How to Create a Pallet Desk
27,213
347
6
This project, while it does require some skill in using a “Skil” Saw (sorry, no pun intended), was a relatively easy undertaking that took approximately 3 hours from start to finish.  You will need safety glasses, a Skil saw, tape measure, power drill with a 3/4″ extra long bit, pencil, level (or long straight edge), screws, 4- 1/2″ washers, 4- 1/2″ Eye-bolts (2 that will fit through the depth of the pallet and allow an extra 1/2″+ and 2 to attach to your wall) and 2- 1/2″ nuts for your bolts, 2- Threaded Rods, 4- Hook and Eye Turnbuckles, spray finish, sand paper, and 2′ piece of 2×4 and a piece of plexiglass.
Step 1: Step 1 : Measure the Pallet
I made my desk by merging the two pallets to allow for a different end design and length but in retrospect I recommend using only one pallet.  Measure the depth you want for your desk (hint: you can find a pre-cut piece of plexiglass at a home improvement center measuring 24″x48″ so you may want to work with those dimensions),
Step 2: Step 2 : Cut and Sand the Pallet
using a level, mark the pallet with a pencil in a straight line across the pallet and cut with Skil saw. (make sure you leave enough overhang from a vertical support on the pallet to accomodate a 2×4 that you will need to secure your desk to the wall.then sanded the pallet to get rid of the splinters and sprayed a clear coat of varnish or you could brush on tung oil.
Step 3: Step 3: Drill Holes in the Pallet Desk
Next you will need to drill two holes in the far front corners of your desk.  Then drill matching holes or at least holes that will position your plexiglass on your desk where you want it.  Hint: It can be tricky to drill plexiglass without cracking it so try to drill 3/4 of the way through your glass and quickly pull your drill back out, the heat from the drill will complete the hole.  Position your plexiglass on the pallet, place a washer on the top, position your I-bolts, place another washer below the pallet and secure the bolts with the nuts.
Step 4: Step 4 : Secure Your Desk on the Wall
Now you will need to find two studs in your wall where you feel you want to anchor your desk.  Do not try to secure this desk to only drywall it is too heavy.  Drill and secure bolts to the wall.  Measure the desk height you want on your wall and secure your 2×4 appropriately below your pallet so the desk will rest on top of your 2×4.  Next attach your metal poles/spans to your desk and wall.You are Done !
You can find more sustainable DIY projects at http://kwyshe.com.
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    6 Discussions
    l8nite
    6 years ago on Introduction
    very creative ! think you should use a pic of the finished desk as the lead pic though
