How to Make Any Shoe Waterproof!
47,156
259
26
For this instructable I will be making a pair of my shoes waterproof. This will work on any shoe.
Supplies:
Step 1: Materials
For this project you'll need :
  • A pair of shoes
  • A white, unscented, tea light candles
  • blow dryer
Step 2:
Get the tea light candle, and rub it on the shoe (you can blow dry the candle so it'll come rub on the shoe easier). Rub the candle on the shoe until the shoe is covered in the wax, or is all white.
Step 3:
Blowdry the shoe until the shoe goes from "white", to it's original color.
Step 4: TESTING
As you can see, the shoe remains dry even when I put it under the faucet. :) hope this helps
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    26 Discussions
    bratanAndreG31
    Reply 3 years ago
    Lard works good on leather shoes. It makes them shiny too. That is if you can find lard, but probably any other animal fat will work too... 100% natural :)
    jack8559AndreG31
    Reply 3 years ago
    It should, but another alternative would be boiled linseed oil, apply with a rag (wear good rubber gloves) and let sit for a week or so outside or a place that fire can't harm anything. If boiled linseed oil is left on a cloth wadded up it can spontaneously ignite so you need to make sure the oil has had ample time to dry good. Many fires have started this way but as long as you let it dry it will remain waterproof for a long time. Cowboys used to use this method for waterproofing their canvas dusters.
    jsollienjack8559
    Reply 3 years ago
    BLO is supposedly bad for leather (brakes it down), Neatsfoot oil is cheap and works great. Added benefit; you won't smell like a wood shop for the next month or two.
    painterperson
    3 years ago
    wax will leave a (waxy, non-transparent ) residue. Hope they aren't your favorite shoes.
    vglaso
    3 years ago
    good idea! using wax to waterproof. am wondering if different types of waxes work in different ways... (is beeswax better than whatever wax is used like maybe paraffin?) candle wax- Is there a difference? How does one tell the difference-
    namoravglaso
    Reply 3 years ago
    There are as many types of wax as there are ways to produce them. Bees wax has the distinct advantage of being non chemical and having a greater malleable temperature range.
    TJLee089namora
    Reply 3 years ago
    Without exception, every substance is a chemical.
    mrgw98vglaso
    Reply 3 years ago
    Using a white crayon wax works better.
    SHOZ123
    3 years ago
    WD 40 works too if you soak the shoe and the let it dry.
    SHOZ123
    3 years ago
    reciter
    3 years ago
    Just treat the shoes with silicone spray.
    danamark
    3 years ago
    Orvis sells Barbour Thornproof Dressing. It's waterproof, a modern version, old version used heavy animal fats. It tricky to formulate an oil, wax dressing that behaves well in cold weather or very cold sea water and is waterproof, the stuff cracks. This stuff is slight pricey but a little goes a long way. I haven't had it cracking, usually because of the wax, in cold weather. I have it on both a hat and coat. You need to reapply yearly. Gee I think the price has doubled since I last purchased this stuff. Best to apply in hot weather, use a hair dryer.
    i.short8
    3 years ago
    Regular mineral oil will soften up paraffin and reduce its brittle nature. Melt the wax and stir in a small amount of mineral oil. Let cool. It will be softer and more pliable.
    namora
    3 years ago
    What happens when the temperature drops? My experience tells me that the wax will crack and cause the canvas shoe to develop serious wear at the joints in the wax, Perhaps a combination of neatsfoot oil with the wax could solve the problem, I suggest this or another edible oil for this because it could be absorbed through the skin. The use of neutral shoe polish might be another answer.
    Gr8Horned
    3 years ago
    Was going to mention Sno Seal and you beat me to it.
    Much Easier than trying to put a hard candle on a shoe.
    Sno Seal is Beeswax based where this is Parrafin Based.
    If your feet sweat bad, your shoes will not breath as moisture will not be allowed out or in.
    hollasch
    3 years ago
    Not much more expensive at all, and a much better form of wax for waterproofing: http://www.amazon.com/dp/B00CQJDQ90 (Snow Seal).
    armin 7
    3 years ago
    I love your fabulous idea.
