How to Grow Orange Tree From Seeds. Bottle Germination Method. Work Always. 100% Success.
15,026
214
40
About: Always pass on what you have learned. https://www.youtube.com/yodha4u
Today, I am germinating orange seeds. I sailed a lot on the internet, so I find as a tree grown from seed can take up to 15 years, so I decided to try to reduce the chronology of its growth in this project, I have covered two phases here ;
1. Faster Germination Method and
2. Re-Potting,
This is a fairly simple process and its a good beginner DIY project. For this I am using a glass bottle, paper towel, tap water, container and soil, generally it went great and I am very happy, I hope you like this project.
Materials Required for Growing Oranges :-
  • Oranges
  • Bottle
  • Paper Towel
  • Water
  • Container or Pot
  • Regular Soil (Compost mix)
Note: - Plastic Container aren’t necessary, but its just help make the process go faster.
Step 1: Choosing, Extracting and Peeling of Seeds.
Get fresh oranges and make sure they full of juice, the best way to find seeds squeeze them and feel good factor after selecting orange, the next process is to extract the seeds, cut the orange in half and choose seeds and try to collect as many as you can, wash the seeds before peeling seeds.
Note:- Peeling seeds can be difficult in the first attempt, I damaged many seeds in peeling. So take time in the process. Slow and steady is the right way.
Step 2: Seeds on Paper Cloth
Now adding all the seeds on paper towels and spray water, not over do it. This can cause the seed to germinate.
Step 3: Bottle Germination Process
Fold gently paper towel and spray water on it, here I am using clean glass bottle for germination. Gently push the paper towel in bottle and sealed with a cork or a piece of wood.
Step 4: Uncapped Bottle After 7 Days
Uncapped bottle after a week and eliminate all seeds from paper towel, also careful about seeds elimination, I lost some seeds in the disposal.
Step 5: Seeds in Container
Add all the seeds in the container, here I am using the plastic container for propagation, adding regular soil mixed with compost, then loosen the soil for seeds, adding seeds and cover with soil and spraying a Little water.
Step 6: Final Look and Getting Good Progress
Here are the images of 1 month progress;
  1. After 3 days it shoots some green buds.
  2. After a week 6 buds grown little.
  3. After 2 weeks it grow little further and
  4. In 3 week it remain same length
  5. After the 4th week a month later it was gone with 2 strong shoots, but it might be fertilizing too much, there leaves getting brown also shoots a new leaves, I hope its a natural process.
I will continue to publish the growth of this plants in the comments section, I hope it will not take too long until the fruit stage. I hope you like this project. Please share your experience with any research on orange plants. Thank you!
Gardening Contest 2017
Third Prize in the
    • Organization Contest
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    40 Discussions
    Mihsin
    1 year ago
    I enjoyed going through all. I always planted lemon seeds, but none sprouted. From a horticulture point of view, trees from seeds don't produce quality fruits.
    RajenderK4Mihsin
    Reply 1 year ago
    If right planning & caring to plants, anything can be grown from seeds. I disagree , do some biological research seeds can be produce quality fruits.
    chris.manning.982
    1 year ago
    Will this work with tomato seeds? I tried germinating and then planting some cherry tomato seeds but they never sprouted.
    StarrsWifechris.manning.982
    Reply 1 year ago
    The easiest way to grow tomatoes from seed is to cut one or two in half and expel the gel like liquid into a small container, along with the seeds, of course :) Place this container into a large Ziploc and put in a warm location with Ziploc open for the first day or 2 and seal it after. I like to put mine on top of the fridge. After a few days, check for a layer of fuzzy mold growing on top. The more liquid you started with, the more mold you need to wait for to ensure all seeds get treated with the enzyme that results from the decomposing tomato product. Once you are satisfied with the mold growth, gently clean the seeds in cool or warm, not hot water and either dry for preserving, or go ahead and germinate with your preferred method. If using store bought tomatoes, I always germinate a portion from each batch before preserving to verify the seeds are viable since alot of farmers are growing gmo or sterile plants. Its best risk but an heirloom plant or seed and preserve seeds from these for future use!
