How to Make Bi-Directional Flex Sensors
120,921
293
79
Flex sensors are passive resistive devices that can be used to detect bending or flexing. The flex sensor shown in this article is a bi-directional flex sensor that decreases its resistance in proportion to the amount it is bent in either direction. The sensor we are building is about 3/8" wide by 5" long. You can easily make a sensor wider and longer depending upon your application:
Applications
Flex sensors may be used in robotics to determine joint movement or placement. They may also be used like whiskers for wall detection. The sensors we are making are also pressure sensitive so they can also be used as bumper switches for wall detection or pressure switches on robotic grippers. For bio-metrics, the sensor can be placed on a moving joint of athletic equipment to provide an electrical indication of movement or placement. A few of the sensors can be incorporated onto a glove to make virtual reality glove.
Step 1: Components:
Components:
The materials needed for the construction of the bi-direction flex sensor is shown in figure 1 and listed below. The size of the materials listed is only a guideline to the sensor we are constructing in this article. These types of sensors can be manufactured to larger widths and lengths.
1. Copper foil laminate 1/4" x 4.5" (see text)
2. Acetate 1/4" x 4.5" x .010 thick
3. Heat shrink tubing 3/8" dia x 5"
4. Resistive material 5/16" x 5" (see text)
Copper foil laminate is used in the electronics industry to make flexible circuits. It is thin copper cladding on a plastic material substrate like acetate. The material we are using is single sided copper. Copper on one side and the substrate (plastic) on the other, The copper cladding material is cut into two pieces 1/4" wide x 4.5" long strips. The material is easily cut with a scissors. Solder about 6" of wire to one end of each strip. You may fine it easier to solder the wire to the strip if you tin the bottom 3/8" of each strip. Solder each wire to one corner side of the strip. It doesnt matter which side you choose, just make sure you solder both strips on the same side, see figure 2.
Resistive Materials
There are a variety of resistive materials available; cloth, plastic and paper. The common element of all the appropriate materials is that the material is somewhat conductive or resistive. The degree to which the material is resistive will determine the scale at which your flex sensor operates. For the example here I am constructing here, I using conductive black plastic poly bags conductive bags used in the electrical industry. These bags are used to store components that are static sensitive. The bags are made from single layer of carbon-loaded polyethylene and its conductivity does not depend on humidity. I cut the bags into the 3/8 " wide by 5" long strips.
Step 2: Making the Bi-Directional Flex Sensor: (Sandwich the Materials)
The resistive material is sandwiched between the two copper clad laminates. The copper sides of the laminates are both facing toward the resistive material; see figures 3, 4 and 5. If you soldered the wires on the same side of the laminates, when you assemble the sensor, the wires will be positioned on opposite corners allowing the base of the sensor to lay flatter.
To this sandwich we add the acetate strip, see figure 6. The purpose of the acetate strip is to make the sensor more resilient and to spring back after it has been flexed.
Step 3: Packing the Sandwich
This entire sandwich is inserted into the heat shrink tubing, see figure 7. The base of the sandwiched materials is shown in figure 8, just before it is inserted completely into the heat shrink tubing.
Step 4: Sealing the Sensor
You are almost finished. At each end of the heat shrink tubing place a small amount of clear silicon sealer, see figure 9. Allow the sealer to dry according to its directions, usually around twenty-four hours.
Step 5: Testing the Bi-Directional Flex Sensor:
Set a VOM meter to read ohms. The sensor we built had a nominal resistance of approximately 20K ohms, see figure 10. As the sensor is bent in one direction Figure 12the resistance decrease in proportion to the bend to approximately 2k, see figure 11. Bending the sensor in the opposite direction also decreases the resistance in proportion to the bend to 2K ohm, see figure 12.
The sensor is also pressure and force sensitive. So pressing down on the sensor will also decrease it resistance. The basic sensor can be modified in size and shape to fit custom applications. The resistive material may also be modified to obtain different resistances and characteristics. Most materials are easily obtained from electronic sources. Images will supply the following materials to get you started.
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    79 Discussions
    ronm161
    Question 11 months ago
    Will it work for the water level?
    1 answer
    jiovineronm161
    Answer 11 months ago
    I don't understand what you mean.
    SreejanA
    1 year ago
    Once the sensor is working, Is there a method to validate the sensor? How do I compare the performance of this sensor with commercially available ones? Most papers put reliability as a parameter to show the performance of DIY sensors, but actually, do not compare with commercially existing sensors.
    jiovineSreejanA
    Reply 1 year ago
    Please let me know which commercial bi-directional sensor you are referring too.
    SreejanAjiovine
    Reply 1 year ago
    My question was intended for general comparison, not exactly on any particular sensor. However, if I choose to compare it to this (http://www.flexpoint.com/product/bend-sensor/), how can it be done? What sensor paramters do i take?
    jiovineSreejanA
    Reply 1 year ago
    These type of sensors that I know about including this one:
    https://www.sparkfun.com/products/8606
    Are resistive. The parameters to measure are changes in resistance in relationship to the degree of bending. With the DIY sensors the in-group variance will be greater than with the commercial sensors.
    HalimahaniR
    2 years ago
    Can the size of resistive material smaller than copper foil? My resistive material is anti-static bag
    jiovineHalimahaniR
    Reply 1 year ago
    It can, but it becomes easier for the two copper foils to touch and short the sensor out.
    jiovineAhsanM18
    Reply 2 years ago
    Technically you can use any conductive material such as aluminum foil. The difficulty is that it is difficult to solder to aluminum and without the conductive foil having a plastic laminate base the foil will deteriorate pretty fast when used.
    osamalios
    3 years ago
    what is the use of the acetate? just to protet the upper copper layer??
    plz answer me ...
    jiovineosamalios
    Reply 3 years ago
    The acetate adds the stiffness and flexibility to the sensor. It allows the sensor to bend and then return to its original shape when the pressure or load is removed.
    jiovine
    4 years ago on Introduction
    Check the resistive material you are using with an ohm meter. If the resistive material is so high in ohms that it doesn't register using a ohm meter it will not work in the sensor.
    The copper foils of the sensor go on opposite surfaces of the resistive material. You should be able to get a resistive reading from the copper-foil, resistive material, copper-foil sandwich before assembling the bi-flex sensor.
    jiovine
    jiovine
    No!
    If the two copper foils touch the sensor is short circuited and will not function.
    John
    yaly
    5 years ago on Step 5
    what can be used as resistive material ?
