How to Make Arduino Based CNC Machine at Home
31,759
241
11
About: Make your own things........
Make a CNC Machine from old DVD writer
Step 1: Video of CNC Machine Working
Step 2: Material Required
1)Arduino Nano x1
2)Old DVD writer x2
3)Motor Driver (L293D) x2
4)16 pin IC socket x2
5) Veroboard doted x1
or you can make pcb
6)Male header & Female header
7)Female USB (For power the motors) or you can use 9v jack
8)Female Jumper wires
9) Nuts
10) BO motor clamp
11)1 Servo motor
12) Double sided tape
13)Pen
14)Acrylic sheet
Step 3: Cutting & Drilling Acrylic Sheet
1pcs 12"x6" (Fore base)
2pcs 1.5"x7" (For X-Axis Stand)
1pcs 3"x3" (For Writing base)
3pcs 1.5"x3"(For Moving part of X-Axis & Y-Axis and also for pen holder)
8pcs .5"x,5" (For specer)
Marke for drilling then drill it
Step 4: Extract X-Axis & Y-Axis From Old DVD Writer
Step 5: Solder Wire With Stepper Motor.
Step 6: Attach 1.5"x 3" Sheet With Moving Part of X-Axis and Y-Axis by Using Glue Gun
Step 7: Make Circuit Board
Make a circuit board using Dotted vero board
or
you can design a PCB ..
If you don't know how to desin pcb check this
Basic PCB designing in EAGLE | Part 1
Basic PCB designing in EAGLE | Part 2
How to print PCB at home | Part 3
Step 8: Make a Pen Holder
Cut the DVD writer Shuter Mechanism
Attach Servo and connect with the Gear
and also connect 1.5"x3" sheet with moving part and also glue the pencil compass to hold the pen...
Step 9: Assembling the Machine
Assemble all the parts as shown in Pictures ...
Step 10: Connection With Board
Step 11: Software Part
Download YOBOTS Project CNC.zip file from below
-->Open-CNC_Machine_Arduino_Code and upload the code to Arduino
-->Open- gcode_executer_For_CNC_Machine and run it
press "p" to select COM Port;
press "g" to Upload g code:
Some G code sample are given in the project file
or
if you want to create own G code watch my Tutorial
Step 12: How to Make CNC Machine at Home
Step 13: Subscribe & Like
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
11 Discussions
MuhdA51
1 year ago
hello sir,
what is the measurement for y-axis on the dvd write?
jimmytemew
1 year ago
wow, that's awesome!.....I really admire that. Pls how can i get the detail info about this project?
SadanandK
1 year ago
Hello sir..
I tried to make ur project... But my motors are not moving when gcode are executed... But when example which are included in ide software are run every thing will fine.... Help me to find out solutions
sanjayks
2 years ago
I run the test code but the stepper motor are not moving they are only vibrating
tonib5
2 years ago
awesome job
Amna97al
2 years ago
nice job
please how can i get the code
SpsinghW
2 years ago
Can you send full video while extracting and how to upload gcode in CNC machine
marcwave
2 years ago
great!! how did you figure out the pin outs (thbe right connections) for the motor wiring?
yobotsmarcwave
Reply 2 years ago
I have used multimeter....
Swansong
2 years ago
That's neat! Awesome way to reuse parts :)
