How to Grow Popcorn Shoots
41,400
189
49
About: I like to design and build random things.
The decision to garden in the winter is an easy one to make. It requires very little time, space and materials to grow tasty salad greens. While reading the seed catalogs, I came across growing shoots, specifically popcorn shoots. So, off to the local farm supply store I went. I snagged a bag of seed starting mix to start the process of growing shoots.
Besides the seed starting mix, all ingredients were on hand. The popcorn came from the kitchen pantry. There were leftover aluminum casserole trays with plastic covers from the holidays. I used an extra storage container to pre-soak the popcorn seeds for a few days.
This is a great project to start over a very long snowy weekend. As for time to harvest, after the pre-soaking period, it takes 10 to 14 days to get shoots 2 to 4 inches long. The shoots are simply snipped off at the base when they have grown to the length you want. I plan to use them in stir fry dishes and salads of course.
This is such an easy crop to grow, even in the winter!
Step 1: Materials
The materials are as follows:
  • Fresh Popcorn, i.e. not 3 years old (unpopped, not the microwavable kind)
  • Flat Casserole Tray or other container with sides less than 2" deep
  • Small Container
  • Potting Soil
  • Water
  • Kitchen shears
Step 2: Pre-Soaking the Popcorn Seeds
In order to ensure a better germination rate, pre-soak the popcorn for 24-72 hours. I put approximately 3/4 cup of popcorn seeds in a glass dish and covered them generously with water. Place the container in the fridge for up to three days.
Step 3: Check for Sprouting
When you can see the nub of the root sprouting out of the majority of popcorn seed, they are ready to plant.
Step 4: Planting
Start by pouring off and discarding the soaking water. Pour 3-4 cups seed starting mix into a large mixing bowl. Add enough water to the mix so that it feels like a dampened but not soaking towel. Place enough seed starting mix in the casserole container to cover the bottom of the container about an inch deep. Gently firm and smooth out the mix. Spread the pre-sprouted popcorn seeds on the moistened seed starting mix and carefully press the seeds into the mix. They should be on top of the mix and not overcrowded.
Step 5: Place Cover on Top
Cover the newly planted seeds with the clear lid provided with the tray/casserole container. The covering creates a steady, moist environment ideal for sprouting seeds.
Growers Note: An option for blanched shoots would be to cover the lid with a cloth. Some folks like yellow blanched shoots.
Step 6: Care
Place the popcorn in a brightly lit window and wait. Check the container every day to ensure that the seeds are still moist. If needed, water the shoots by misting with fresh water. If mold starts to develop, just leave the lid off for a day. This will allow the surface of the seed starting mix to dry out a little. If your house stays dry during the winter, mold should not be an issue. If the lid is not fitted tight to the container, the shoots will lift the plastic lid up as they grow. It will take anywhere from 7 to 14 days to reach harvest. The popcorn shoots are ready to harvest when they are 2 to 4 inches long.
Step 7: Harvest
From the pictures, you will notice that the seed germination rate is different. Some shoots will take longer to reach the desired length, which provides a longer harvest. For reference, this picture was taken seven days after planting.
To harvest your popcorn shoots, simply cut each shoot as far down the stalk as possible. Once picked, if you do not use the shoots immediately, dry off any water and wrap them before placing in a container the vegetable crisper.
Enjoy your crisp fresh greens!
Step 8: Update - Growth After 2 Weeks
Step 9: References
Below are a few references for growing popcorn shoots.
Sproutpeople
Johnny's Select Seeds
Indoor Gardening Contest 2016
Runner Up in the
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Jewelry Challenge
    Jewelry Challenge
49 Discussions
38ren
2 years ago
Very interesting instructable, I had never heard of popcorn shoots before reading this :)
I do have a question if you don't mind answering; I noticed you used white popcorn kernels. Is this a requirement or will generic un-popped yellow kernels work as well?
Thanks so much for this well documented instructable, when mine grow I will be sure to post a picture ;D
38renmtairymd
Reply 2 years ago
Thanks, will check this out.
mrsmerwin
2 years ago
I had no idea that the plant was edible.
I think that most grocery store corn, including pop corn, is subsidized so if you try to grow it all the way to seed, there is no way to predict what you would get.
Ranaspmrsmerwin
Reply 2 years ago
The neat thing about corn is that it breeds true, and it's very obvious when it's crossed with another type of corn (as long as their coloration is different.) Each strand of silk goes to the body of the corn, and when the silk gets a bit of pollen on it that specific kernel forms. That is why you sometimes have dead zones on an ear of corn, (they didn't get fertilized) or you end up with different colors on an ear (unless you have a type of corn that's multicolored). Apples, on the other hand, are a complete crapshoot as to what you'll get when planted from seed, even seeds from the same apple will make wildly different types of apple.
DaviDBCoemrsmerwin
Reply 2 years ago
If the seeds have a Monsanto Patent, and you grow them to maturity, what you might get is a Lawsuit (which is partially true & partially snark). I know that is not a nice thing to say, but it was the first thing that "Popped" into my head!
BTW - I think I'll try growing the shoots, too! And it might work just as well with bird seed such as Black Oil Sunflower, Millet, and so forth.
mrsmerwinDaviDBCoe
Reply 2 years ago
Are those plants edible too? I had a field biology class in college and I know some plants are not recommended eating. I was amazed by how many plants are edible. I know things like milkweed is poisonous unless prepared properly.
Cayoticamrsmerwin
Reply 2 years ago
i agree, the old adage of "it's great to eat but you got to know how to cook it" especially applies to plants, there are many plants that are poisonous when raw but perfectly safe to eat after you cook the poison out, cashews are one I know of? Another I'm told are acorns,you have to boil them in three changes of water before they are safe.
mrsmerwinCayotica
Reply 2 years ago
Three changes of water is the same thing that Dr. G told us for the milk weed buds in field bio. On the last day of class we had a group meal where we were each assigned food from the nature area to bring. I still like the boiled coattails--with butter it is a little like corn on the cob. Coattails pollen can be used a little like corn meal and baked into muffins.
mrsmerwinbuildandsewandstuff
Reply 2 years ago
I have been sitting in the hospital with my sick and using my tablet to keep myself from going nuts. I have been having a lot of trouble with not having a real keyboard.
mrsmerwinMick Gibson
Reply 2 years ago
really! Did not know that. Dr. G did show us soap root which he claimed is still used in some places to clean fine art work. Wow, it is amazing what is coming back to me even after all these years.
mtairymdmrsmerwin
Reply 2 years ago
The corn shoots are edible and yes, it is very important to know what parts of plants are edible.
mtairymdDaviDBCoe
Reply 2 years ago
I don't think growing the hybridized popcorn to maturity will be productive because corn needs to mature all at the same exact time to get fully filled out ears. There would be differences in the maturity because the popcorn seed would have different genetics.
Good luck spouting the sunflower seeds!
mtairymdmrsmerwin
Reply 2 years ago
Yep. Its hybridized corn so it will not grow 'true to seed.'
mrsmerwinmrsmerwin
Reply 2 years ago
sometimes I hate auto correct. That should say hybridized. Yes I probably spelled it wrong.
JacobR4
2 years ago
Neat idea!