    RajenderK4chris.manning.982
    Reply 1 year ago
    You can try this but it's very hard to remove tomato seeds protective layer, you can simply cut tomatoes and lay the slices on top of the soil. The sun does all the work and the seeds fall through the slice and grow up through the rotting tomato slice, almost acting like its own self-made compost in the early stages of growing. I hope this will work, let me know if you trying another attempt.
    Kevanf1RajenderK4
    Reply 1 year ago
    Great guide, thank you. I have successfully germinated lemon, grapefruit and lime seeds in the pat (many years ago) despite living in the middle of the UK. I just let my seeds dry out and then planted them in my own home made compost/fertiliser. Sadly I did not know how to properly care for them back then and they died after 12 months :( You mention this method of slicing tomatoes and just laying them on the soil. I've seen first hand nature growing this same way. It happens where people discard a half eaten (for example) cheese and tomato sandwich. As long as local wildlife does not get to the tasty treat the sandwich will degrade leaving the sliced tomato to do its stuff and the seeds germinate and produce new plants. They are quite successful at producing new tomatoes this way.
    VancoDchris.manning.982
    Reply 1 year ago
    Let one go over-ripe on the vine, then let it decompose in a small amount of water, eventually washing out the seeds....
    http://permaculturenews.org/2014/07/08/save-tomato-seeds/
    CaitD1
    1 year ago
    Yes, I have made orange wine also. It is delicious. I cannot imagine grapefruit wine though. The process is very simple and available online and in books. We have specialized stores here that sell all the supplies. Other fruit works just as well.
    CaitD1
    1 year ago
    Did this decades ago when I was in high school. We live in Florida, so that was a big advantage. We planted the seeds and when they sprouted, kept transplanting into larger containers as needed. At about 2-3 years, we set one out in the back yard. This was a grapefruit, and we had fruit on that tree for about 30 years. It finally died a while back, but my Mom froze the juice and had it year round. We were lucky and did not have to use a graft to get good fruit, but that is something to definitely consider when trying this. Grafting one or more varieties of orange onto a stock has been done with success also.
    RajenderK4CaitD1
    Reply 1 year ago
    @CaitD1 Good to hear that I revived your good memories, also how you froze juice for a year long consumption ?
    CaitD1RajenderK4
    Reply 1 year ago
    To juice oranges and grapefruit for freezing, just juice with a regular juicer and pour the juice into sterilized glass containers. Be sure to leave room for expansion caused by the freezing before capping and just put in the freezer. Thaw in refrigerator as needed. If your juice is a bit sour, you can also add a bit of sugar to taste. With the grapefruit, we did not do that.
    RajenderK4CaitD1
    Reply 1 year ago
    @CaitD1 thanks, well that's the normal, I thought you preserving like wines. :)
    Mikki G.W
    1 year ago
    I've grown tons of oranges directly in soil (usually put them in
    another potted plant and re-pot later), but they never get more than
    some 10cm tall... It's like they just stop growing taller, even though
    they seem to thrive and have a big enough pot
    RajenderK4Mikki G.W
    Reply 1 year ago
    well you can follow this instructible, I'm posting updates on regular intervals.
    eileenlilleyMrCheatak
    Reply 1 year ago
    Only if you treat them like Bonsai, i.e. trimming the roots etc. Could be fun to do that too.
    RajenderK4eileenlilley
    Reply 1 year ago
    @eileenlilley ​bonsai is for decorations, I'm going to grow as a huge tree and harvest before 15 years. That's the whole objective of this project.
    MrCheatakeileenlilley
    Reply 1 year ago
    Yeah, if you try and it works out, that would be great if you make an intractable on that.
    RobertW327
    1 year ago
    To help grow a nice strong healthy tree it is a beneficial to pick all fruit as soon as you see it ,not letting it ripen. This lets the tree put down strong roots and leads to better harvests in the future.
