How to Make Invisible Ink
Follow all the steps in this instructable do that you do your invisible ink correctly. Have FUN!!!:):):):) Pls VOTE!!! Thx
Step 1: Step 1
Gather up all materials needed for this instructable. Half of a lemon Couple drops of water Q-tip Small bowl Piece of paper Heat lamp
Step 2: Step 2
Squeeze as much lemon juice into the small bowl as possible. And then add a few drops of water to the bowl with lemon juice in it. Swirl around a little bit.
Step 3: Step 3
Dip your Q-tip into the lemon juice solution and write what you would like onto the paper. Try not to dip after each letter because this will make the letters very wet. After your secret message has had at least 30 min to dry you may advance to the final step.
Step 4: Step 4
After your message has dried get your heat lamp and place right over message for about 10 sec, make sure your paper doesn't catch on FIRE!!!!!:):):):)
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
