How to Hang an Internal Door
This guide shows you how to hang a new Internal door. It's a fairly simple job although some DIY skills are needed to cut the holes for the hinges in the new door. The job should take roughly about 2-3 hours.
Supplies:
Step 1: Removing the Old Door
Unscrew the old door, removing the screws from the bottom hinge before the top hinge. [NOTE: Where the hinges or screws have been painted over, chip away with an old screwdriver.] Make sure the door is well supported when the last screw is taken out of the top hinge.
Step 2: Cutting the New Door to Size
Position the new door in the door frame to see if it needs adjusted. Use the old door as a template by laying it on top of the new door and marking where to plane or cut. Use a panel saw if you need to take more than 6mm off the height of the new door, then sand it smooth. If you need to trim less off than 6mm then use a power plane. Ideally, there should be a 2mm gap between the door and the frame.
Step 3: Fixing the Hinges on the Door Frame
Screw each hinge to the door frame with a single screw and open the hinges. The hinge pivots (edges) should stick out from the frame edge.
Step 4: Fixing the Hinges on the Door
Unscrew the hinges from the door frame and lay them on the edge of the door, making sure they are lined up correctly. Draw around the hinge flaps and use a straight edge to mark the width of the hinge on to the door. Using a chisel make a series of cuts across the wood at 5mm intervals to the same depth as the flap
Step 5: Hanging Your New Door
With the door supported on wedges fix the hinge flaps to the door frame. [Use only one screw so that you can make adjustments.] Check that the door opens and closes easily. If it does then your ready to fix the rest of the screws.
Step 6: Painting the Door
When painting the door always follow the wood  grain for a smooth finish. Dust down the door and wipe with a cloth. Wedge the door open and apply a primer coat and undercoat. Once dry, paint the door the color of your choice.
Step 7: Finished!
If you want to know how to fit the door handle then please follow this link: http://lmgtfy.com/?q=How+to+fit+a+door+handle
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    3 Discussions
    BushieCaseyCase
    Reply 4 years ago on Introduction
    I THINK he meant "inferior" !!!
    THIS Instructable is rubbish ~ every other reference I have seen says fit the hinges with the door still on it's edge on the floor..
    BEFORE raising it into place within the doorjambs.
    AS for planing down edges to fine-tune the fit ~ I believe that there will STILL be a lot of tradies and handymen out there using hand planes and Surform tools ~ despite ready access to power tools these days ?
    Ranie-K
    7 years ago on Introduction
    So these images are OK for you to license as BY-NC-SA? I did a tine-eye-search and found one of them only on pages using Copyright statements.
