How to Build a Temporary Wood-fired Brick Pizza Oven With Cheap, Easy to Find Materials
168,773
169
37
About: I write for magazines, I make TV shows, and I blog about things to build. Check out my website "DO IT" for more DIY fun.
If you like DIY projects (and pizza projects), check out my site, mikesenese.com/DOIT and follow me on twitter @msenese
This pizza oven is just about as simple to build as stacking blocks, but creates a highly effective wood fired oven with an arched roof that can reach the 800-900 degree temperatures needed to make mindblowing pizza.
Originally posted on my site:
How to Build a Temporary Wood-fired Brick Pizza Oven with Cheap, Easy to Find Materials
and
Tips, Notes and Photos from a Reader’s Temporary Pizza Oven Build
(in which DOIT reader Tom Niccum builds his own temporary pizza oven following the original writeup my site, and graciously supplied many very helpful tips, supply lists, and info. Thanks Tom!!)
This is a great, low-cost project for someone who wants to test out the ins-and-outs of brick oven cooking. Super fast and easy to build, and with minor modifications, it can be assembled semi-permanently and get you through a season of baking delicious breads and pizzas.
I attended a fantastic pizza making event at Machine Project (instructor: Michael O’Malley) that included the construction and firing of a DIY temporary brick pizza oven – the ultimate in pizza cooking. Hugely educational and inspiring, even for a committed pizza fanatic such as myself. The oven, built, fired up, and torn down over the course of an afternoon, worked amazingly well – I cooked the best pizza I’ve ever made, by far.
Step 1: Tools and Materials Needed
Materials:
1. I used 190 Firebricks (one sacrificed to make “shards” for roof shimming. (about $1.80/ea)
2. Used 1 50# bag of refractory clay and 1 bag of sand.3. 60 concrete blocks ($1 each)
4. 5 48″ angle iron5. 4 48″ threaded rod
6. 4×4 durock
7. 4×4 IsoBoard (expensive! $12/sf) (at Machine Project we used 16 1' pavers as we built this on a solid metal tabletop)
8. 8.5×8.5x 24″ Clay flue liner
Tools that came in handy:
1. Angle grinder with cutoff blade (threaded rods, angle iron)
2. Circular saw with diamond blade (Durock, Jig legs)
3. Skill saw (jigsaw) – Jig form
Step 2: Base Construction
At Machine Project we used a heavy metal table (for ceramics or welding).
Thomas built his own base from concrete blocks
1. Base is 5 courses of standard concrete block (48×48″) with a line of block down the middle of the interior
2. On top of base is Durock cement board
3. On top of Durock is a 2″ layer of IsoBoard – a refractory insulation – should help keep the floor hot longer
4. Floor of oven is on Iso Board
Step 3: Assemble the Floor and Walls
For the floor of the oven built at Machine Project, we first used a single layer of concrete pavers to create some insulation. 4'x4' grid, 16 pavers total.
Alternatively, Tom Niccum used a 4' x 4' ISO board, an easier (but much more expensive) solution if you don't already have a flat surface underneath.
On top of the first layer, start laying out the firebricks into a square floor that is 5 bricks wide by 10 bricks deep. If your firebricks aren't of standard size, you want the floor area to be square and close to 4'x4'. A few inches short is OK.
Take the 4' angle iron pieces and drill a hole at each end, large enough for the threaded rod to slot through, but small enough that the nut can be screwed against it without going through it. We'll use these metal pieces to hold the sidewalls in place. Place two of them on the floor of the oven, one on the right and one on the left side.
Assemble the side walls by standing bricks on their sides, placed on top of the angle iron that runs them the length of the floor. Starting from the back, put thirteen bricks on each side (see photos for positioning). Add one layer of bricks on their side on top of that layer..
For the back wall, stack bricks on their sides in a staggered pattern. You'll need to break a few bricks in half to have the back wall sit flush with the sidewalls. Go six levels tall and on the last level, leave the sides open as the roof will start arching in here.
