How to Install Volumio on Raspberry Pi
About: I'm a YouTube Maker and Creator who loves to find ways outside of the box to create and use things. My primary mission is to teach what I have learnt in the simplest way possible to all human kind. Follow me...
In this article, you are going to learn how install Volumio on your Raspberry Pi and how to use it remotely.
If you really enjoy this article, consider checking out my Volumio on Raspberry Pi Guide
And for an awesome source of Raspberry Pi Accessories, check out my Raspberry Pi Amazon List.
Let’s get started!
Supplies:
Step 1: What You’ll Need
Step 2: Getting the Latest Volumio Image
Go to http://www.volumio.org.
Click on the “Download” Button.
Select “Raspberry Pi” and then click on “Download”
Step 3: Flash the Image
Once the Image downloaded, open Etcher and click on “Select Image”.
After you’ve selected the image, click on “Select Drive”.
NOTE: Be sure you select the correct drive.
Click on “Flash”. Once it finishes it’ll automatically unmount the MicroSD Card.
Step 4: Start Up Volumio
Wait for the Raspberry Pi to read all the Volumio files.
You’ll be taken to a login screen, log in with the username “volumio” and the password “volumio”
Step 5: Use Volumio From a Web Browser
Once you’ve set up Volumio on the Raspberry Pi, go to http://volumio.local on your Web Browser to access the remote interface.
Congratulations, you’ve just installed Volumio on your Raspberry Pi and that’s it for this tutorial.
If you enjoy this Instructable, consider checking out my TechWizTime YouTube Channel.
And for a good source of Raspberry Pi products, check out my Raspberry Pi Amazon List.
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    2 Discussions
    moviedale
    Question 10 months ago on Step 5
    I'm stumped, how do you get from Step 4 to 5? i.e., get past the command line prompt -- volumio@volumio:~$ -- for it to run or to be set up? Nothing I've tried gets past the DOS. I need to run it WIRED, as a stand alone unit w/ just kbrd, mouse and monitor into a hi-fi system. I'm new to RPi and Linux, but have used comps for 30+ years, so didn't think it should be that difficult...
    Thanks for any help, links, etc you can provide.
    StathisK6
    Question 1 year ago on Step 4
    how can i connect with pi?
