How to Install Lakka on a Raspberry Pi 3 2 1 B+ 0 Zero
7,080
65
About: I'm a YouTube Maker and Creator who loves to find ways outside of the box to create and use things. My primary mission is to teach what I have learnt in the simplest way possible to all human kind. Follow me...
In this Instructable, I'm going to show you how to install Lakka on your Raspberry Pi.
If you enjoy this Instructable, consider checking out my TechWizTime YouTube Channel
And for a good source of Raspberry Pi products, check out my Raspberry Pi Amazon List
Let's get started!
Step 1: What You'll Need Before We Start
  1. Lakka Image for Raspberry Pi
  2. 8GB MicroSD Card (Recommend Samsung)
  3. Raspberry Pi 1, 2 or 3
  4. Etcher
NOTES: The Raspberry Pi 3 requires a 2.5A power supply so make sure you have one that is capable. I highly recommend Samsung Micro SD Cards due to a technology called Wear Leveling which greatly increases the life span of the memory card.
Step 2: Download Lakka Image
Go to http://lakka.tv/ to Download the latest Lakka Image available, Click on the "Get" Button, Click on the "Get Lakka" Button, You'll be taken to a page with three options, we'll pick "GNU/Linux", You'll be taken to a list of all the devices Lakka is available for, Click the "Download Lakka" Button
Step 3: Copying the Image
Open up Etcher and Click “Select Image, Select the Lakka Image we just downloaded.
Click on “Select Drive” to select the Drive you want your image to be copied to.
NOTE: Remember to select the correct one, as the process will be messed up if you don’t choose the right one
Click on “Flash” and wait for it to copy the image to your SD Card.
NOTE: After it is done, it’ll automatically unmount the SD Card so you can take it from your Computer to continue the process
Step 4: Booting Into Lakka
Start your Raspberry Pi and wait for it to correctly boot into Lakka
Our Lakka instalation on Raspberry Pi is completed and that’s it for this tutorial. If you’ve installed Lakka on Raspberry Pi, have any suggestions or had problems during the installation, please leave a comment.
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    trialex
    2 years ago
    One suggestion would be to specify which image to choose for a Pi Zero - Lakka doens't make it obvious.