Once you have the sides in place, you can put the other two angle iron pieces on top of the bricks and slide the threaded rod through the holes. Screw the nuts into place but don't lock it in yet, in case you have some adjusting to do.
Step 4: Build the Arch
I get a lot of questions about the jig used to place the bricks into the arch. Here are the details and a rough blueprint:
-Legs: 2×4, approximately 12″ long (extending 9.25″ below the arch). Qty: 2
-Arch: 1/2″ plywood, 32.25″ wide, 5.25″ at its peak. Qty: 2
The legs extend below the bottom of the arch 9 1/4″ – however, the exact height was adjusted on-site (by cutting part of them off) by the instructor to match up with the size of the bricks he used. In order for the arched bricks to lock into place, you want the bottom edge of the arch to be just below the walls. On our oven, we did a stack of bricks on their side (about 9″) and one layer laying down (about 2″) . Measure your bricks and adjust the height of the arch accordingly.
The two legs are screwed in between the two sides of the arch
To draw the curve, you want to know the radius of the arch you’re building. After doing the weekend class, the instructor gave me the jig we used, but no specifics on the dimensions. Using an online circle calculator with the measurements of the arch height (5.25″) and the chord length (straight-line distance between the two ends of the arch; 32.25″), I was able to determine the radius of the arch to be 27.39″. With the radius, you just need to make a line at that length, one end fixed and one with a pencil attached to it, and use that to draw the curvature.
If you don’t have internet access and need to figure out the radius, here’s the equation:
radius = (rise2 + (1/2 width)2) / 2 x rise
rise is the height of the arch
width is the length of the chord
Attach the two pieces of plywood with a few screws before cutting, and cut them as one piece to ensure that the curve matches. Use a jigsaw or a router set up to cut curves. Ultimately, the bricks will settle a bit so the curve doesn’t have to be cut perfectly, but try to get it close to make things easy.
Step 5: Stack Bricks to Make Arch, and Remove the Jig
Place the jig at the back end of the oven, against the wall. Put a thin (1/4" or less) shim under each leg.
Starting from the outside, add the bricks on their sides, moving inwards from each side. The middle brick (keystone) ended up fitting perfectly into place. Break one of the firebricks and use the shards in between the gaps to keep them from shifting and falling during the jig removal.
Once the arch is in place, you want to gently slide the shims out from underneath the legs. The jig will drop down and the bricks will settle a bit. At this point, you can gently pull the bottom of the jig towards you to slide it out from the bricks. If everything was done correctly, they should remain in place. I have never seen this not work, but still, do it gently.
Watch the attached video for a demonstration.
Once the first layer is done, repeat for two more - the arch ceiling is three brick lengths long.
Step 6: Build the Opening and Chimney
You'll still have a bit of space past the archway towards the front of the oven – this is where the chimney will go.
Make sure to consult the photos to see that you have the bricks oriented well.
Start by adding six bricks, stacked sideways, on each side of the wall. This will create the entryway.
Four bricks, on their sides, are placed on top of both walls. At the back side, a strip of angle iron is placed against the arch to create a lip that runs between both sides of the oven entryway.
A second angle iron piece is placed on the bricks at the front, to create a ledge for the top of the entryway. Place bricks, on their side, across this angle iron.
Three bricks are placed on each side wall, leaving a space in the center that the chimney flue can fit over (the back of the flue rests on the angle iron that goes in front of the arch; the front of the flue goes on top of the bricks that make the top of the entryway.
Place two more bricks on each side of the chimney to block any remaining opening from the archway.
Step 7: Cover the Oven in Fireclay
Mix up a batch of fireclay (available at pottery and clay suppliers) and sand, with water.
Apply this mixture to the outside of the oven, concentrating it on all the gaps between bricks. The idea is that this will help keep the smoke, and to a lesser degree, the heat, inside the oven. Be liberal with it. You'll have plenty.
We found a few spots on the back of ours that didn't get enough fireclay. And as Thomas noted:
"Clay/Sand – we did a 1:1 mix. It seems very grainy and brittle – lots of cracks. May try another batch with less sand and put over the current one."
