How to Build Garage Shelves From Scrap Wood
685
7
4
About: Hi Everyone, I'm Jeremy Hoffpauir. I write instructables about unique DIY woodworking and home improvement projects. I use unique design elements with a rustic coastal style in my creations such as epoxy...
In this instructable, I show you how to build sturdy garage shelves from 2x4s and plywood.
First, I like to be organized. Furthermore, the first step to organization is creating a home (garage shelves) off the floor for each item.
I am a native of South Louisiana, which means I own lots of outdoor cooking equipment for boiling crawfish and other seafood. Moreover, my outdoor cooking equipment and ice chests currently reside on top of my garage refrigerator or on the garage floor. So, I decided to build sturdy garage shelves from 2x4s in order to hold my ice chests and outdoor cooking items. Additionally, I used scrap plywood and particle board for the wall mounted garage shelves.
This sturdy DIY garage shelving solution is strong, versatile, and expandable. Also, it can be built for a single shelf or across an entire garage wall.
Lastly, the DIY garage shelves can easily be moved to accommodate larger items and make efficient use of wall space.
Tools I Used
Free DIY Plans
1.75" Screws
3" Deck Screws
Laguna Bandsaw
Jig Saw (Alternate to Bandsaw)
Circular Saw (2nd Alternative to Bandsaw)
Wood Glue
Brad Nailer
Nails for Brad Nailer
Air Compressor
Hose Reel for Compressor
Clamp
Leveler
Neodymium Magnets
Step 1: Make Brackets
I built the shelf brackets according to the measurements in the diagram.
First, I used a square scrap piece of 3/4" plywood for the garage shelving brackets. Also, this plywood happened to be large enough for 2 brackets. Ultimately, I cut the plywood to be 16" wide.
Next, I used my tape measure to mark a line 8" down from the top corner, 1.5" across from the previous mark, and finally 1.5" down from the top of the opposite side. Conveniently, the 3/4" plywood was a square. This allowed me to reference the 90 degree angle on 2 sides.
Then, I used a marker, a ruler, and a combination square to connect the lines.
As a side note, I made a few brackets from scrap 1/2" particle board because I ran out of 3/4" plywood; however, I didn't use them - yet. If you plan to use this material as a bracket, be sure to laminate 2 brackets together with glue and brad nails to make one bracket. Ultimately, 1/2" thick particle board is not enough strength to use as a bracket.
Step 2: Cut Out Brackets
I used my bandsaw to cut out the DIY garage shelves. However, a jigsaw works just as well if not better.
Additionally, you need two side brackets to make 1 shelving bracket.
Step 3: Middle Support Bracket
The middle support bracket for the garage shelves stabilizes the bracket and creates a flat surface for the shelf. Basically, I used a 14.5" scrap 2x4.
First, I gathered a scrap 2x4. Next, I measured and cut to length on my miter saw. Then, I used the first 2x4 as a baseline to cut the additional middle supports. Obviously, this helps keep things consistent and speeds up the process. Lastly, I cut 1 middle support bracket for every bracket.
Step 4: Garage Shelving Bracket Assembly
As a quick note, I painted the garage shelving side brackets and middle support with leftover paint in my workshop. Of course, this is not necessary.
Additionally, I used a scrap piece of 2x4 to serve as reference during the bracket assembly. This is the 2x4 in the pictures below which is not painted.
First, I placed the 2 side brackets on opposite sides of the reference 2x4 with the inside of the bracket facing up.
Due to my paint miscalculation, I did not paint the inside of some side brackets and the top of the middle support 2x4 to conserve paint. These parts of the bracket are not visible. Next, I ran a line of glue along each bracket. However, I forgot about the 1.5" of space I needed to leave for the support 2x4. I simply used my finger to push the glue away from the reference 2x4 approximately 1.5".
Then, I placed the middle bracket on top of the reference 2x4 and closed the side brackets on them. I used a clamp to hold it in place.
