How to Fix a Flat Tire
107,298
6
26
About: Engineer making renewable energy products for African entrepreneurs.
One day, you'll get a puncture. And I guarantee, it will be at the worst time possible. Here's how to install a spare tire.
NOTE: Some cars have locking wheel bolts. If yours does, check your glove box for a special key. If you don't have this key, and have a lock -- you will not be able to remove your wheel.
If you are uncomfortable with changing your tire on the side of the road. Call for assistance - do not drive with a spare tire or punctured tire unless you have run flat tires.
Never raise a vehicle with people inside.
It is beneficial to practice this operation in your driveway so you can complete the task quickly and comfortable on the side of the road.
Check the pressure of your spare tire frequently (at least once a month) and before long trips. There's nothing worse than finding all you have to replace your flat tire with is... a flat tire.
Avoid products like "Fix-A-Flat" and alike. These make tire repair, if not impossible, much more difficult. Only use these as a last resort.
Step 1: Get to a Safe Location
Once you've determined you have a flat or a puncture -- turn on your hazard lights and pull off the road. Ideally, you want to park on a hard, level surface that is visible to other drivers.
Once you've come to a stop, make sure that you can safely open your door.
Step 2: Preparation
First, open your hood - leave your hazard lights on. An open hood on the side of the road indicates distress and makes your car more visible.
Now, open your trunk (or wherever your spare tire is located).
Step 3: The Road Side Kit
Here we have a few items - but we only need three.
1. Screwdriver and plastic lug wrench (to unscrew once they have been freed)
2. Jack -- this one is known as "The widow maker" among the VW community
3. Lug Wrench
If you thought ahead, you might have also included gloves, to keep your hands clean.
Other good things to have
1. Flashlight (preferably a human powered one)
2. Road Marker
3. Road Flare
4. Jumper Cables (that's another instructable)
Step 4: Clear Trunk Space Remove Spare
My trunk was full of stuff -- I was off to a party! So, all if had to come out.
Once the trunk space is clear:
  • Lift the trunk floor
  • Remove Road Side Kit
  • Unscrew Spare Tire Tie Down (this keeps the tire from rattling)
  • Remove Spare Tire
You'll notice, I have a full sized spare. This means, I can put replace any tire of my car with it. For those with a "donut" spare - you can only replace a wheel that is not driven. That is, if your car is front wheel drive, AND you have a puncture on your front wheel -- you'll need to replace a rear wheel with the spare, and then replace the flat/punctured wheel with your fill sized rear wheel.
This is to prevent excessive wear on your transmission (specifically, differential). Additionally, driving with an undersized tire on a driven wheel can be dangerous.
Step 5: Secure Your Vehicle
When you lift a car with an emergency, the wheels need to be able to roll a tiny bit. Otherwise, you'll find out why this VW jack is known as the widow maker. If the wheels are not able to roll, a moment force is applied to the jack which will cause it to twist off. Not good my friends. Luckily, we can secure either the front or rear without problems ;)
For Flat Ground (that is, the car doesn't roll on it's own):
If you're replacing a front wheel -- engage the parking brake OR chock the opposite rear wheel (if possible) -- leave your transmission in neutral.
If replacing a rear wheel -- put your car in first gear (for manual transmission) OR chock the opposite front wheel -- leave the parking brake off.
Step 6: Free Wheel Bolts/Lugs
Remove any wheel center caps to reveal your lugs/bolts. Using your lug wrench, loosen each lug to break it free. DO NOT continue removing them at this point.
DO NOT raise the vehicle off the ground at this time.
Step 7: Place Jack and Raise
My jack uses my car's unibody to lift the car. There is a bit of metal that comes down vertically that the jack settles into. NOT ALL VEHICLES are like this. Check your owner's manual for the proper lift points
Place the jack down so it's "feet" are even on the ground and level. Begin raising the jack and make sure the jack cup fits into the proper portion of the frame.
Once the cup is in place, begin to lift the car slowly. Check that the jack is not twisting and that it's base is level on the ground. Should the jack start twisting or go off center -- immediatly lower the jack and try again.
Raise your vehicle so that there is a little space under your wheel.
DO NOT place your jack on soft ground such as dirt, soil or grass.
Step 8: Remove Lugs/Bolts and Wheel
Now, unscrew the lugs and remove them. Place them in a pocket or anywhere that they won't get lost.
At this time, you should be able to remove the wheel. Remove the wheel and place it under your car as shown. In the even that your jack fails, your car will not fall on to an unprotected wheel hub.
Yes, I've had a jack fail on me while rotating my tires. No, my wheels were not destroyed.
