How to Install OSMC 11 on a Raspberry Pi 3, 2, 1, B+, 0
About: I'm a YouTube Maker and Creator who loves to find ways outside of the box to create and use things. My primary mission is to teach what I have learnt in the simplest way possible to all human kind. Follow me...
In this Instructable, I'm going to show you how to install OSMC on your Raspberry Pi.
If you enjoy this Instructable, consider checking out my TechWizTime YouTube Channel.
And for a good source of Raspberry Pi products, check out my Raspberry Pi Amazon List.
Let's get started!
Step 1: What You'll Need
Step 2: Download the Image
Go to https://osmc.tv/
Click on "Download"
Scroll down and click on "Disk Images"
Select your Raspberry Pi device and click on the link to download the image.
Step 3: Write the Image
Open up Etcher and Click “Select Image”.
Select the OSMC Image we just downloaded.
Click on “Select Drive” to select the Drive you want your image to be copied to.
NOTE: Remember to select the correct one, as the process will be messed up if you don’t choose the right one.
Click on “Flash” and wait for it to copy the image to your SD Card.
After it is done, it’ll automatically unmount the SD Card so you can take it from your Computer to continue the process on your Raspberry Pi.
Step 4: Configure OSMC
Once you start your Raspberry Pi, the system will automatically install some things and then it will reboot.
Once it reboots, OSMC will star to load.
After it loads you'll be prompted with the First Time Setup Wizard, go thru it to configure and personalize your OSMC installation.
The OSMC installation on Raspberry Pi is completed and that’s it for this tutorial.
If you’ve installed OSMC on a Raspberry Pi, have any suggestions or had problems during the installation, please leave a comment.
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
