How to Rearrange Pinterest Pins
71,627
6
18
About: Field Guide for the Millennial Man
In this video I'll show you how to rearrange pins within a Pinterest board.  It's kind of a pain but it can be done if your one of those super organized types of people.  I think Pinterest is a great way of organizing things you like on the internet but I have noticed some major issues with the site over the past few months.  For example I have not been able to create new pins for over a month now.  I hope this problem gets resolved soon.
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • Arduino Contest 2019
    18 Discussions
    DonnaH36
    3 years ago on Introduction
    Awesome. Thanks for your help, very much appreciated :)
    Pin4Ever is an extension I use to rearrange my pins. It's not perfect, as it only works with Firefox and no other browser, and sometimes a few of my pins disappear (and they might or might not reappear later in the wrong spot), but it's still the best option. I've already tried moving pins with the Move button on Pinterest, and there seems to be a limit of 50 pins that you can move each day. At that rate, it would take me DAYS to rearrange some of my boards. (And for other people with THOUSANDS of pins on one board, it would take them WEEKS, maybe even MONTHS.) Also, I don't like cloning the pins because then I lose the likes and repins if I delete the old ones.
    Wookbert
    5 years ago on Introduction
    A different method, which does the same, but has the advantage that one doesn't have to scroll through the list boards to pick first the Temp board and then the original board again (as described herein), is the following:
    1. Click the red Pin it button of the pin which you want to move to the top. The "Repin a pin" dialogue appears, with the board which you’re currently in being already selected. Click "Pin it". Close the appearing "Repinned" confirmation window through the X icon in the upper right corner (or simply wait for the dialogue to close automatically after approx. 8 seconds).
    You have now created created a clone of the pin, whereas the clone appears at the very top.
    2. Delete the old pin by clicking the "Edit" pencil button of the old pin (if you didn't scroll, it should be very close to its old position, it slightly moves though, as the pins are pushed downward due to the clone pin at the top) and click "Delete Pin" in the appearing dialogue. Confirm the deletion.
    3. Done!
    I personally find this a bit more handy...
    BalbirS1Wookbert
    Reply 3 years ago on Introduction
    If you don't mind loosing your likes and re-pin #'s like myself who's still new to Pinterest, then this certainly is the way to go. Thanks!
    ColorExpertWookbert
    Reply 5 years ago on Introduction
    Yes, that is a bit simpler but you lose your likes and repin #. By creating a temp board to do the moving that information stays intact.
    feekathy
    4 years ago on Introduction
    Thanks Big Nate, its 2015 and they still don't have that button so thanks to you I can re-arrange my boards.
    rose33090
    This video was very helpful to me, being new to Pinterest. Thanks for taking the time to create it.
    sunlitweb
    I used to work at a job where I had visibility about how databases are structured. Pinterest is a hierarchy. It is like windows explorer with those nested folders. From your view, your Pinterest account is the top folder. But in reality there are layers above it you never see. Every time you move a board, there has to be a corresponding change of database address. That info and confirmation tracks back through levels above your account to the database. When we finally were able to move boards, it created a new "layer of complexity" for the database. Moving pins in the millions each day would multiply the complexity exponentially for Pinterest. Far more than most websites have. I personally do not expect it, given that every layer of complexity adds the risk of system failure.
    sunlitwebsunlitweb
    Reply 4 years ago on Introduction
    I'm sorry. I forgot to add that the ideas all of you have about moving pins in a board are very good. I concur with them. And I sincerely hope a day will come when we can move pins on our boards. But until then, your ideas will work awesomely.
    NikiK
    I'm just going to move everything to the temp in the order I want, then delete the original board and rename the new board. Thanks for the tip that got me there :)
    mdstoney
    Easier than this. Select "Move Pins" button. Check box of pic you want #1. Check to move it in the same board. This pic is now #1. To edit the whole board, you would need to stragetically plan the order of pins and move them in reverse order, i.e. pin you want last gets moved first.
    agnes.mina
    They just added the feature! There is now a "Move Pins" button next to the "Edit Board" button when you have a specif board open! You click it and choose "Move" and oh wait, that helps you move it to a different board. 2 years later we are still waiting for a drag-and-drop rearrange feature for pins. We know they can do it - they did it for boards, didn't they? What is their angle???
    agnes.minaagnes.mina
    But hey, at least you can use this new "move" feature to cut out the Temp board this video suggest by sending a pin to the front of the board by "moving" it to its original board...
    Awesome! It was the first one that came up and told me EXACTLY what I wanted to know! Whewww!! Thank you!
    That was a really well done and helpful video. Maybe you can help me with a different problem. I accidentally pin things to the wrong board. what is the best way to send a pin from one board to another? right now I'm pinning them to the correct board then deleting them from the incorrect board.
    rchassereau
    Great video! I figured I'd share that I have found a third party tool that allows you to rearrange your pins (it does have limited functionality). The tool is called Pin4Ever and it's free version could help rearrange the pins (I think it works with firefox only). I have a chrome extension that allows you to rearrange your boards alphabetically with one click (made it for a family member). If anyone is a neat freak, and wants to rearrange boards feel free to give it whirl. My extension can be found at the chrome web store, it's called "Pinterest Sort". Good Luck
