How to Make 12V DC to 220V AC Inverter
42,569
107
17
About: HI! I am Junez Riyaz, currently doing Bachelor of Technology in the field of Electronics and Communication Engineering. I am much interested in inventing something new yet from my childhood. In my leisure ti...
Hello guys, In this Instructable I will instruct you to make your own 12v DC to 220v AC inverter with less number of components. In this project I use 555 timer IC in Astable multivibrator mode to generate square wave at 50Hz frequency.
More information about this project visit Electronics Projects Hub
Before going to start don't forget to vote this Instructable .
Subscribe my youtube channel Subscribe
About Inverters :
Inverters are often needed at places where it is not possible to get AC supply from the Mains. An inverter circuit is used to convert the DC power to AC power. Inverters can be of two types True/pure sine wave inverters and quasi or modified inverters. These true /pure sine wave inverters are costly ,while modified or quasi inverters are inexpensive. These modified inverters produce a square wave and these are not used to power delicate electronic equipments . Here, a simple voltage driven inverter circuit using transistors as switching devices.
Supplies:
Step 1: Components Required
Transistors [ Banggood / Aliexpress ]
BC547 - 1 [ Aliexpress ]
2N6292 - 2 [ Aliexpress ]
Resistors [ Banggood / Aliexpress ]
15k Ohm - 4
100k Ohm - 1
Capacitors [ Banggood / Aliexpress ]
0.01uF - 1
0.22uF - 1
Other
IC 555 - 1 [ Banggood / Aliexpress ]
8 Pin IC Base - 1 [ Banggood / Aliexpress ]
Switch - 1 [ Banggood / Aliexpress ]
PCB - 1 [ Banggood / Aliexpress ]
Transformer [12-0-12/3A] - 1 [Banggood]
Heat Sinks - 1 [ Banggood / Aliexpress ]
Step 2: Watch Video First!
This video gives you all the information you need to build your own 12v DC to 220v AC inverter.
During the next steps however I will present you some additional information to make the project even simpler.
Step 3: Circuiting
Here you can find the circuit.
You can see my PCB traces and it is easy to understand while making.
Place all the components on the PCB according to schematic.
Solder all the components carefully.
After circuiting now the time to test with a 220v bulb.
Step 4: You Made It!
That's all guys you made it.
Feel free to comment.
For more projects and tutorials subscribe my youtube channel [Click Here]
Visit my website Electronics Projects Hub
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    17 Discussions
    yoshuga12
    Question 2 months ago
    Does this have practical applications, If so how long should it last?
    isaacb83
    Question 4 months ago
    I have made this circuit but i didn't get the ac output before connecting the transformer. Can you please help me
    Tanmay Deuskar
    1 year ago
    Nice instructable. I want to make this project but I don't have the 2N6292 transistor. Is it possible to use a N-channel MOSFET like the IRFZ-44N instead.
    Thanks.
    ShwetaY1
    Question 4 months ago on Step 4
    How to make transformer for this project
    SavasB1
    Question 8 months ago
    watt?
    shrikantnaidu66
    Question 1 year ago
    HLLo... caN u exPLaiN fuLL worKinG oF thiS ciRcuiT in deTaiL pleZZZ...!!!! RpLY mE aS fasT as YoU caN..... Everything iN deTaiL
    NanangP1
    Question 1 year ago
    can i can chang with Tip31/41??
    gm280
    1 year ago
    I see you used the BC547 NPN transistor as an inverter setup so both power transistor are not turned on at the same time. I was just wondering why you didn't use MOSFETS instead of NPN power transistors? It would have worked and even used a lot less current wasted in heat. Either way, it is a workable circuit. Nice project.
    MikBgm280
    Reply 1 year ago
    +1 on the MOSFETS, but also maybe a fuse in line with the 12v supply, for that day when both transistors/MOSFETS turn on at once (failed BC547 or one of the main ones goes short circuit) :(
    Otherwise "Bang good" won't just be a company to buy the bits from ! :)
    RitaH25
    1 year ago
    I was wondering what i would havce to change to make this compatable to a 110v circut?
    panttalRitaH25
    Reply 1 year ago
    You can use transformer step-down 110v to 12v... And put it in reverse means out put become input and input becomes output...
    Transformer 110v to 12v-0v-12v
    Hope this helps
    JunezRiyazRitaH25
    Reply 1 year ago
    By changing transformer to 12/110 transformer
