How to Integrate Wires Into 3D-Prints to Build a 18650 Battery Charger
19,228
184
32
About: My Name is Daniel Aeschlimann. During the day I am a Mechanical Engineer. During the evenings I tinker with witn my 3D-Printer, my CNC router and with Arduino. Some projects i record on video and upload them...
My goal was, to build a battery charger for 18650 Li-ion batteries. For this project, I designed a 3D-printable part where I can integrate the tp4065 charger board and the wires which connect to the battery terminals.
This method can be useful, for every 3D-print with integrated electronics.
You can also watch my Video about this Project:
Step 1: Material You Need
As charging circuit I use a tp4056 li-ion charger. This charging module is cheap and available as a protected version to prevent overcharging the battery.
TP4056 on Amazon: http://amzn.to/2fDOQ5Z
The charger which I build is capable to charger 18650 Li-ion batteries. I guess you have some because you are interested in this Instructable.
18650 Li-Ion Battery: http://amzn.to/2fEHoYv
What you need is a piece of wire. I recommend not to use litz wire but a wire with one solid copper pliable wire. It is easier to integrate into the 3D-print.
Tools:
  • Because it is a 3D-printing related project, you need a 3D-printer. (or a friend with a 3D-printer)
  • For soldering your soldering iron.
  • And for the wort with the wire side cutter, pliers, and cable stripper.
Step 2: Designing and Printing
You can download my 3D-model, print it and go to the next step. Here I will explain you my thought to my design.
My goal was, to create a well designed, and print in one part battery holder with integrated charger circuit.
I wanted to integrate all the wires into the 3D-print. First because of the nicer look, but also to avoid any failures from improper installed Wires wile later usage.
The designed features:
  • The battery snaps into its place due to the flexibly designed bracket.
  • The cutout enables an easy grabbing for removing the battery.
  • The bore is to attach the charger to my solar panel (See the Instructables)
  • The TP4056 charger circuit fits into the pocket on the side.
  • Trough the opening the status LED's of the circuit are visible.
  • To create a contact on the poles of the battery, there are two holes to thread the wire through.
  • On the bottom and top side are grooves to install the wire.
  • And for bringing the + pole wire to the bottom I designed a boring through the part.
  • For routing the wires to the charger circuit there are holes towards the soldering pads of the TP4056 module.
Step 3: Integration of the Circuit and the Wires
Now, I explain to you how I integrated the wires into the 3D-print.
  • First I soldered two wires to the tp4056 charging circuit.
  • Then I insert the charger with the wires ahead into its designated pocket.
  • The positive wire I route upwards through the long 2mm boring.
  • Now the positive wire points out of the top, and the negative wile out of the bottom.
  • The negative wire has to cross the positive wire according to the grooves in the bottom.
Step 4: Build the Pole Contacts With the Wire
Now we make the two pole contacts with the positive and negative wire to have a connection from the battery to the charger circuit.
  • Both outstanding wires we can cut down to 5cm lengths.
  • With the cable stripper, we remove the isolation from the outstanding wires.
  • now we push the wire to one boring down,
  • pull it with the pliers through,
  • and push it through the other boring back
  • and pull it tight with the pliers.
  • The end can now be cut down again to a length which can be bent over and slowed into the groove.
With this method, you will get a good contact for the battery poles.
Step 5: Glue the Wires in Place and Test the Charger
I used hot glue to ingrain the wires into the grooves.
With a multimeter, I made a short test if the polarity is correct and everything works.
As you saw on some pictures, I'm able to use this charger with my tiny solar panel.
I hope you got some inspiration and please send me some comments from you projects where you used similar methods to integrate electronics into a project.
Attention!
  • The Charger has no mechanical protection against reversing the polarity of the battery.
  • I recommend to only use 18650 Batteries with built-in protection circuit.
    • Organization Contest
    • Pie Contest
      Pie Contest
    • Remix Contest
      Remix Contest
    32 Discussions
    RobertF168
    1 year ago
    Instead of hot glue I would rather use a 3D pen with the same material. This will be nicer when finished ;)
    TheOriginalNerdRobertF168
    Reply 5 months ago
    Also, you could print an end plate to cover the whole end. Or you could print the wire recesses deeper and print a plug that presses into the recess.
    lomo85RobertF168
    Reply 1 year ago
    Yes, you are right, this would be perfect. but i did't have one.
    DennisD145
    10 months ago
    Shouldn't the battery be connected to the B+ and B- circuits instead of the OUT+ and OUT-? The OUT circuits are supposed to be used to power a device that will use the 3.7V of the 18650 battery.
    cristhompson
    1 year ago
    Brilliant. Been looking for something like this for a while. Is the tp4056 you link to the protected version?
    lomo85cristhompson
    Reply 1 year ago
    No, the linked version is a unprotected one.
    cristhompsonlomo85
    Reply 1 year ago
    Thanks.. Would you mind linking in the protested one? I don't really know what I'm looking for... Ta.
    Cris.
    jledwards666
    1 year ago
    This is kind of a side issue but I can't seem to make the first picture under Step 4 to parse correctly... what exactly am I seeing? Clearly the wire is being stripped but I've never seen a tool like that being used... it appears to be some sort of pliers with over-lapping rabbit teeth/prongs to remove the sheathing, with a hole in the lower jaw thru which a threaded part is protruded for some reason. The write up is clear enough as to what needs to occur during the step, I just can't get the picture to make any sense. Thoughts?
    lomo85jledwards666
    Reply 1 year ago
    Yes, it is a simple wire stripper. It has two sharp v-grooves-knives and with the screw, I can adjust the remaining opening to the diameter of the copper. So, the plastic will be cut and can be strippt form the wire.
    jledwards666lomo85
    Reply 1 year ago
    Thnx, Lomo85, for getting back to me about this. I had indeed suspected it was some sort of stripper but was unfamiliar with the exact type. I've been an aerospace engineer for some 28 years and have never run across anything quite like these, although I've seem many, many other variants of wire strippers. Lol, I was so interested that I sent the picture to a number of my friends (also engineers) and none of them had seen these in person before either (although one of them had seen a picture of this style before in a book/magazine). He sent me a picture which I've attached herein. So, I learned something new today! Thnx again for the nice write-up. :-)
    WannaDuino
    1 year ago
    das hast du gut gemacht, this is a very nice job dude.
    wannaduino.com
    Chuckwilcox
    1 year ago
    Hi Daniel, great design, video and instructable thanks for sharing.
    MichaelAtOz
    1 year ago
    Nice 'ible.
    "Step 5: Glue the Wires in Place and Test the Charger"
    I know it's hot glue, but
    "Step 5: Test the Charger THEN Glue the Wires in Place"
    Always test before reassembling (or gluing), inevitably it doesn't work and you need to dissemble again...
    lomo85MichaelAtOz
    Reply 1 year ago
    You are right! I already used the charger before I glued the wires in.
