How To.. Make a Magic Ping Pong Table
7,171
75
This is how we made our first magic ping pong table! It's a boardroom table that can easily be turned into a ping pong table! We hope you enjoy!
Supplies:
Step 1: ​First You Need Your Legs and Base! We Have Used Pine for Ours But Its Really a Matter of Personal Taste
Step 2: Then, Your Table Top! We Have Used Redwood Ply
Step 3: Collect Your Tools and Materials..And We Can Begin!
Step 4: First, We Made the Base..Using a Saw and Chisel, We Created a Tenon and Mortise Joint to Connect the Legs to the Base of the Table..
Step 5: To Ensure the Fit, We Did a Dry Run
Step 6: Once We Were Happy With It, We Glued It in Place and Clamped It Together
Step 7: We Wanted Our Table to Be Moved Easily, But to Also Be Secure When in Place.. So We Added Castors
Step 8: As the Table Top Needs to Rotate, We Added a Support Beam in One Corner, Where There Would Be a Lot of Pressure on the Base..
Step 9: We Also Added 2 Beams of Pine to Support the Table Top. This Is Also Where We Will Later Place the Spinning Mechanism..
Step 10: We Used a 'Lazy Susan' to Make Our Top Spin.. This Meant, a Lot of Measuring to Ensure a Precise Fit!
Step 11: We Used a Spare Piece of Ply to Test Out Our Placement..Tested, and Made a Few Adjustments..
Step 12: Then, When We Were Sure It Was Right, We Tested It Out!
Step 13: Now for the Real Thing! We Cut Two Pieces of Our Lovely Ply..
Step 14: We Added Self Supporting Table Hinges, to Keep Them Together and Create Our Double Sides
Step 15: We Stained the Legs..
Step 16: And on the Top, a Ping Pong Stripe!
Step 17: We Added a White Wash.. and We Are Almost Done!
Step 18: This Is Our Finished Product in Action!
Step 19: And There You Have It! a Board Room Table That Turns Into a Ping Pong Table!
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    2 Discussions
    WestleyTwain
    3 years ago
    Could you please explain how to buy/install the hinges as well as where to put the pivot point? I'm having problems planning my build.
