How to Give Money As a Gift in a Unique Way
Make your own money keyring that you can hold a few notes encase of emergency or to give to someone with money rolled up inside its a great way to give someone money for their birthday ! you cna then simply pull out the note/bill by pulling it through the slot !
Step 1: Drilling the Hole
First i drilled the hole making sure to pull the drill out every so often to clear the chips out.
Step 2: Join the Hole
cut a slot with the tablesaw you need to cut far enough so you can fit a bill or note inside.
Step 3: Sanding...
I then cut the stock in half with a tablesaw and a handsaw as my blade is too dull for this hard wood, then i used an orbital sander and sanded it down then i used some hand sandpaper to knock of the sharp corners.
Step 4: Finishing Up
if you want you can drill a hole and attach a keyring, now wipe of some boiled linseed oil and try it out !
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    rainingfiction
    2 years ago
    Very creative for giving money; most people just do cool cash origami.
