Tutorial to Interface HX711 Balance Module With Load Cell
92,593
72
17
Description
This module uses 24 high-precision A / D converter. This chip is designed for high-precision electronic scale and design, has two analog input channels, programmable gain of 128 integrated amplifier. The input circuit can be configured to provide a bridge voltage electrical bridge (such as pressure, load) sensor model is an ideal high-precision, low-cost sampling front-end module.
Specification
  • Two selectable differential input channels
  • On-chip power supply regulator for load-cell and ADC analog power supply
  • On-chip oscillator requiring no external component with optional external crystal
  • On-chip power-on-reset
  • Data Accuracy: 24 bit (24 bit analog-to-digital converter chip)
  • Refresh Frequency: 10/80 Hz
  • Operation supply voltage range: 4.8 ~ 5.5V
  • Operation supply Current: 1.6mA
  • Operation temperature range: -20 ~ +85℃
  • Demension: Approx. 36mm x 21mm x 4mm / 1.42" x 0.83" x 0.16"
Step 1: Material Preparation
In this tutorial, you will need :
1. Arduino Uno Board and USB
2. HX711 Balance Sensor
3. Load Cell (can be any weight of load cell ie 20KG, 60KG or 100KG)
4. Male Female Jumpers
5. Crocodile Clip Wires
5. Arduino IDE
Step 2: HX711 Pin Description
Step 3: Load Cell Wire Connection
The four wires coming out from the wheatstone bridge on the load cell are usually :
  • Excitation+ (E+) or VCC is red
  • Excitation- (E-) or ground is black
  • Output+ (O+), Signal+ (S+)+ or Amplifier+ (A+) is white
  • Output- (O-), Signal- (S-)+ or Amplifier- (A-) is green
Step 4: Hardware Installation
HX711 to Arduino Uno :
  • VCC to 5V
  • GND TO GND
  • SCK to D5
  • DT TO D6
Load Cell to HX711
  • E+ : RED
  • E- : BLACK
  • A- : WHITE
  • A+ : GREEN
Then, connect your Arduino Uno Board to your Computer via USB.
Step 5: HX711 Library
Communicating with the Balance Module requires a driver for the HX711 sensor. The simplest way to install the driver is to download the HX711 library. Download the ZIP file below > Open Zip File > Extract to your Arduino Uno Library folder. Refer the image above for your references.
Step 6: Sample Source Code
Download the sample source code below, open and upload this sample source code into your Arduino IDE.
NOTE : You can change your calibration factor before uploading the code OR you can adjust it later in the serial monitor box since the code allow you to add and substract the value of calibration factor.
Step 7: Serial Monitor
When you has succesfully uploaded the sample source code into your Arduino Uno Board. Open Serial Monitor and it will show u as shown in the picture above.
Step 8: Result
when the serial monitor give u a value for reading, it means that u has succesfully interface your load cell. Now, you can set your own calibration factor by adjusting the value using the '+' or 'a' to increase the value OR '-' or 'z' to decrease the value. You have to calibrate only once for each load cell.
NOTE : This tutorial only show you on how to interface HX711 with load cell. We did not use the correct calibration factor. You have to set your own calibration factor for your load cell. Check on this video and tutorial to learn on how to set the calibration factor for load cells. Remember that each load cell with different weight ie. load cell 20KG, 60Kg and 100KG have different value of calibration factor. Thus, you will have to set calibration factor for each load cell with different weight.
Step 9: Videos
This video shows how to interface HX711 Balance Module with Load Cell.
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
17 Discussions
Danangbagasw
4 months ago
do you have the code hx711 with mcu ?, cause i'm going to upload it to thingspeak
ChrisM980
Question 4 months ago
Is it possible to get the weight from each load cell, or can we only get the total weight?
DanielaM78
4 months ago
this module also works for load cells of 180 kg?
nkomecharles14
Question 9 months ago
hello.. i have difficulties with my loadcell from step 9 .. i dont actually understand how the software part functions... when i run the code i get "0.00g" on the serial monitor and the value does not changes no matter the load i use on the loadcell....
PaugambiAalisons
Reply 5 months ago
Have you found an answer to this problem? Have tried different pins, etc and am still having no luck.
HI, Mistake in the script.
  • VCC to 5V
  • GND TO GND
  • SCK to D5
  • DT TO D6
D5 and D6 are actually the other way round! So SCK should go to D6.
Also green had to go to A-.,white to A+.
Otherwise, thanks for the tutorial. Thank F**K it finally works.
NatanB2
6 months ago
Hey, what kind of Load Cell (make model specifics) did you use?
Srijal97
Tip 8 months ago
Your code was helpful, thanks! One particular thing that I noticed while interfacing an S type load cell was that the load cell only measured either compression/tension at one time based on the connection of the white and green ends to the HX711. For example, when I tried it with White to A- and Green to A+, I was only able to detect compression. I interchanged White to A+ and Green to A- and got tension readings but no compression.
DharuQ
Question 9 months ago on Step 3
Can we handle the fluktasi. Like the number of weigth stop and didn't change everytime.
zeevon
Question 1 year ago
Your i2c connection diagram also wrong. Your sample program use pin 5,6 for DT & SCK but your diagram show pin 4,5. Wasting time to troubleshoot.
Budihal
Question 1 year ago on Step 5
Sir I need hx711 adc converter weighing load cell with 8051 ,I need both assembly ,c language code hole program ,because I m beginner so please
1 answer
Budihal
Question 1 year ago
I need for this daigram c or assembly language code please any body help me
1 answer
abderezak_science
1 year ago
I have a project on the electronic scale with arduino so could you help me to give me the program
ForssFägerström
1 year ago
Do you have a specific reason for connecting the white and green wire of the load cell the way you did?
In your instructions, the white wire "Output+ (O+), Signal+ (S+)+ or Amplifier+ (A+)" is connected to pin 3 (A-) in J1, which goes to pin 7 (INNA, Ch. A Negative Input) of HX711, and the green wire "Output- (O-), Signal- (S-)+ or Amplifier- (A-)" is connected to pin 4 (A+) in J1, which goes to pin 8 (INPA, Ch. A Positive Input) of HX711.
Also, what do the notations "(S+)+" and "(S-)+" mean? Typo/copy-paste error?
