How to Install LibreElec 7.0.2 on a Raspberry Pi 3 2 1 B+ 0 Zero
About: I'm a YouTube Maker and Creator who loves to find ways outside of the box to create and use things. My primary mission is to teach what I have learnt in the simplest way possible to all human kind. Follow me...
In this Instructable, I'm going to show you how to install LibreELEC on your Raspberry Pi.
If you enjoy this Instructable, consider checking out my TechWizTime YouTube Channel.
And for a good source of Raspberry Pi products, check out my Raspberry Pi Amazon List.
Let's get started!
Supplies:
Step 1: What You'll Need
Step 2: Download the Image
Go to https://libreelec.tv/
Scroll down to "Direct Downloads"
Select your Raspberry Pi system.
Scroll down a bit more to see the direct download link, click on it and wait for the download to finish.
Step 3: Write the Image
Open up Etcher and Click “Select Image”.
Select the LibreELEC Image we just downloaded.
Click on “Select Drive” to select the Drive you want your image to be copied to.
NOTE: Remember to select the correct one, as the process will be messed up if you don’t choose the right one.
Click on “Flash” and wait for it to copy the image to your SD Card.
After it is done, it’ll automatically unmount the SD Card so you can take it from your Computer to continue the process on your Raspberry Pi.
Step 4: Boot Into LibreELEC
Place the MicroSD Card into your Raspberry Pi.
The system will load up, and it will eventually reboot.
After the reboot is done, you'll see a First Time Setup screen, go thru it to properly configure and personalize your LibreELEC installation.
The LibreELEC installation on Raspberry Pi is completed and that’s it for this tutorial.
If you’ve installed LibreELEC on a Raspberry Pi, have any suggestions or had problems during the installation, please leave a comment.
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
