How to Make Bulletin Board Push Pins With Miniatures
492
9
About: Introverted, fun-loving, [status quo]-disturber, who loves all things suspicious, and cute. ✿ Laryssa ✿ Make | Create | Learn | Question | Live Your Joy --- Instagram @SeekingJoyfulLiving
Personalize your bulletin board, at home or at work, with push pins that express your unique style - using miniatures. I made these pins for my kitchen bulletin board and it took no more than 15 minutes (not including glue drying time).
Step 1: Gather Your Materials
You will need:
  • clear push pins,
  • miniatures of your choice (I purchased these at Michaels)
  • good glue that bonds plastic (if your miniatures are made of something other than plastic check that your glue bonds the material to the plastic of the push pins)
  • a piece of styrofoam or floral foam (anything that you can push your pins into upright to hold them while the glue dries)
  • latex gloves (or non-latex, if you are allergic) for handling the glue
Step 2: Arrange Your Push Pins
Push your pins into your styrofoam (or material of choice)
Keep the pins an inch or so apart so you can maneuver your fingers around them as you glue on your miniatures.
Step 3: Glue Your Miniatures & Push Pins Together
Read the bonding and safety instructions on your glue of choice. (Some glues, like the one I used, require you to put the 2 pieces together and then pull them apart for a minute and then put them together again.
This would be a good time to wear your gloves. You wouldn't want to glue a miniature to your finger :)
Add a dab of glue to the top of each push pin and position each miniature to your liking on the top of each pin.
Leave the glue on your new pins to dry according to the instructions on the bottle/tube.
Step 4: Enjoy Your Unique Push Pins
Display your favourite photos and important notes with your unique push pins.
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    3 Discussions
    SayWhatWhit
    1 year ago
    I think you should do a tutorial on making the small things that you bought.
    Joyful LivingSayWhatWhit
    Reply 1 year ago
    Thanks for the suggestion. That would be a lot of fun. When I get a chance I'll give it a go :)