Step 9: Attach Spare
Place your spare onto your wheel hub. You may need to lift your vehicle a little more as the spare may be larger compared to a flat tire.
In my case, the wheel sits on a hub (not the bolts). So I have to place the wheel on the circular ring (pictured) - then bolt on.
Screw in all of your bolts/Lugs - until hand tight (do not use lug wrench to apply a great amount of force).
Step 10: Partially Lower Your Vehicle - Tighten Lugs
Now, remove your flat tire from under your car and lower your car so that some of the vehicles weight is place on the spare.
At this time, use your lug wrench to tighten all lugs in a star shaped criss cross pattern. This ensures the wheel tightens evenly. Look at image notes for order...
After doing one pass with your lug wrench, do a second and third.
Now Lower your vehicle completely.
Step 11: Finish Tightening and Clean Up
With the car lowered completely, tighten the lugs/bolts as hard as you can with your wrench.
Put your flat tire in your trunk (in the spare tire well if applicable) and put away your road side kit.
    • Paper Contest
      Paper Contest
    • Epilog X Contest
      Epilog X Contest
    • Sweet Treats Challenge
    26 Discussions
    menahunie
    7 years ago on Step 8
    Jacks can and do fail; especially the junk ones that come with your car.
    My girlfriends Lexus RX300 did just that. Just as I had removed the loosened lug nuts on the front tire the jack BENT ( it was in the proper lift point and straight up and not at any angle; nor did the car move ) and car dropped down... I had slid the spare tire under where you show and it stopped the car from landing on me. I use a mini FLOOR jack I bought instead and way stronger with rubber wheel chocks. You can find these in any auto or Walwart Store..
    PlayPatterns
    9 years ago on Introduction
    The most important part is to have the proper tools and be prepared BEFORE you get the flat...I stopped by the side of the road today to try to help some guys with a flat and couldnt because they didnt have the right size wrench...and neither did I
    HamO
    11 years ago on Introduction
    Extremely well done, as usual. Good job. Nice space spacing jack the VW has.
    DerinHamO
    my van also hides it in a convenient place,although i cant say the same with the spare wheel,the spare is under the car
    Derin
    here instead of opening the hood you need to place a reflective triangle 5 meters from your car (and possibly cones if you have them) be careful with car regulations
    Lithium Rain
    LOL! I was going through all my old comments/replies, and only just now found out you actually made this! A rather belated thank you and 5/5 stars.
    JerryMopar
    This instructable should be actually called CHANGING a flat tire, NOT Fixing it. Fixing it would be putting a plug in it, would be totally different. IMHO
    trebuchet03JerryMopar
    Semantics. Putting a plug in a tire is totally different than fixing it - you just can't see what sort of damage was done inside.
    TIA
    bdl
    One extremely useful tip I once had was to keep your hands at the "four" and "eight" clock positions on the wheel when removing or replacing. Should the car topple, this will throw your hands clear of the arch. The person who told me this had a hand on the "twelve" position of a wheel when the draft from a passing vehicle tipped his car off of the jack and his hand was trapped (and badly broken) for about 15 minutes until a patrol car arrived by chance. Nice instructable though. Here in the UK, I am amazed that this is not taught during driver training.
    killerjackalopebdl
    It's now being added to the test next year in both mainland and northern Ireland, along with some other stuff.
    A couple of little additions for you, the locknut key may also be in the space saver kit somewhere (where you find the tyre) and sometimes in a little compartment behind a door in the side of the boot (trunk) why there are so many places I don't know. The only tyre sealant i have ever seen work is an industrial brand one, it's not a thin gel like most and actually resembles tar, you pump that stuff in and it will seal a large hole up to about 30psi, also great for sealing tyres on to the rim, also it can be cleaned off for patching. I will remember the trade name I can only remember calling it the black stuff and black magic. Most older european cars have a scissor type jack that is 99% of the time painted black, the trick to using the crank here is to turn the handle at the bend, it's just easier. Also your fears about the jack are a sensible point to make, I actually know an owner who got a rather large chip in his shin bone when the jack pinged out. If the jacking point allows you putting the jack diagonally minimizes risk to you and still gives you good access for the actual jacking... Last point is carrying an extra piece of sturdy steel bar in the space saver is generally considered sensible, idiots at places like kwik fit alway use the air gun and even if you weigh 300lbs those nuts wont move with that little leverage, just slide the bar over the handle and it saves you alot of effort... By the way I was a tyrefitter for three years so... meh Which reminds me, if you have anything heavier than a normal saloon car I suggest finding somewhere for a cheap trolley or bottle jack, a pickup truck is best with a bottle jack, the extra lift makes life easier when you get stuck on a curb or the jungle...
