How to Embed Objects in Resin Beach Art
1,952
10
About: Hi Everyone, I'm Jeremy Hoffpauir. I write instructables about unique DIY woodworking and home improvement projects. I use unique design elements with a rustic coastal style in my creations such as epoxy...
In this instructable, I show you how to make DIY wood and resin beach art with real sand and sand dollars. I also show you how to embed objects in resin.
While scrolling through the pictures on my phone last month, I ran across a picture of the beach my wife took last summer. The picture inspired me to do a DIY resin beach scene with a piece of scrap live edge Cypress wood from a previous project.
In order to make this project more interesting than simply a wood and resin art project, I decided to embed objects in resin such as real sand and sand dollars.
Tools & Material Used in Project
Step 1: Prepare Wood for Resin Pour
I found this unique piece of live edge cypress wood in my scrap wood bin.
Also, I chose this piece of cypress wood because the live edge would fit nicely as the beach entry of the wood and resin beach art scene.
First, I sanded both surfaces with 80 grit, 120 grit, 180 grit, and 220 grit. I lightly sanded the loose debris away from the live edge while careful not to damage it.
The edge opposite from the live edge was already straight from my previous project. Next, I squared one side of the cypress wood with my miter saw. I flipped the wood over and squared the other side. Keep in mind, I didn’t need to do square each end. However, my OCD activates when I see asymmetrical edges or sides.
Then, I took the wood to my resin pouring station to build the resin mold.
Step 2: Build Mold for Resin
First, I found a scrap piece of 3/4″ plywood to use as the bottom of the resin mold. The bottom piece of the resin mold must be at least 1.5″ wider than the wood. Additionally, the length needs to be as long as the wood and resin beach art plus 1.5″.
The additional 1.5″ in each direction (length and width) accommodates the 2 pieces of 3/4″ plywood which form the box.
Next, I covered the plywood with packing tape and covered the tape with furniture wax. The packing tape prevents the resin from adhering to the plywood. Furthermore, furniture wax (or vaseline) serves as a release agent and makes the wood and resin beach art easy to remove.
I repeated this process for the resin mold sides as well.
Build Perimeter of Resin Mold
First, I placed the cypress wood in the resin mold and grabbed a few scrap pieces of 3/4″ plywood for the each side, front, and back. As I mentioned previously, I covered the sides, front, and back pieces with packing tape and furniture wax.
Keep in mind, the perimeter pieces don’t need to be cut to size in order to fit perfectly. Essentially, they will work as long as they form a square.
Next, I used my brad nailer to hold down the sides, front, and back pieces. Then, I used my hot glue gun to seal the resin mold and prevent leaking. Silicone or hot glue seal and prevent resin from leaking. I used hot glue because it was within arm’s reach of my resin pouring station.
Ultimately, hot glue is not as strong as silicone but it dries quicker.
Step 3: First Resin Pour
For the first resin pour, I mixed 32 ounces of epoxy resin in 1 container according to the manufacturer’s instructions.
Next, I poured 16 ounces into a different container. I added 2 drops of transparent blue dye in 1 container and 2 drops of transparent green dye in the other container. This was my first time using this transparent dye, so I was careful not to add too much. I can always darken the resin beach art top layers, which is exactly what I needed to do.
This transparent dye is very thin, which could be good or bad. I believe it is good because I can control the color better. However, some may view this as bad because more dye is required to achieve the medium to darker colors.
After I mixed the transparent dye, I poured the resin. The emerald waters of Destin, Florida have a thin layer of blue/green water close to the beach and darker blue beyond the second sandbar.
Then, I removed the bubbles with my mini torch.
Step 4: Add Real Sand to Resin
I’ve read nightmare stories about people trying to mix sand and resin. Luckily, this is my second project using resin and real sand without issues.
First, I sprinkled pool sand (Quikrete) in the resin immediately after the first pour. I let the sand sink to the bottom and sprinkled more. The sand sort of clumps as it sinks to the bottom due to the thick consistency of the resin. So, sprinkling sand twice helps eliminate any bare spots on the bottom. Then, I used my mini torch to remove bubbles every 2 of 3 minutes for 15 minutes.
Step 5: Second Resin Mixing
After the first resin pour, I allowed it to cure for 24 hours. It didn’t need that much time, but I gave it that much time because I had other things to do.
