How to Recycle HDPE Plastic the Easy Way
101,060
1,106
161
About: Come spend some time in the shop. I'm a hobbyist woodworker and professional computer geek in Northern California. I guess my projects will vary widely, and I have no clue what I plan to make next...
After spending 2 hours cutting up a single milk bottle with kitchen shears, I knew I couldn't do it again.
I felt like a late night infomercial and may have actually uttered the phrase, "There has to be a better way!"
Turning old milk jugs and bottle caps into useable stock for making. In this short video I process a 2 milk bottles and about half a dozen bottle tops into a 1 1/2" x 3" x 5" turning block.
You could just as easily press this into sheet material for use in box inlays or scroll saw art. The possibilities are endless. The total processing time was under an hour from bottle to blank! Less than waiting for a glue up!
The result is a stunningly colorful blank ready for some new project!
2 People Made This Project!
  • Jewelry Challenge
    Jewelry Challenge
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
161 Discussions
pbarsamian
4 years ago on Introduction
Of course I am wondering about 2 things: 1.) the state of the expensive Vitamix blades after grinding plastic, 2.) the fumes from melting the plastic
kludge77pbarsamian
Reply 4 years ago on Introduction
2. No fumes that I could detect.
1. The Vitamix made drinks Wednesday and performed as per usual. That being said, my wife has made it very clear it doesn't get to go on another shop field trip... :)
Rimwulfkludge77
Reply 3 years ago
of course its a "VitaMix" it can grind cement into dust yet it can't do a thing to strawberry seeds they're impervious to the vitamix powers
Rimwulfkludge77
Reply 3 years ago
ChrisK12kludge77
Yeah, those fumes your olfactory bulb can't respond to are always really safe to inhale...
inkerbelkludge77
I'm curious if the plastic pieces scratched up the container at all. I honestly don't know if my husband would have survived doing that to my Vitamix!
That said, I've been tempted to put non-food items into my Vitamix container as well, so I'm considering buying a second container if I can find a used one somewhere at a price I'd be willing to pay.
GenerallyOddkludge77
Every workshop needs its own vitamix...in my opinion...wish they weren't so expensive. But the good news is that you can often pick up a blender at a rummage sale for a couple of bucks. And if you take out the guts, they're mostly recyclable.
pbarsamiankludge77
that is so strange. my father, in his reduced state, accidentally melted a bunch of that stuff and the stink was terrible.
Your wife is smart!
radamquigley
I have done this but use the Christmas cookie tins as the mold. It allows the plastic to melt into bricks, and you can cut down to size from there.
Light_Labradamquigley
Polymers seldom melt sufficiently to consolidate without some compression. Kludge77 did the right thing by softening then pressing into a mould. If you just heat polymers for a long time and/or very high temperature you will get massive decomposition (yellowing) before they melt into a solid block.
RedBinaryLight_Lab
Time is an issue, however most types of HDPE in small enough granules will join without compression. As I said elsewhere in the comments here I would actually recommend experimenting with a temperature range of 400-450F as that is the temperatures we use at my work to get the plastic to a nice light consistency without burning for cleaning it from metal tooling. The process uses high pressure compression and a temperature profile starting at around 330F and ending in the range of 350-365F. This lower temperature for the process allows for better surface appearance of the pressurized plastic and quicker cooling for the industrial process, but for creating "ingots" that cool at room temperature over a non-specified "cycle time" it would not be an issue. You wouldn't expect to see any decomposition of HDPE at 450F until molten at an extended time frame of maybe 20 or 30 minutes. Maybe even longer than that.
Light_LabRedBinary
Yes HDPE powder can be sintered as low as 130C depending on grade. One of the research projects I worked on involved developing sintered polyolefin prosthetics. Sintering provides an open pored structure and this porosity weakens the material mechanically. I am sure that most uncompressed sinters would not survive lathe work. Moreover the porosity is very dependent on the polymer particle size. Roughly stacked polymer chips would produce a poorly sintered structure.
Sintering density is improved with elevated temperature and time. Polymers are good thermal insulators and getting the heat to penetrate to the centreof the powder of a large enclosed mould can take a very long time. Often hours not minutes. The outer layer is subjected to the full time and temperature. In our work we found the manufacturers decomposition temperatures to be very optimistic.
I once made an experimental series of consolidated sintered blocks (~150mm cube) using a range of conditions up to 250C and up to 4 hours, easily eclipsing the conditions you suggest. Every reasonably undecomposed sample turned out with only a consolidated skin ~2-3cm thick, the centre particles were still free flowing. I eventually achieved marginal success by repeatedly pulling the hot mould out of the oven and standing on it and then returning it to the oven. i{^_^}
BUT it does depend on what you call acceptable mechanical strength, density and decomposition; the medical standards for prosthetics are very strict. If what you made didn't fall apart; smell really bad; or end up in a child’s mouth it could be acceptable for some applications.
radamquigleykludge77
you will have to flip it once or twice so all the air trapped inside gets pushed towards the surface. The smaller tins (the rectangular ones) work best and punch a hole or two on top to vent the gas it lets off. For some reason placing large strips on the bottom and then adding smaller cut pieces keeps it from burning or getting that brown edging. Hope it helps...
tcup345
Question 11 months ago on Introduction
Is there any way to melt plastic without using a toaster oven? Could I use a torch?
StevenL107
1 year ago
Maybe I need to find a Vitamix blender because I chunked a bunch of milk bottle strips into my Cuisinart blender for five minutes and it had zero effect.
Eddie_T
3 years ago
I would like to make a sheet that could be rolled into a cone shape to make a cyclone dust separator similar to the Dust Deputy. Maybe starting by cutting and flattening 5 pound whey protein containers, then somehow joining them into a larger sheet.