Step 5: Secure Garage Shelves
While the clamps secured the side brackets, I secured the garage shelves.
First, I drove 2 brad nails in per side. Then, I loosened the clamp and removed the bracket from the reference 2x4. I verified I had 1.5" of space between the back of the middle support 2x4 and the back of the side brackets. Next, I drilled 3 pilot holes per side and secured it with screws.
Then, I verified the bracket fit nice and snug on the reference 2x4.
I repeated this process until I had 8 brackets.
Step 6: Prepare Wall Support 2x4s
For these DIY sturdy garage shelves, the wall support 2x4s must be attached directly to a wall stud.
Since I installed this system in a small space, I only needed 2 8' 2x4s to vertically attach to the wall at 32" apart. As a side note, wall studs are spaced 16" on center behind sheetrock. I find it more than sufficient and sturdy to space the wall support 2x4s 32" apart. First, I used a 1/8" drill bit to predrill 4 pilot holes spaced around 2' apart. The spacing doesn't need to be exact. Next, I used a countersink bit so the screw does not protrude the surface as this may cause the shelf bracket to be uneven.
Step 7: Find Wall Studs With Magnet
Obviously, finding studs is an important part of building sturdy garage shelves from 2x4s. In order to find wall studs without a stud finder, I used a neodymium magnet to locate the sheetrock screws.
Essentially, sheetrock screws are used to secure sheetrock to a wall stud. Neodymium magnets lock on sheetrock screws very easily, which helps me determine the location of the wall stud. First, I run the neodymium magnet horizontally on the wall and slowly work my way down with each pass. Next, I use a nail to mark the location of the stud through the center hole in the magnet. Then, I repeat the process further down the stud to get another reference nail. As a last step, I use my 4' leveler to mark a line down the center of the stud.
Step 8: Secure Wall Support 2x4 to Wall Stud
First, I place the wall support 2x4 on the line with my leveler on the side to make certain it remains square.
Next, I use a 3" screw to secure the 2x4 to the stud.
Step 9: Attach Brackets
After both wall support 2x4s were secured to the wall stud, I attached the garage shelf brackets.
First, I marked the top of each support bracket according to the drawing below.
Next, I placed the brackets on the 2x4s. My brackets had a snug fit, so I didn't need to use a clamp to secure them.
Then, I drove in 2 screws per side on the first bracket. I placed the leveler on top of the bracket and repeated the same process for the other bracket while keeping everything level.
Step 10: Secure Top Shelf
First, I used my bandsaw to cut 2 notches 1.5" deep according to the diagram below. I used 1/2" particle board for the shelf, but 3/4" plywood can be used as well. In fact, the drawing and my DIY plans for this project have 3/4" plywood as the top shelf.
Then, I used 2 screws (front and back) to secure the shelf to the middle bracket support.
Step 11: Final Result
These garage shelves provided a home for my ice chests and outdoor cooking equipment.
Also, I like this garage storage solution because I can easily expand the system to other parts of my garage. In fact, I plan to do just that in the coming months.
Step 12: Conclusion
I hope this project provided you with value.
Visit my online store to download a set of DIY Plans or purchase unique items I create.
Do you want me to make you something? Visit my online custom request form and let me know what you are looking for.
Feel free to contact me anytime if you have any questions. I'm happy to help!
Follow Me
YouTube - I have plenty of video tutorials
Instagram
Facebook
Twitter
Pinterest
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    4 Discussions
    dk31rc
    4 weeks ago
    Nice shelves. I think that for a stronger structure you should put the narrow side of the studs facing the wall and the narrow side of the brackets facing the shelves - something like the pics below. Of course, for light loads it won't make any difference.
    jeremyhoffpauirdk31rc
    Reply 4 weeks ago
    Great Idea! I did not think of that design, but it definitely makes sense and would be much stronger. Thank you for the suggestion!
    seamster
    5 weeks ago
    This is a great and very easy to make bracket design. I had some shelves in my garage using brackets like these for many years. Nicely done!
