How to Frame Nick Offerman
2,127
28
8
About: Mostly, I study chemistry but sometimes I work wood. Also, the game.
This is the story of how I framed Nick Offerman in walnut.
Step 1: Tools and Materials
You will need the following stuff (you can buy most of it at Food & Stuff) :
Wood
A 2D version of Nick Offerman (see next step)
Thick paper
A glass pane
Thick cardboard
Nails
Glue
Hammer
Some fashion of saw (circular, jig, american, japanese. You name it)
Optional : a router
Sandpaper
Hand plane
Step 2: Get a 2D Nick
First, you need to develop a passion for the TV series Parks and Recreation. Then you'll want to look further into Nick Offerman, who stars as Ron Swanson, and realize that he is an accomplished woodworker, actor and lover. The next step is to start worshipping him and make you girlfriend aware of it.
If everything goes according to plan, she will send you a drawing of Nick in the mail, and you can start working on framing him.
Step 3: Kill a Walnut Tree and Make It Into a Plank
Not pictured is the chopping down as I did not carry the job myself. My granddad harvested the wood from a walnut tree in my great-grandmother's garden.
Pictured is the face of the Batman in the walnut wood.
Step 4: Make a Frame : Prepare the Wood
Using the table saw and a guide, cut the plank in equally wide slices. Using a handplane, round the outside corners. One of the sides of the frame will have a live edge and I selected a piece of wood with a lot of knots for added woodyness.
Step 5: Make a Frame : Grooves
I made the grooves with the neighbors 12000rpms digital router with a german tungsten carbide bit but really, you can do it either with a hammer and chisel, a handsaw or a circular saw (pictured).
The groove is 1,2 cm deep and 9 mm high, with a rectangular section. Make sure your glass pane has a some space (about 1 mm) to wiggle wiggle wiggle.
Step 6: Make a Frame : Cut at 45°
Once the whole length is grooved, use a miter box to cut 45° (Celsius or Fahrenheit?) angles. They need to be snug.
Step 7: Make a Frame : Glueing
I used a tight strap to hold the frame while the glue was curing, and added various bits and pieces to tighten it even more.
Step 8: Finishing
I finished with 200 then 400 grit sandpaper, then wet the surface, let dry, and sanded to 400 again the little poking bits of wood. I finished with a 1:1 mix of hexane:paraffin oil.
Step 9: Paper Frame
Using thick textured white paper and a special 45° exacto knife, I cut the piece of paper which goes right behind the glass pane and makes the framing beautiful and professional.
Step 10: Ardbeg
Self explanatory. Pour the whisky in the glass, pour the glass in the mouth. Repeat steps whisky through mouth as necessary.
Step 11: Add Glass, Paper Frame, Nick and Cardboard Back
In that order.
Then very small nails to hold the whole shabang, and paper tape on it to prevent dust from entering the frame.
Step 12: Done.
Good job, you now own your very own framed Nick Offerman. Make one for a friend. Also works with Amy Poelher or your mother-in-law.
Until next time,
Deluges
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    8 Discussions
    WilliamF134
    11 months ago
    Please make a serious woodworking comedy show on the YouTubes.
    ...I not kidding, that would be awesome.
    delugesWilliamF134
    Reply 11 months ago
    Haha thanks, maybe in another life... This one is quite packed!
    parisusa
    2 years ago
    Nick & Ron would be impressed!
    DikkenDweis
    3 years ago
    Nice job! And one of the best and most funny instructables to read :)
    delugesDikkenDweis
    Reply 3 years ago
    Thanks! Had a lot of fun making it and writing about it.
    ByronR6
    3 years ago
    Nice, I've been looking at getting into doing some framing, I don't have a Walnut tree to kill but will see what I can find