Step 8: Fire It Up!
At this point, you should be just about ready to go. An advantage of this "temporary" design over other cement or mortar styles is that you don't need to wait for anything to cure before heating it up.
Start by lighting a very small kindling fire. We used some scraps we cut from an abandoned wooden pallet. In fact, we did the entire fire using scraps from that pallet.
As long as you go at a slow pace, you'll minimize the amount of smoke generated. Let the kindling burn for a bit, then add bigger pieces slowly. You'll notice the roof of the oven collecting black soot.
Eventually, you'll have a very nice fire raging inside the oven. The soot will start to burn off, leaving the bare bricks exposed again.
Keep feeding the fire, while watching the temperature. A good oven cooks around 800 degrees. Use an infrared thermometer to gauge the temperature. I got this one which goes up to 952F, and it didn't cost much at all.
Once you're up in the 700 degree range, you'll have no problems making some seriously tasty pizzas. Push the burning wood and embers to the back of the oven (make a simple tool for this if you need to by nailing a short 2x4 to the front of a longer piece) and sweep using a natural hair brush. Oh, and wear gloves if you have them. I use welding gloves.
Step 9: Make Your Pizza
Make your pizza to your liking.
With a hotter oven, you can use a wetter dough.
Slide it into the oven with a peel (read my writeup on how to make a perforated pizza peel). Keep your eyes on it though, this one will cook a LOT faster than your home oven does. About 45 seconds in you'll want to rotate it. Give it another rotation about 45 seconds later. 30 seconds after that, you're just about done.
Remove.
Slice.
Devour.
Step 10: Final Notes From Tom
Finished up in time for lunch…
Pizzas were great – I think I need to get the oven hotter – they were taking 4-5 minutes to cook fully. but they still tasted fantastic.
Start time to finish – roughly 10 hours. Five hours Friday night – much of that was hauling the concrete blocks and fire bricks from the front of the house to the back. I did all of that myself. Also got base assembled and hearth laid.
9am-2pm (5 hours) on Saturday had 2 friends assist. Built side walls, drilled angle-iron, built curved roof jig, built roof and applied the mud. Fired oven for one hour to heat/cure.
Pizza in belly by 2:10pm…
Notes:
1. I did add another set of bricks on each side of the door to make the opening smaller, it seemed too large to me (that took six bricks)
2. Oven was still pretty warm 4 hours after fired died out. I’ll try to take some temps with my infrared thermometer of heat decay
3. Clay/Sand – we did a 1:1 mix. It seems very grainy and brittle – lots of cracks. May try another batch with less sand and put over the current one.
4. Clay flue liner cracked within a few minutes, seems to be holding together, but maybe we need to heat more slowly the first time
Future experiments:
1. Wrap exterior in ceramic fiber insulation blanket while running… try to get heat up.
2. Build a door
3. Fire to heat then record temp decay with as is, and with blanket, and with door. Want to test feasibility of pre-heat then baking bread or roasting chicken with out fire burning.
UPDATE:I got an email and a photo from Tom telling me about his attempt to cook a whole chicken in the oven. From the description and the looks of the photo, I think he got it right on the first try.
"Tried roasting today… have to keep a small fire going as the temporary oven doesn’t hold enough heat. Otherwise, fantastic.
Did two chickens. One in a roasting pan, one “Beer Can” style. Plus a dish of potato, carrot and zucchini.
Best chicken I’ve ever cooked.
Took about 90 minutes to roast, stayed nice and moist, outside was deeply browned."
Finalist in the
Pizza Contest
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    37 Discussions
    KraigR
    Tip 9 months ago on Step 10
    Would consider emitting sand from fireclay. Consider ordering arch bricks. Would slow heat steady but just a small fire for a long time like 24 hours. This is curing/drying period for castable refractory. After drying heat slowly elevate with larger and larger fire. Keep the large fire going to get oven hotter than what it will ever be to cook. This drives out chemically bound water after which further heating fires this material through conversion to it's ceramic structure. Temporarily insulation on the shell during firing can help. Pink housing insulation will work. Pay a very close inspection of interior arch surface. It's natural for refractories to exhibit some spalling like behaviour. Using a dental pick dislodge any pieces of refractory that look like they might want to come loose. Do this after each cook for several firings. One school of thought on baking bread in a wood fired oven.... building one large fire filling the entire space followed by a second reload, after which floor gets raked/swept/mopped. Baguettes are cooked first followed by whole wheat and then sourdough-rye with a thick crust.
