How to Build SMPS Transformer | Home Make 12V 10A Switching Power Supply
About: Nice to meet you my friends. Visit my Youtube Channel for get more instructable My youtube channel: https://www.youtube.com/c/longtechnical
With the transformer from old computer PSU. I try to make 12V 10A ( SMPS ) at home. I use SprintLayout for make PCB and iron method for make PCB board. In this video you can see me windings the SMPS transformer
For easy make PCB you can download my gerber file below and upload to JLCPCB.COM for make PCB online
https://drive.google.com/file/d/1UjW-VHvbHSNWNfw00ue3HTzWt3pBR8py/view
Step 1: Design the PCB
I use SprintLayout one of Rusia electric software for design PCB and print it to calendar paper. I always use calendar paper for print PCB because it cheap and good quality
Step 2: Make a PCB by Iron (press) Method
The first we need to cut the PCB exactly the PCB we print on calendar paper. After that we use the iron press to the PCB about 5 minute at maximum temperature
Step 3: Complete Make PCB
We put the PCB into water about 5 minute. After that we take the paper out and put it to FeCl3 liquid for 15 minute or more...then put to water again and clean it.
Because make the PCB take alot of time so for easy you can make PCB online. I usualy make PCB online by upload the gerber file to JLCPCB.COM for get PCB only 2$ for 10PCB. All file of my project include gerber file below. https://drive.google.com/file/d/1UjW-VHvbHSNWNfw00ue3HTzWt3pBR8py/view
Step 4: Drill PCB and Solder Component
Make the hole for PCB and solder component. I had attach the layout picture you just put the component to exact position.
List of component below.Your can order online them from LCSC.COM
Fuse 5A https://bit.ly/2F8Gvmy
Capacitor 275/250V https://bit.ly/2P2vKad
AC filter https://bit.ly/2SIc6hE
Brigde diode RS507 https://bit.ly/2AHtLz4
Resistor 150K https://bit.ly/2JxTcWD
Cacpacitor 150uF/450V https://bit.ly/2ziFjXC
MF275 5D9 https://bit.ly/2P6KNiU
Resistor (27k )33K/2W https://bit.ly/2RwonVc
Mosfet 20N60 x2 https://bit.ly/2SCssst
Resistor 27ohm X2 https://bit.ly/2Rt2INF
Capacitor 224/100V https://bit.ly/2Om5S3Y
Diode UF4007 https://bit.ly/2yLNSek
Diode 1N4007 https://bit.ly/2zpXcno
Diode MBR20100 https://bit.ly/2F8HXp0
IR2153 https://bit.ly/2AHuwbo
Resistor 15K https://bit.ly/2EZwYhF
Capacitor 102 https://bit.ly/2QeOhN7
Capacitor 100uF/16V https://bit.ly/2PDOfkw
Capacitor 105/600V https://bit.ly/2yNRP1T
Resistor 4K7 https://bit.ly/2yM5CGv
Led 5mm https://bit.ly/2P31o7s
Resistor 2k2/2W https://bit.ly/2RwQNP0
Capacitor 2200uF/50V https://bit.ly/2AHcNkD
Choke and transformer heatsink we can take from old computer PSU
The Transfomer we need windings modify.
Step 5: Take Out the Old Wire From Transformer and Rewindings
Put the transformer to hot water in 5 minute. after that we can get the ferrite core. windings the transformer we use 0.4mm wire with primary 40T and secondary 5T for get 12V output. At the output with big current we use 6 wire together. Each layer must to use insulation tape
Step 6: Solder Transformer and First Test
Solder the transformer and test the circuit. In the first test we must connect with 60w/220v light bulb before plug to 220V. If the circuit fail the light bulb will on and we safety
    • PCB Contest
      PCB Contest
    • Safe and Secure Challenge
    • Faux-Real Contest
      Faux-Real Contest
    15 Discussions
    JohnC430
    4 months ago
    Heyyyy!!! thats a great idea to print the pcb on Calendar paper. and also to cook the old transformer to remove the glue etc. Thanks for sharing.
    throbscottle
    5 months ago
    Is it your own design of SMPS?
    Can you supply a schematic please? It would be good see how it works and not just follow a construction guide.
    I have a box of old ferrite core transformers I wanted to open, thank you for showing the method!
    LongTechnicalthrobscottle
    Reply 5 months ago
    Sorry for the late reply. This is design of SMPS. I use IC IR2153 with R=15k and C= 1n it run at 47kHZ. Schematic below
    Razanur
    4 months ago
    Nice instructables. I'm really missing the part on how you came up with the schematic (and the schematic itself). You had a design target, how did you achieve it. There are really good I instructables on toner transfer etc, so you can just link to them. What makes this ible unique is the purpose of the electronics. That's at least why I came here - I wanted instructions on how to translate the design target (12V, 10A) into a circuit.
    JohnC430Razanur
    Reply 4 months ago
    The title of the instructible is "
    HOW TO BUILD SMPS TRANSFORMER"
    so you were expecting more than that? there are plenty of 12V/10A p/s designs in YouTube.
    (sorry for the large CAPS font; i merely copied and pasted the title)
    mrtalgo
    5 months ago
    Good project! I like the ferrit/bobin extraction.
    You can add a schematic diagram for reference.
    JohnC430
    5 months ago
    Nice project. Thanks for sharing. where is the schematic? How did you calculate the turns on the primary? you have 20+20 turns = 40 Turns. what is the frequency of operation? how big is the core? part number? Please explain. Thanks
    LongTechnicalJohnC430
    Reply 5 months ago
    I use IC IR2153 with R=15k and C= 1n it run at 47kHZ. The transformer take from old computer PSU with EE35 core Schematic below
    LongTechnical
    5 months ago
    If you have any problem about my project. Please comment below i will help you. Thank