Obviously, I didn’t add enough transparent dye in the resin during the first resin pour. First, I mixed 32 ounces of resin in one container and 32 ounces of resin in a different container. Next, I added about 10 drops of transparent blue dye in the first container and transparent green dye in the second container.
Add More Transparent Dye
After I mixed the 10 drops of transparent dye in each container, the color was still too light.
So, I added 5 more drops which was perfect.
Step 6: Second Resin Pour
First, I poured the green and blue resin slowly in the resin mold.
Next, I used my heat gun to blend the colors where they met in the middle.
Step 7: Embedding Real Sand Dollars in Resin
Immediately after the second resin pour, I added real sand dollars.
First, I dropped 4 sand dollars in random locations in the resin beach art scene.
Next, I used my stir stick to push the sand dollars to the bottom. I had to push the sand dollars back to the bottom twice over a period of 5 minutes to prevent them from rising.
Step 8: Add Resin Art Waves
Immediately after I added the sand dollars, I mixed 12 ounces of resin for the resin beach art waves.
Next, I mixed pearl white pigment into the resin. The resin wave effect can be accomplished many different ways, but this way works best for my work flow. Then, I poured the resin and used my heat gun to mix it. Ultimately, there is no set rule regarding this step. I simply keep playing with it until I achieve a look which appeals to me.
Step 9: Resin Lace Effect
First, I poured 12 ounces of 91% isopropyl alcohol in a spray bottle.
Next, I added 10 drops of pearl white pigment. I added 5 drops at a time until I got the color consistency I needed. Some people refer to this mixture as alcohol ink.
Then, I sprayed the mixture on the resin beach art with real sand white waves. Alcohol creates a the resin lace effect, which makes the waves look more realistic.
Finally, I used my heat gun to move the resin around and remove bubbles.
Step 10: Create Resin Cells
To create resin cells, I used 3 drops of silicone oil in various locations on the resin beach art. Resin cells create small circles on resin art because it disperses the material it comes in contact with.
This resin art effect makes the waves to appear alive or in action.
Step 11: Excess Resin
Often times, I have a small amount of excess resin after a resin pour.
So, what do I do with excess resin? How to dispose of resin properly? I pour excess resin in silicone molds (in top section of this article) to convert excess resin into something useful for future projects.
Step 12: Remove Resin Beach Art From Mold
First, I used a hammer and tapped on each end and side of the resin mold. The mold released very easily.
Next, I used a pry bar to gently pop up one end. I pulled up gently and the rest of the wood and resin beach art released very easily.
Then, I cleaned up the trash and dust from my work area.
Step 13: First Resin Flood Coat
The flood coat for any resin art project is important. It not only provides the final finish, but it also protects the resin wall art.
First, I used my leveler to make sure the resin beach art was level both horizontally and vertically.
Next, I mixed 16 ounces of resin. The flood coat is clear, so no need to add pigment or dye. Then, I used a plastic spreader to spread the material on the wood and resin beach art. The flood coat really made the resin beach art come to life!
After the resin covered the material, I spread the resin towards the side and allowed a small bead drip over.
I used a brush to smooth out the sides. The brush bristles lightly scrape the bottom to keep the resin from beading. Normally, I use my fingers to do this; however, my gloves had a tear across my fingertips. I had to wipe the sides every 3 minutes for 15 minutes. Finally, I used my torch to remove resin air pockets.
Step 14: Second Resin Flood Coat
After roughly 12 hours, I repeated the process for the second flood coat.
However, I did not use the plastic spreader with the second flood coat. I simply poured 16 ounces of material on top of the resin beach art with real sand and allowed it to self level. Of course, this won’t work unless the surface of the resin beach art is not level. If it is not level, no big deal – simply tilt the work surface in all directions and let the resin run over the opposite end.
Step 15: Conclusion
If you want to purchase this item, visit my Ebay listing here.
The picture below is what inspired me to do this project. I think I came fairly close to the water color in the picture. For what it is worth, the shallow water in Destin, Florida is normally a lighter blue with a slight green tint. It is not as green as it is in the picture.
I hope this project provided you with some value because this is, and always will be, my ultimate goal.
Please consider subscribing to my YouTube channel, Follow Me on Instagram, and visiting my website for more projects.
Also, I have digital plans available for download for many of my projects. Click Here to check those out.
Feel free to contact me anytime if you have any questions. I'm happy to help!
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
