How to Grow and Care for Baby Toes (Fenestraria Rhopalophylla)
5,858
26
About: I work at instructables by day, and turn into a stitch witch by night. follow me on instagram @jessyratfink to see what i'm working on! ^_^
The Baby Toes plant (scientific name: Fenestraria rhopalophylla) is one of my most favorite succulents because of their ease of care! They grow happily in a sunny window and offer up gorgeous flowers when they're healthy.
I bought this Baby Toes about six months ago from a Lowes with some cacti. It was in really rough shape, on the bottom of a shelving unit in the middle of the store in the dark. Since I've been caring for it, it's quadrupled in size and bloomed for me too!
In this instructable I'll walk you through the basics of caring for a Baby Toes plant, including watering, soil type, and how much light to give your Baby Toes plant.
If there's anything I missed, please ask a question in the comments below!
Step 1: What Type of Soil Should I Use for Baby Toes?
Baby Toe plants have shallow roots and are very susceptible to root rot, so it is important to use a well draining cactus/succulent soil.
I'm currently using Black Gold cactus mix for my cacti and succulents - it contains pumice, perlite and sand which allows it to dry out quicker. I like this mix because I don't have to amend it with extra pumice, sand or rocks. :)
Make sure to avoid regular potting soil or any mix with loads of humus, loam or peat moss as these hold in moisture.
Step 2: How Should I Water My Baby Toes?
Baby toes are VERY easy when it comes to watering. The clear "windows" at the top of the leaves will begin to get soft and visibly wrinkly when the plant is thirsty. The actual leaves will wrinkle as well, but the windows are the easiest to see.
Baby toes can be watered from the bottom of the pot or by pouring water gently on top - I tend to go with watering the top. Pour water gently over and around the baby toes, continuing to soak the soil until you achieve runoff from the bottom of the pot. I like to put a saucer under the pot so I can catch any runoff easily. :)
Once the baby toes are watered, place the pot back on a dry saucer and allow it to dry out completely before watering again! I keep my baby toes in a west facing window and water them once a week.
Check out my "How and When to Water Your Plants" instructable for full details.
Step 3: Do Baby Toes Bloom or Flower?
Yes! This is one of my favorite parts about this plant. When your baby toes have nice established roots and enough light and water, they will send up flowers! So far this year I've had four blooms. Two white flowers, and two buds I'm still waiting to open.
Baby toes typically have yellow or white hued flowers. My most recent flower was a shade of very light pink at first and then turned white when it fully opened.
Baby toe flowers are also very reactive to light! They will open, close, and move frequently throughout the course of the day. They're awesome to watch!
When the flowers die, trim them off at the base of their stem so the plant can go back to putting energy into producing more leaves.
Step 4: How Much Light Does My Baby Toes Need?
Baby toes need quite a bit of light. I only recommend growing them in a windowsill or outside. (If growing outside, you need very warm temperatures year round. If you live in USDA zones 10a to 11b, baby toes will do well outside!)
Inside, a south facing window will offer the most sun. West and east facing windows are great, too! Northern facing windows will offer the least light, so I'd avoid those. You want your baby toes in bright light the majority of the day.
Outside, baby toes can grow in full sunlight. (But keep in mind that you may have to water them more often due to hotter temps and direct sunlight.)
Step 5: Other Tips for Baby Toes Care
Fertilizing Baby Toes
Baby Toes can handle a small amount of fertilizer. I typically dilute my standard organic fertilizer by half and apply it once a month when my Baby Toes is actively growing. In winter, you'll want to suspend fertilizer if the plant goes dormant and stops actively growing.
Propagating Baby Toes
This can be done from both the splitting of the the plant and by seeds produced after blooming, but the seedlings take forever to grow and are hard to keep alive. I recommend uprooting the Baby Toes plant and separating rooted sections with a sharp clean knife to propagate.
Finding the Right Pot for Baby Toes
Baby Toes need a pot that is similar in size to the actual plant. In most cases, a 4 inch pot will be more than enough room! These plants don't grow super fast or large, so a smaller pot will ensure you aren't overwatering your Baby Toes. I like to use terra cotta pots for my Baby Toes plant because it allows the soil to dry out faster. Avoid pots without holes - chances are you'll kill your plant by accident thanks to water sitting in the bottom between waterings!
Check out my instructable titled "How to Choose the Right Planter or Pot for Your Plant" for more information!
    • Epilog X Contest
      Epilog X Contest
    • Faux-Real Contest
      Faux-Real Contest
    • Safe and Secure Challenge
    2 Discussions
    jsetla
    6 weeks ago
    Cool plant. I have never seen it but I have a burro's tail which is similar. But the flower on the Baby Toe is quite lovely. Thanks.
    claudette sova
    2 months ago
    Now I want Baby Toes too. I love succulents. I'll have to look for this one at Home Depot the next time I go. Thanks for the instructable...