    DominickH
    1 year ago on Step 1
    I count 229 firebricks. could you tell me the dimensions of your fire bricks as well? Thank you
    Roddy Harrison
    2 years ago
    First of all great post! Now, one thing that is almost never mentioned in these DIY:s is how to add a door. I've found a place where I can buy a door https://vurb.eu/products/double-door but it's very rare that it's in these DIY that they explain for example how to attach a door etc. Also I would like to know if I should pick the door first or descide on the oven structure first.
    mommywoman
    4 years ago
    This is really nice. You could make it permanent by using something (like mortar ?) to adhere the bricks. Your title says cheap. I'm sorry, but I don't think of this cheap. I tried to calculate the cost of the supplies and I came up with a figure in the several hundred dollar range. With a somewhat limited budget that's a lot of money to me, maybe not to other people and I'm sure it must be cheaper than hiring someone to make it. It is very nice though.
    mikejsapopivker
    Reply 4 years ago on Introduction
    Yes, in fact I know of one person in Minnesota that has done just that. Simply replace the clay with refractory cement and affix the bricks permanently. An external housing will help protect from the elements.
    Info about his build here: http://www.mikesenese.com/DOIT/2010/06/diy-temporary-wood-fired-pizza-oven-build-tips-notes-and-photos/
    Let me know if you build one!
    leovalk
    6 years ago on Introduction
    This looks like something I can try, but where did the durock go? it is listed in the materials but I can't see it and there is no reference to it on in the text.
    andyk75
    8 years ago on Introduction
    Hey, very good description of the oven! In the last step, did you put a closed beer can in the chicken, or was it an empty one? Andy
    Jason91887andyk75
    Its an open, full beer can I believe. A full one would explode and no one wants shrapnel in their chicken. Nice instructable btw. I have been wanting to make a brick oven/grill and I might take a few cues from this.
    We always mix half can of beer and half can of BBQ sauce together and insert the open end of the can into the chicken. It not only gives the bird a little more flavor, but it comes out real moist.
    Originally called "Beer Butt Chicken".
    dondonjordanandyk75
    if you put a closed can in the chicken you'll be picking aluminium shards from your dinner all night long. Your meant to pour yourself a glass and put the opened can up the chicken. LOVELY JUBLY!!!
    Morpheus
    Have you thought about using a scissor or hydrualic jack (like one from an old (or new) car ie the one you tow the trailer with, to lower the arch jig instead of knocking out the shims? Just put the jack on a piece of plywood in the centre of each course of bricks. Next, wind it up to the correct height, then lower away when you are finished placing the bricks on the jig. Should be a lot easier and no collapsing/jarring etc. to worry about.
    themarkd
    Very cool. May give it a try. But, at just shy of $700 bucks it ain't cheap, and (around here) firebrick isn't "easy" to come by. With some mods, could cinder block replack some non heat conductive portions? If there are any.
    mikejsthemarkd
    Yeah, firebrick is definitely a lot pricier than the generic type - but keep your eyes open on Craigslist and other places, I've heard stories of used refractory (fire) brick being given away. The instructor/guide on this project, Michael O'Malley, told me that it should be fine to use standard red bricks if there is no long-term intent for the oven. Eventually the heat should cause them to crack and degrade, but I have a feeling you could get at least a few firings out of it. If you test it out, leave a note to let us know how it goes.
    Wazzupdoc
    Great Instructable and very inspiring. Here's an idea: why not use a small hydraulic bottle jack to hold up the arch during construction. You could then lower it gently and make any adjustments to the arch along the way. I like the project. It's something I've been thinking about for a long time.
