How to Make a Watermelon Basket
110,333
79
20
About: Ribbon and bows one-stop shopping resources. Affordable prices & great quality. We ship worldwide. Check out dozens of free tutorials.
Great for parties, school picnics...
Supplies:
Step 1: What You Need
Watermelon, a thin bladed knife, a melon baller, an icecream scoop, a marker, other fruits.
Step 2: Mark
the top of the melon as shown
Step 3: With
a long, thin bladed knife, cut out the top of the watermelon, leave the center as handle. Cut the handle to wave shape.
Step 4: Use
the melon baller to scoop the flesh out.
Step 5: Now
you can use a icecream scoop to scrap the inside walls of the watermelon clean
Step 6: If You Like,
cut the handle so it waves a little bit more. Mix other melon balls or fruits with watermelon balls then put them into the basket.
Many thanks to williamgeorge for the tip below.
I just read your instructions for making a watermelon basket filled with fruit. I've made watermelon baskets and one of the problems I've encountered is liquid from the fruits collecting in the bottom of the "basket" which makes the fruit soggy. I corrected this problem with the last basket I made by putting "drainage" holes in the bottom of the watermelon after hollowing it out and before filling with the fruit. I then put the basket in a large oval roasting pan filled with ice cubes (to keep the fruit cold), and the water from the fruit drained into the pan along with the melting ice. This kept the fruit in the basket from getting soggy. Thought you might be able to use this idea.
Step 7: More Instructions
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    20 Discussions
    superitchy
    9 years ago on Introduction
    My father used to do this for all of our Fourth of July parties. Once he even made a whale! I don't quite know how to explain how he did it though, but it wasn't too difficult.
    gamertj
    10 years ago on Introduction
    this is so easy ive done these all the time in my high school culinary class but i never have the materials to do it at home lol
    EverDave
    I've been making watermelon carved fruit salads for family event since the 70's. ALWAYS a big WOW! Add rum, or not, depending on audience ;) I always cut a sawtooth pattern on the edges with a knife, until I recently bought a "V" fruit cutter that gives me a much more uniform sawtooth than I could ever achieve manually, with a knife. Adds a touch of sophistication...
    EverDaveEverDave
    P.S. I carve the wqatermelon as HipGirl does, then cut out the sawtooth pattern on the edge. You need a nice long knife to cut the basic form, then a finer knife (or tool) to aooly the sawtooth edge. Extra time, but the presentation value is worth it (IMHO).
    williamgeorge
    "I just read your instructions for making a watermelon basket filled with fruit. I've made watermelon baskets and one of the problems I've encountered is liquid from the fruits collecting in the bottom of the "basket" which makes the fruit soggy. I corrected this problem with the last basket I made by putting "drainage" holes in the bottom of the watermelon after hollowing it out and before filling with the fruit. I then put the basket in a large oval roasting pan filled with ice cubes (to keep the fruit cold), and the water from the fruit drained into the pan along with the melting ice. This kept the fruit in the basket from getting soggy. Thought you might be able to use this idea.
    williamgeorge
    Guaranteed ROI
    canida
    It looks good! I always like to add fresh herbs (mint, basil, etc) to my fruit salads, and the green watermelon rind would really bring out the hints of color.
    SondraC
    This is not original, and can be found on wikiHow. The original and many other watermelon carvings are found on watermelon.org
    canidaSondraC
    SondraC, plagiarism is a serious charge, and completely unfounded in this case -- hipgirl's pictures and descriptions are her own.
    Watermelon carving is a classic idea that no one can claim as original, though individuals can put their personal stamp on the broader concept. Even if a similar basket had already been demonstrated on Instructables, this one would also be welcome - part of the ethos of Instructables is learning the same idea or technique from several different teachers, as they will all explain things slightly differently, and add their own personal twist. There's no single "right" way to do things.
    In the future, please refrain from leaving comments like the one above, as they are neither positive nor constructive, and as such violate our "be nice" policy. If you do ever come across evidence of plagiarized work, you can PM me directly with the information.
    hipgirlSondraC
    Wow. Thanks for the tip. Here is the page:
    http://www.watermelon.org/watermelon_carving.asp
    Right the idea is not original. I saw it at a party and tried to make one myself and recorded the steps. The instructions are original enough though. I made them from scratch with step by step pictures.
    And I think this one is the simplest and doable for a busy mom like me. I made my first one in 25 minutes.
    Thanks.
    Michelle
    Bartboyhipgirl
    you're welcome, oh, and if you changed your avatar, people will think much more of you, it is a small step, but it looks unprofessional just having a blank face as it.
    hipgirlBartboy
    Thanks for the suggestion. Never thought about that. Just uploaded the ribbon ladybug I made. Thanks.
    noxvox
    Adorable! Even though I don't like watermelon, I'll still have to make this. Very ingenious.
