How to Capture the Sun in a Jar!
52,750
174
31
About: In a valiant attempt to keep myself from dying of boredom, I create.
I was looking for way to provide an energy fun and safe night light for the grandchildren's bed room.  I found inspiration for this project in two places; the first is here:  http://craftsbyamanda.com/2010/12/epsom-salt-luminaries-some-winter.html, so my thanks for Amanda and her Epsom salt luminaries and here: https://www.instructables.com/id/Home-made-Sun-Jar/, my additional thanks to cre8tor for his sun jars.  What really finalized the project was the day I walked into our local dollar store and there were the solar powered lamps for one buck.  The same day I went to target and they had them there for $2-$10.  Hurray! This just might work.  So I bought 3 (from the dollar store) and when home and when I had a little free time, I made them.  So here is how I was able to “Capture the Sun in a Jar”, and add a little light to that dark bedroom.
Step 1:
Supplies:
Solar yard lamps ($1 from Dollar Store)
Glass jar with glass lid ($2.50 from local craft store)
E 6000 glue
Espom Salts crystals ($3.00 for a big bag)
Modge Podge glue
Food colors (you choose)
Paint brush
Paper (foam) plate
Clear spray sealer
Blue painters tape
Spoon
Step 2:
Take the solar yard lamp apart, until all you have is the main light assembly.  On the top is a mini solar panel.
Step 3:
If you unscrew the screws on the back you will find a rechargeable battery which is connected to the solar panel.
Step 4:
On the opposite end it a LED light.  If you cover the solar panel the light will glow.  Just leave it the way it is.
Step 5:
Put some of the E-6000 on to the outer edge of the solar panel
Step 6:
and stick it to the underside of the glass lid.  This will allow the solar panel to absorb the energy from sun through the glass and store the energy in the battery.   The E 6000 is and dries clear so it will not interefer with the solar panels' energy gathering capabilities.
Step 7:
Place a piece of the blue painters tape on top of the lid to cover the solar panel.  You will be covering the jar with Epsom salts and you want to keep the solar panel area clear so that it can absorb the suns energy.
Step 8:
Pour some Epsom salts crystals on to the paper/foam plate.  At this point, if you want you can add a couple of drops of food coloring, using whatever color you choose.  Use a spoon to mix it well.
Step 9:
Use the paint brush to spread the glue all over the jars sides.  Use as much glue as you can without it running all over.  Roll the glue covered sides of the jar in the Epsom salts crystals.  Set it aside to let it dry (this will take several hours to overnight).
Step 10:
Spread the glue on the sides of the lid and cover it with Epsom salts.  Put more glue on top of the lid, all around where the solar panel will be.  Sprinkle more Epsom salts on the glue.  Get every area, except the solar panel area, covered with Epsom salts crystals.  Let dry.  Wash the brush with soap and water and let it dry also.
Step 11:
After the glue holding the Epsom salts crystals is dry, take the clean, dry paint brush, and brush off any loose salt crystals.  Then use the clear spray sealer to seal the Epsom salts crystals.  Spray 4 light coats, with time to dry, in between each coat.  A heavy coat could cause the Epsom salts crystals to dissolve, so light coats work best.  Let dry.
Step 12:
Remove the little piece of blue tape to expose the solar panel to the light of the sun, especially in a south or west window (if you live in North America), or set it where light bulbs can power the solar panel.
When the dark descends the stored energy in the battery, will turn on the light in the bottle and it will glow. What a wonderful night light for the grandchildren.  Beautiful!   Enjoy!
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    31 Discussions
    Just because I know people in different areas of the working sector...
    I asked a highway stripe paining crew for some of the little glass balls they spray into the wet paint that makes the stripes reflective at night.
    They gave me a gallon, and in the craft/Instructables world, that's a LOT of little glass beads.
    Call your local city/county/state road departments and ask if you can get a baggie full.
    Overall, another EXCELLENT INSTRUCTABLE. Thank You
    You can also obtain glass beads from airport and road pavement marking companies. Once they get wet or or debris in them they must be discarded. A gallon is definitely a lot of glass beads.
    WOW, Goat, thanks for that idea! Now I'll add that to my dumpster-diving at the bike shop for supplies. Question on the beads--you'd have to have a direct light on them to make them glow, right? They don't retain light?
    P.S. LOVE the solar night lights, Astraley.
    So I went down to the Dept of Transportation yesterday and asked--and they gave me a jar of the reflective stuff. Here's my version of the above using one of the bottles left over from my outdoor chandelier project and a Dollar Store solar light. The reflective beads were glued on the outside with polyurethane. Not sure if it adds any more than Nana's epsom salt version.
    Thank you so much for the link to my epsom salt luminaries :) yours are awesome! Just FYI that eventually the epsom salt will lose its pretty sheen as the moisture evaporates. However, you can easily wash off the jars by soaking them and then redoing them again :)
    girl_spunky
    6 years ago on Step 10
    You can get white glitter at Michael's that would give the same effect. You probably wouldn't need as much stuff to seal it either and it won't melt on you.
    Hmm, using magnesium sulfate crystals (Epsom Salts) for a textured surface, is interesting. Though I take it this is meant for indoor only, due to the salts, though if you happen to have some glass, you could break into into small pieces and use that instead. Though, one would probably want to either grind down the finished surface or cover it with a acrylic or silicone to make the surface easy to handle.
    I love this broken-glass idea, finally a use for all the tiny slithers from my sister's picture framing studio! Thanks. Really like Senkat's marble idea too but we don't have any of those.
    Cheers lads.
    SenKatBrefelanDesigns
    Reply 6 years ago on Introduction
    Possibly another reflective/refractive item could be some crackled glass marbles ! I do the DIY crackle method, which makes them fragile (bake in "brownie" pan at 400 degrees for three hours, remove from oven, and immediately pour ICE COLD water on top of them - PLEASE use common sense, protective eyewear, oven gloves, etc !)
    gtoal
    how about going for a one-two punch by painting the inside of the jars with flourescent paint? (not complex to paint, just fill it up then pour it out. let it dry and repeat a few times for a thick enough coat.)
    diajoh
    I bet you could also use unscented crystal cat litter ($4 for a 4-lb bag of Mimi Litter at Wal-Mart). Larger crystals, though, and some blue mixed in. But they wouldn't dissolve if you got them wet.
    Awesome instructable. I see a lot of these in my future. Thanks for sharing
    RobTurrentine
    6 years ago on Step 9
    Thanks. I really like this project. I may try to make one this weekend.
    MacOSJoey
    Really good idea and very nice looking, however, you specified it was for your grandkids, and I could easily see children flaking off the salt into a big mess pretty quick. Otherwise good idea,
    Korbl
    6 years ago on Step 12
    Nice instructable, and they look good, but it seems like the epsom salts might dim the light a little. You can also improve the light diffusion by filling the jars with water and a bit of bleach. You'd of course want to seal the LED against liquid pretty well. The idea comes from water bottle lights invented by a guy in Brazil during a black out, who used actual sunlight to light up his workshop during the day, using 2 cap fulls of bleach in a two liter bottle, so that gives you somewhere to start with proportions.
