How to Build a 2×4 Porch Swing
4,474
106
About: Build instead of buy....most of the time.
I have always wanted to turn my sitting bench design into some type of swing. Recently I was asked to make a swing so I figured now would be a great time to do so. The swing that I came up with is made from eight 2x4x8’s and four 3/8″ eye bolts. My cost was around $40 with a build time of 5 hours. I wish I had a place to hang one of these because this has turned out to be one of my favorite projects in a long time. I hope you enjoy and can build one of your own. When you get to the end of this tutorial don’t forget to download the free plan!
Step 1: Cut
Cut all of your parts to length and width according to the cutting diagram. The width (3″) needs to be cut first with the arm components. Typically I like to have all my parts cut before assembly but there are a few parts that need to be measured after some assembly is done (pink)
Step 2: Half Laps
Half lap joints can be cut with various tools. In this project I used my table saw with a dado blade. It is the quickest and easiest method for me. However, if you do not have a table saw you can either cut these with a hand saw and chisel or a circular saw and chisel. For a good explanation of cutting precise half laps please refer to the video at the end of this article.
Step 3: Glue Up
With all of the arm components cut and fitting together nicely you can glue all of the pieces into place.
Step 4: Trim the Arms
The front of both arm assemblies needs to be trimmed slightly (red/bright green). A cut perpendicular to the bottom needs to be made where the half laps intersect. This point is where the seat slats will start.
Step 5: Add Slat Supports
The slat supports (pink) can now be measured and put in place. I used glue and 4 or 5 screws to secure them to the arm.
Step 6: Install Slats
Starting from the front install the seat slats. Each slat is secured with two screws on both sides from below. Make sure you pre-drill for all of your screws so that you do not split the slat support. The space between slats is 1/8″. I used the solid end of a 1/8″ drill bit for this. After the seat slats, install the back slats working from the top down.
Step 7: Eye Bolts
I used 3/8″x4″ eye bolts on my build as they were the shortest I could find. 3-1/2″ eye bolts would be ideal. I drilled holes so that they went through both the arm and the slat supports.
Step 8: Final Thoughts
So that’s it. This was a very fun build. Like I said in the video I don’t have anywhere to hang this from. I sure wish I did because I really want one of these for myself! As always, if you decided to build one of these I would love to see your finished product! If you would like a PDF copy of the full plan as well as the SketchUp file download the .zip file here.
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    HansG30
    6 months ago on Step 8
    Hi
    Really like the build. Looks great and very neat. I think that having a a couple of diagonal beams between the seat and the backrest would significantly increase strength.
    HG
