
  • Start by finding the middle point of your cord by taking both ends and placing them together and then following the cord down to the loop at the end.
  1. Take the middle point, or the loop if you will, and put it through your Stainless Steal Shackle
  2. Find your two ends and prepair to place them through the loop.
  3. Place the two loose ends through your loop on the other side of the shackle.
  4. This is what it should look like.
Step 4: Step 3: Creating Your Inner Cords and Measuring for Wrist Size
  1. Form two loops using your fingers and bring the cord down roughly 7-8 inches.
  2. Separate the cords to form to hanging loops like shown in part 2 of the diagram.
  3. Bring them closer together so you can get an accurate measurement. Lay a tape measure or ruler down next to your cords and prep for measurement. You want to measure from the middle of the shackle bolt to the end of the loops which you have taped at the bottom. **NOTE: You must add 1" to your wrist measurement. For example, the persons wrist for the bracelet below was around 8 inches, so we are measuring this around 9 inches to end up with the correct sizing.
Step 5: Step 4: Temporary Step: Taping Ends to Insure Accurate Measurement and Stable Weaving
  1. Tape off your ends after measuring correctly.
  2. At this point you are ready to start your braiding process.
Step 6: Step 5: Stabilizing the Top of Your Bracelet to Begin Braiding. Essential Step in Overall Outcome of Bracelet.
-Make sure this is nice and tight when you begin braiding.
  1. Take your left cord and lay it over the inner cords.
  2. Wrap the same cord around the back of the inner cords and back onto the left side.
-It should look like it does in part 2 of the diagram.
-You are now ready to start your first Gator braid.
Step 7: Step 6: Completing Your First Gator Braid.
-Now theres a lot to take in here so take your time and follow the steps 1 by 1.
-Remember the numbers below correspond to the numbers in the diagram below.
-The arrows in the diagram show whether the cords should be going over or under certain other cords. Follow them closely.
  1. Take your left cord (which you just wrapped over and around back to the left side) and go over "inner cord 1" and under "inner cord 2".
  2. Take your right cord and thread it under the cord you just brought over.
  3. Now thread the same right cord over the "inner cord 2" and under the "inner cord 1".
  4. Now with that same cord, thread it under and through the loop which was created. Remember to use the diagram below to help you. It is very clear and shows you where your cord should go.
  5. This is what the braid should look like before tightening.
  6. Push up with your finger so it's nice and tight against the cow hitch/shackle.
Step 8: Step 6: Completing Your Second Braid.
  1. Take your right cord and bring it under the "2nd inner cord" and over the"1st inner cord".
  2. Take your left cord and place it over the right cord which you just brought over.
  3. Continue the left cord under the "1st inner cord" and over the "2nd inner cord".
  4. Continue the same cord over and through the loop as shown in part 4 of the diagram.
  5. This is what it should look like before tightening.
  6. A finished, tightened Gator stitch.
Step 9: Step 7: This May Occur
  1. While braiding your bracelet you may end up with a gap between your shackle and your braids.
  2. The numbers in the diagram correspond to the numbers below.
  3. This is what it will look like it if happens.
  4. Hold the two inner individual cords of each of the "inner cords" and push up on the braid. It will slide back up into place.
Step 10: Step 8: Weaving Down to the End
  • The numbers in the diagram correspond to the numbers below.
  1. Once you are a good portion of the way down, you can undo the tape you applied.
  2. This is a close up of what your brads should look like.
  3. Braid all the way down until you have 1/2" left.
Step 11: Step 9: Cutting and Melting the Ends
  1. Place yut scissors about an 1/8" away from the bracelet and snit the cord on either side.
  2. With your lighter melt the ends so the cord doesn't fray. Once you pull the lighter away, your going to want to use your hands (we suggest dipping you fingers in water or licking them first to avoid a burn) to smoothen over the ends creating a mushroom head type shape on each end of the cord. This allows the cords to lock into place so they don't slide out.
  3. This is what it should look like. Make sure to make this the side of the bracelet which is against your wrist so the ends are hidden.
Step 12: Putting It On
  1. Slide the 2 loops onto the side of the shackle which has the threads on it.
  2. Put your shackle bolt on and tighten.
  3. Pull the loops back over onto the shackle bolt.
Step 13: And You're Done!
Check out my online boutique for awesome hand-crafted products: Rusticlub
  • Epilog X Contest
    Epilog X Contest
  • Organization Contest
  • Sweet Treats Challenge
48 Discussions
irishwhistle
Question 10 months ago
I dunno if you're still answering questions about this but I can't find the answer anywhere... once you use it, how do you re-tie it if the ends have been widened? Or is it meant to be a strictly emergency item, meaning it's there if you need it and once used you can't make it into a bracelet again?
1 answer
AnthValeirishwhistle
Answer 10 months ago
Hey,
I would snip the ends and re-melt them so they are a bit thinner and re-weave the bracelet. It's going to a bit more challenging the second time around without any of that extra cordage to work with. That being said, it is pretty much an emergency thing, yes. But it's not impossible to re-weave it after it's deployed.
Best of luck.
Anthony
victorparedes
1 year ago
Are there any adjustment's that need to be made for a side release buckle like this? (1 & 3/4 in. long)
treymartin82
3 years ago
I made it! This was really easy once I got the hang of the weave. For mine I didn't cut and burn the ends but rather ran them straight down the inside of the middle. I can't wait to make this again!
15, 11:23 AM.jpg
tabbas1
3 years ago
This was my first ever paracord project and this made it an extremely easy project. Couldn't be happier.
gman47
4 years ago
do u know about trailblazer survival products
hms1997
5 years ago
I finally got around to making one but with a side release buckle. Instead of measuring an inch larger, I did half an inch larger. It was still too big so I had to soak it in water overnight. I think I ended up with 2-4ft extra cord (I haven't measured yet) on my 7-7 1/2 inch bracelet. I'll post a picture of it later.
hms1997AnthVale
Reply 4 years ago on Introduction
I had completely forgotten about it. I'll try to upload one this weekend or next.
paracordry
5 years ago
I tried it doing the braid on the same side instead
As a combat veteran, and former member of a USASOC tactical airborne Co, I can actually vouch for this guy and back him up, from having had actual training on WHY we use what we use, etc. I also went digging around and found a link that kind of breaks down what he's saying into a more civilian-friendly explanation, including a link to buy some of the real stuff at a higher price point than he's charging, all things considered: http://www.paravival.com/the-blog/what-is-550-cord/
AnthValePTHFNDR4LIFE
Reply 5 years ago on Introduction
I'm sure it can be done. But it may or may not affect the quick release aspect of it. The cow hitch is the center of all the cord. So that is where both the colors would meet up. So I guess you could fuse them together and make a cow hitch at the point where you melted the two colors together? Or maybe you could just bring both cords through and braid over them and eliminate the cow hitch.
Anthony
Melvin71
this was a great project and worked out well the only thing I had to figure out was that you keep doing the first braid then second, first then second which you didn't really specify or just missed it but overall nice work.
AnthValeteufelaffe
Reply 6 years ago on Introduction
I'm sorry it's actually a 3/16th size shackle. I guess they measure it by the diameter of the metal, not the width of the shackle itself.
AnthValeteufelaffe
Its more of a preference but I use a 1" shackle. You can use 1 size bigger or one size smaller. I wouldn't go much more than that in either direction.
Anthony
